Octoprint is currently not running error
I deleted and re-installed Octopi on my Raspberry 4 and now I am getting the message, " The OctoPrint server is currently not running
If you just started up your Raspberry Pi, please wait a couple of seconds, then try to refresh this page.
If the issue persists, please log into your Raspberry Pi via SSH and check the following:
  • Verify that the process is running: ps -ef | grep -i octoprint | grep -i python should show a python process:
pi@octopi:~ $ ps -ef | grep -i octoprint | grep -i python
pi 1441 1 6 11:12 ? 00:00:15 /home/pi/oprint/bin/python
/home/pi/oprint/bin/octoprint --host=127.0.0.1 --port=5000
  • If it isn't, the question is why. Take a look into ~/.octoprint/logs/octoprint.log , there might be an error logged in there that helps to determine what's wrong.
  • You might also want to try if you can restart the server (if no obvious error is visible): sudo service octoprint restart .
If all that doesn't help to trouble shoot the issue, you can seek support on the OctoPrint Community Forum. Please provide your OctoPi and OctoPrint versions as well as your octoprint.log and explain what you already tried and observed as detailed as possible.
I am able to access Octopi via SSH however, so I know it's up and connected.
Everything listed above.
Can't even get there
lol...
great....don't know how to do that
Octo version 5.10.63-v71+, ender 3 and 5 pro, chrome browser, Mac M1 machine and Microsoft Surface
Would this be the issue?
Yes sir, that was it! Thank you kindly!
