My Ender 5 Auto-home's with a 12.35mm Z offset (I like the extra gap as it stops the nozzle get coated when extruder is heating up). But when I home using the Home button in Control the nozzle homes to 12.27mm. I have no idea where the 0.08mm comes from. Of course I want it to be zero. Also cannot use the Bed levelling Plugin as I cannot set a negative offset i.e. the bed never raises enough to meet the BLTouch probe.
Note the printer works fine
octoprint.version : 1.5.3 (my is if it works leave it alone. i.e. only upgrade if necessary)
Windows 10
Ender 5 (modified 32bit silent mother board with BLTouch - stock Creality firmware) MSS DD hot end, Leas screw upgraded so now 1600 steps per mm instead of the default 400
