Octoprint issue Always Booting in safe mode
Octoprint constantly boots up in Recovery mode. I never ha that.
Tried to uninstall some addons didnt work
Its autmoatically booting so yea
No it makes the problem
Idk what to write here log provided down below
### Additional information about your setup
2023-03-15 20:23:36,554 - octoprint.startup - INFO - ******************************************************************************e[0m
2023-03-15 20:23:36,561 - octoprint.startup - INFO - Starting OctoPrint 1.8.7e[0m
2023-03-15 20:23:36,561 - octoprint.startup - INFO - Starting in SAFE MODE. Third party plugins will be disabled!e[0m
2023-03-15 20:23:36,561 - octoprint.startup - INFO - Reason for safe mode: problem during last startupe[0m
2023-03-15 20:23:36,561 - octoprint.startup - INFO - ******************************************************************************e[0m
2023-03-15 20:23:40,124 - octoprint.util.connectivity.connectivity_checker - INFO - Connectivity changed from offline to onlinee[0m
2023-03-15 20:23:40,157 - octoprint.util.connectivity.connectivity_checker - INFO - Connectivity state is currently: onlinee[0m
2023-03-15 20:23:40,157 - octoprint.util.connectivity.connectivity_checker - INFO - Connecting to 1.1.1.1:53 is workinge[0m
2023-03-15 20:23:40,157 - octoprint.util.connectivity.connectivity_checker - INFO - Resolving octoprint.org is workinge[0m
2023-03-15 20:23:40,163 - octoprint.startup - INFO - Blacklist processing done, adding 3 blacklisted plugin versions: roomtemp (any), GcodeEditor (>=0.1.1,<=0.2.8), gcodeleveling (>=0.1.0,<=0.1.1)e[0m
2023-03-15 20:23:40,166 - octoprint.plugin.core - INFO - Loading plugins from C:\Octoprint\venv\Lib\site-packages\octoprint\plugins, C:\Users\anton\AppData\Roaming\OctoPrint\plugins and installed plugin packages...e[0m
2023-03-15 20:23:41,221 - octoprint.plugin.core - INFO - Plugin GCode Viewer is disabled.e[0m
2023-03-15 20:23:41,361 - octoprint.plugin.core - INFO - Plugin Pi Support Plugin (2022.6.13) did not pass check, not loading.e[0m
2023-03-15 20:23:41,438 - octoprint.plugin.core - INFO - Found 21 plugin(s) providing 16 mixin implementations, 34 hook handlerse[0m
2023-03-15 20:23:41,458 - octoprint.server.heartbeat - INFO - Starting server heartbeat, 900.0s intervale[0m
2023-03-15 20:23:41,665 - octoprint.server - INFO - Intermediary server startede[0m
2023-03-15 20:23:41,706 - octoprint.filemanager.storage - INFO - Initializing the file metadata for C:\Users\anton\AppData\Roaming\OctoPrint\uploads...e[0m
2023-03-15 20:23:41,723 - octoprint.filemanager.storage - INFO - ... file metadata for C:\Users\anton\AppData\Roaming\OctoPrint\uploads initialized successfully.e[0m
2023-03-15 20:23:41,724 - octoprint.server - INFO - Added new permission from plugin action_command_notification: PLUGIN_ACTION_COMMAND_NOTIFICATION_SHOW (needs: "Need(method='role', value='plugin_action_command_notification_show')")e[0m
2023-03-15 20:23:41,724 - octoprint.server - INFO - Added new permission from plugin action_command_notification: PLUGIN_ACTION_COMMAND_NOTIFICATION_CLEAR (needs: "Need(method='role', value='plugin_action_command_notification_clear')")e[0m
2023-03-15 20:23:41,724 - octoprint.server - INFO - Added new permission from plugin action_command_prompt: PLUGIN_ACTION_COMMAND_PROMPT_INTERACT (needs: "Need(method='role', value='plugin_action_command_prompt_interact')")e[0m
2023-03-15 20:23:41,724 - octoprint.server - INFO - Added new permission from plugin announcements: PLUGIN_ANNOUNCEMENTS_READ (needs: "Need(method='role', value='plugin_announcements_read')")e[0m
2023-03-15 20:23:41,724 - octoprint.server - INFO - Added new permission from plugin announcements: PLUGIN_ANNOUNCEMENTS_MANAGE (needs: "Need(method='role', value='plugin_announcements_read'), Need(method='role', value='plugin_announcements_manage')")e[0m
2023-03-15 20:23:41,725 - octoprint.server - INFO - Added new permission from plugin appkeys: PLUGIN_APPKEYS_ADMIN (needs: "Need(method='role', value='plugin_appkeys_admin')")e[0m
2023-03-15 20:23:41,725 - octoprint.server - INFO - Added new permission from plugin appkeys: PLUGIN_APPKEYS_GRANT (needs: "Need(method='role', value='plugin_appkeys_user')")e[0m
2023-03-15 20:23:41,725 - octoprint.server - INFO - Added new permission from plugin backup: PLUGIN_BACKUP_ACCESS (needs: "Need(method='role', value='plugin_backup_access')")e[0m
2023-03-15 20:23:41,725 - octoprint.server - INFO - Added new permission from plugin firmware_check: PLUGIN_FIRMWARE_CHECK_DISPLAY (needs: "Need(method='role', value='plugin_firmware_check_display')")e[0m
2023-03-15 20:23:41,725 - octoprint.server - INFO - Added new permission from plugin logging: PLUGIN_LOGGING_MANAGE (needs: "Need(method='role', value='plugin_logging_manage')")e[0m
2023-03-15 20:23:41,725 - octoprint.server - INFO - Added new permission from plugin pluginmanager: PLUGIN_PLUGINMANAGER_LIST (needs: "Need(method='role', value='plugin_pluginmanager_list')")e[0m
2023-03-15 20:23:41,725 - octoprint.server - INFO - Added new permission from plugin pluginmanager: PLUGIN_PLUGINMANAGER_MANAGE (needs: "Need(method='role', value='plugin_pluginmanager_manage')")e[0m
2023-03-15 20:23:41,725 - octoprint.server - INFO - Added new permission from plugin pluginmanager: PLUGIN_PLUGINMANAGER_INSTALL (needs: "Need(method='role', value='plugin_pluginmanager_install'), Need(method='role', value='plugin_pluginmanager_manage')")e[0m
2023-03-15 20:23:41,725 - octoprint.server - INFO - Added new permission from plugin softwareupdate: PLUGIN_SOFTWAREUPDATE_CHECK (needs: "Need(method='role', value='plugin_softwareupdate_check')")e[0m
2023-03-15 20:23:41,725 - octoprint.server - INFO - Added new permission from plugin softwareupdate: PLUGIN_SOFTWAREUPDATE_UPDATE (needs: "Need(method='role', value='plugin_softwareupdate_update')")e[0m
2023-03-15 20:23:41,725 - octoprint.server - INFO - Added new permission from plugin softwareupdate: PLUGIN_SOFTWAREUPDATE_CONFIGURE (needs: "Need(method='role', value='plugin_softwareupdate_configure')")e[0m
::ffff:192.168.178.125 - - [15/Mar/2023 20:23:42] "GET /api/job HTTP/1.1" 404 -
2023-03-15 20:23:42,538 - octoprint.util.pip - INFO - Using "C:\Octoprint\venv\Scripts\python.exe -m pip" as command to invoke pipe[0m
2023-03-15 20:23:43,169 - octoprint.util.pip - INFO - Version of pip is 22.3.1e[0m
2023-03-15 20:23:43,474 - octoprint.util.pip - INFO - pip installs to C:\Octoprint\venv\Lib\site-packages (writable -> yes), --user flag needed -> no, virtual env -> yese[0m
2023-03-15 20:23:43,474 - octoprint.util.pip - INFO - ==> pip ok -> yese[0m
2023-03-15 20:23:43,489 - octoprint.plugins.softwareupdate - INFO - Loaded version cache from diske[0m
2023-03-15 20:23:43,492 - octoprint.plugins.softwareupdate - INFO - Loaded update log from diske[0m
2023-03-15 20:23:43,501 - octoprint.plugin.core - INFO - Initialized 16 plugin implementation(s)e[0m
2023-03-15 20:23:43,504 - octoprint.plugin.core - INFO - 21 plugin(s) registered with the system:
|  Action Command Notification Support (bundled) = C:\Octoprint\venv\Lib\site-packages\octoprint\plugins\action_command_notification
|  Action Command Prompt Support (bundled) = C:\Octoprint\venv\Lib\site-packages\octoprint\plugins\action_command_prompt
|  Announcement Plugin (bundled) = C:\Octoprint\venv\Lib\site-packages\octoprint\plugins\announcements
|  Anonymous Usage Tracking (bundled) = C:\Octoprint\venv\Lib\site-packages\octoprint\plugins\tracking
|  Application Keys Plugin (bundled) = C:\Octoprint\venv\Lib\site-packages\octoprint\plugins\appkeys
| !Autologin Configuration (0.2.0) = C:\Octoprint\venv\lib\site-packages\octoprint_autologin_config
|  Backup & Restore (bundled) = C:\Octoprint\venv\Lib\site-packages\octoprint\plugins\backup
|  Core Wizard (bundled) = C:\Octoprint\venv\Lib\site-packages\octoprint\plugins\corewizard
| !Dashboard (1.19.9) = C:\Octoprint\venv\lib\site-packages\octoprint_dashboard
|  Discovery (bundled) = C:\Octoprint\venv\Lib\site-packages\octoprint\plugins\discovery
|  Error Tracking (bundled) = C:\Octoprint\venv\Lib\site-packages\octoprint\plugins\errortracking
|  Event Manager (bundled) = C:\Octoprint\venv\Lib\site-packages\octoprint\plugins\eventmanager
|  File Check (2021.2.23) (bundled) = C:\Octoprint\venv\lib\site-packages\octoprint_file_check
|  Firmware Check (2021.10.11) (bundled) = C:\Octoprint\venv\lib\site-packages\octoprint_firmware_check
| !GCode Viewer (bundled) = C:\Octoprint\venv\Lib\site-packages\octoprint\plugins\gcodeviewer
|  Logging (bundled) = C:\Octoprint\venv\Lib\site-packages\octoprint\plugins\logging
| !OctoEverywhere! (2.3.7) = C:\Octoprint\venv\lib\site-packages\octoprint_octoeverywhere
|  Plugin Manager (bundled) = C:\Octoprint\venv\Lib\site-packages\octoprint\plugins\pluginmanager
| !PrettyGCode (1.2.4) = C:\Octoprint\venv\lib\site-packages\octoprint_prettygcode
|  Software Update (bundled) = C:\Octoprint\venv\Lib\site-packages\octoprint\plugins\softwareupdate
|  Virtual Printer (bundled) = C:\Octoprint\venv\Lib\site-packages\octoprint\plugins\virtual_printer
Prefix legend: ! = disabled, # = blacklisted, * = incompatiblee[0m
2023-03-15 20:23:43,509 - octoprint.environment - INFO - Detected environment is Python 3.10.10 under Windows (win32). Details:
|  hardware:
|    cores: 6
|    freq: 2904.0
|    ram: 17109819392
|  os:
|    bits: 64
|    platform: win32
|  python:
|    pip: 22.3.1
|    version: 3.10.10
|    virtualenv: C:\Octoprint\venve[0m
2023-03-15 20:23:43,513 - octoprint.server - INFO - Reset webasset folder C:\Users\anton\AppData\Roaming\OctoPrint\generated\webassets...e[0m
2023-03-15 20:23:43,513 - octoprint.server - INFO - Reset webasset folder C:\Users\anton\AppData\Roaming\OctoPrint\generated\.webassets-cache...e[0m
2023-03-15 20:23:43,513 - octoprint.server - INFO - Reset webasset folder C:\Users\anton\AppData\Roaming\OctoPrint\generated\.webassets-manifest.json...e[0m
2023-03-15 20:23:43,712 - octoprint.server - INFO - Shutting down intermediary server...e[0m
2023-03-15 20:23:43,874 - octoprint.server - INFO - Intermediary server shut downe[0m
2023-03-15 20:23:43,875 - octoprint.events - INFO - Processing startup event, this is our first evente[0m
2023-03-15 20:23:43,875 - octoprint.events - INFO - Adding 1 events to queue that were held back before startup evente[0m
2023-03-15 20:23:43,876 - octoprint.filemanager - INFO - Adding backlog items from all storage types to analysis queue...e[0m
2023-03-15 20:23:43,876 - octoprint.server - INFO - Autoconnect on startup is configured, trying to connect to the printer...e[0m
2023-03-15 20:23:43,886 - octoprint.plugins.softwareupdate - INFO - Fetching check overlays from https://plugins.octoprint.org/update_check_overlay.jsone[0m
2023-03-15 20:23:43,886 - octoprint.filemanager - INFO - Added 0 items from storage type "local" to analysis queuee[0m
2023-03-15 20:23:43,891 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valide[0m
2023-03-15 20:23:44,064 - octoprint.server - INFO - Trying to connect to configured serial port Nonee[0m
2023-03-15 20:23:44,236 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valide[0m
2023-03-15 20:23:44,297 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Detecting serial connection"e[0m
2023-03-15 20:23:44,299 - octoprint.util.comm - INFO - Serial detection: Performing autodetection with 3 port/baudrate candidates: COM1@250000, COM4@250000, COM3@250000e[0m
2023-03-15 20:23:44,299 - octoprint.util.comm - INFO - Serial detection: Trying port COM1, baudrate 250000e[0m
2023-03-15 20:23:44,300 - octoprint.util.comm - INFO - Connecting to port COM1, baudrate 250000e[0m
2023-03-15 20:23:44,302 - octoprint.server.util.watchdog - INFO - Running initial scan on watched folder...e[0m
2023-03-15 20:23:44,303 - octoprint.server.util.watchdog - INFO - ... initial scan done.e[0m
2023-03-15 20:23:44,391 - octoprint.util.comm - INFO - Failed to connect: Port COM1 is busy or does not existe[0m
2023-03-15 20:23:44,391 - octoprint.util.comm - INFO - Serial detection: Could not open port COM1, baudrate 250000, skippinge[0m
2023-03-15 20:23:44,391 - octoprint.util.comm - INFO - Serial detection: Trying port COM4, baudrate 250000e[0m
2023-03-15 20:23:44,391 - octoprint.util.comm - INFO - Connecting to port COM4, baudrate 250000e[0m
2023-03-15 20:23:44,393 - octoprint.util.comm - INFO - Serial detection: Handshake attempt #1 with timeout 2.0se[0m
2023-03-15 20:23:44,394 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0e[0m
2023-03-15 20:23:45,202 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance on Antons-Pc._http._tcp.local.' for _http._tcp.local.e[0m
2023-03-15 20:23:46,089 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance on Antons-Pc._octoprint._tcp.local.' for _octoprint._tcp.local.e[0m
2023-03-15 20:23:46,090 - octoprint.plugins.discovery - INFO - Registered OctoPrint instance on Antons-Pc for SSDPe[0m
2023-03-15 20:23:46,176 - octoprint.server - INFO - Listening on http://0.0.0.0:5000 and http://[::]:5000e[0m
2023-03-15 20:23:46,188 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valide[0m
2023-03-15 20:23:46,413 - octoprint.util.comm - INFO - Serial detection: Handshake attempt #2 with timeout 2.0se[0m
2023-03-15 20:23:46,461 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0e[0m
2023-03-15 20:23:46,475 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valide[0m
2023-03-15 20:23:46,741 - octoprint.util.pip - INFO - Using "C:\Octoprint\venv\Scripts\python.exe -m pip" as command to invoke pipe[0m
2023-03-15 20:23:46,741 - octoprint.util.pip - INFO - pip installs to C:\Octoprint\venv\Lib\site-packages (writable -> yes), --user flag needed -> no, virtual env -> yese[0m
2023-03-15 20:23:46,741 - octoprint.util.pip - INFO - ==> pip ok -> yese[0m
2023-03-15 20:23:46,743 - octoprint.plugins.softwareupdate - INFO - Minimum free storage across all update relevant locations is 16.7GB. That is considered sufficient for updating.e[0m
2023-03-15 20:23:46,814 - octoprint.server.preemptive_cache - INFO - Preemptively caching / (ui _default) for {'base_url': 'http://192.168.178.38:5000/', 'path': '/', 'query_string': 'l10n=de'}e[0m
2023-03-15 20:23:48,495 - octoprint.util.comm - INFO - Serial detection: Handshake attempt #3 with timeout 2.0se[0m
2023-03-15 20:23:48,495 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0e[0m
2023-03-15 20:23:49,352 - octoprint.server.preemptive_cache - INFO - ... done in 2.55se[0m
2023-03-15 20:23:49,352 - octoprint.server.preemptive_cache - INFO - Preemptively caching / (ui _default) for {'base_url': 'https://127.0.0.1:5000/', 'path': '/', 'query_string': 'l10n=en'}e[0m
2023-03-15 20:23:49,837 - octoprint.server.preemptive_cache - INFO - ... done in 0.48se[0m
2023-03-15 20:23:50,497 - octoprint.util.comm - INFO - Serial detection: Trying port COM3, baudrate 250000e[0m
2023-03-15 20:23:50,497 - octoprint.util.comm - INFO - Connecting to port COM3, baudrate 250000e[0m
2023-03-15 20:23:55,682 - octoprint.util.comm - INFO - Failed to connect: Port COM3 is busy or does not existe[0m
2023-03-15 20:23:55,682 - octoprint.util.comm - INFO - Serial detection: Could not open port COM3, baudrate 250000, skippinge[0m
2023-03-15 20:23:55,682 - octoprint.util.comm - INFO - Changing monitoring state from "Detecting serial connection" to "Error"e[0m
2023-03-15 20:23:55,684 - octoprint.util.comm - INFO - Changing monitoring state from "Error" to "Offline after error"e[0m
2023-03-15 20:23:55,685 - octoprint.plugins.action_command_notification - INFO - Notifications clearede[0m
2023-03-15 20:25:00,505 - octoprint.server.util.flask - INFO - Passively logging in user Anton from 192.168.178.38 via autologine[0m
2023-03-15 20:25:00,505 - octoprint.access.users - INFO - Logged in user: Antone[0m
2023-03-15 20:25:00,644 - octoprint.server.util.flask - INFO - Passively logging in user Anton from 192.168.178.38e[0m
2023-03-15 20:25:00,644 - octoprint.access.users - INFO - Logged in user: Antone[0m
2023-03-15 20:25:00,756 - octoprint.server.util.flask - INFO - Passively logging in user Anton from 192.168.178.38e[0m
2023-03-15 20:25:00,756 - octoprint.access.users - INFO - Logged in user: Antone[0m
2023-03-15 20:25:07,583 - octoprint.server.util.sockjs - INFO - New connection from client: 192.168.178.38e[0m
2023-03-15 20:25:07,834 - octoprint.server.util.flask - INFO - Passively logging in user Anton from 192.168.178.38e[0m
2023-03-15 20:25:07,834 - octoprint.access.users - INFO - Logged in user: Antone[0m
2023-03-15 20:25:08,670 - octoprint.server.util.sockjs - INFO - User Anton logged in on the socket from client 192.168.178.38e[0m
2023-03-15 20:26:06,750 - octoprint.server.util.flask - INFO - Passively logging in user Anton from 192.168.178.38 via autologine[0m
2023-03-15 20:26:06,750 - octoprint.access.users - INFO - Logged in user: Antone[0m
2023-03-15 20:26:06,841 - octoprint.server.util.sockjs - INFO - User Anton logged in on the socket from client 192.168.178.38e[0m
e[31m2023-03-15 20:26:06,841 - tornado.general - ERROR - WebSockete[0m
  File "C:\Octoprint\venv\lib\site-packages\octoprint\vendor\sockjs\tornado\transports\websocket.py", line 67, in on_message
    self.session.on_messages(msg)
  File "C:\Octoprint\venv\lib\site-packages\octoprint\vendor\sockjs\tornado\session.py", line 439, in on_messages
    self.conn.on_message(msg)
  File "C:\Octoprint\venv\lib\site-packages\octoprint\server\util\sockjs.py", line 302, in on_message
    self._on_login(user)
  File "C:\Octoprint\venv\lib\site-packages\octoprint\server\util\sockjs.py", line 741, in _on_login
    self._keep_alive.start()
  File "C:\Users\anton\AppData\Local\Programs\Python\Python310\lib\threading.py", line 930, in start
    raise RuntimeError("threads can only be started once")
RuntimeError: threads can only be started once
2023-03-15 20:26:06,842 - octoprint.server.util.sockjs - INFO - Client connection closed: 192.168.178.38e[0m
2023-03-15 20:26:06,857 - octoprint.server.util.sockjs - INFO - New connection from client: 192.168.178.38e[0m
2023-03-15 20:26:06,864 - octoprint.server.util.flask - INFO - Passively logging in user Anton from 192.168.178.38e[0m
2023-03-15 20:26:06,865 - octoprint.access.users - INFO - Logged in user: Antone[0m
2023-03-15 20:26:06,952 - octoprint.server.util.sockjs - INFO - User Anton logged in on the socket from client 192.168.178.38e[0m
Runing Octoprint on windows 11 btw. worked great befor tho
Hello @ChargedCreeper_YT !
This blue word is a link with further infos :wink:
