When connecting to my Anet running Marlin 1.1.9, I have always left the port set to AUTO. I have never had any issues. Now, with 1.4.0, I can see it trying to connect, as it reboots the controller board as always, but on the terminal, it shows:
Serial port list: ['/dev/ttyUSB0', u'/dev/ttyS0']
Trying /dev/ttyUSB0
Could not connect to or enter programming mode on /dev/ttyUSB0, might not be a printer or just not allow programming mode
Trying /dev/ttyS0
Could not connect to or enter programming mode on /dev/ttyS0, might not be a printer or just not allow programming mode
Changing monitoring state from "Detecting serial port" to "Error: Failed to autodetect serial port, please set it manually."
If I set it to /dev/ttyUSB0, it connects without issue
I have lengthened timeouts in the connection section, checked wait for start on command" all to no avail.
octoprint.log (1.0 MB) serial.log (1.7 KB)
Octoprint 1.4.0 on Octopi0.17.0, Raspberry Pi 4B 4G version, Anet A8 printer, Marlin 1.1.9 firmware
If I try to use AUTO mode, it fails imediately and Octoprint has no response - only fix complete restart or "service octorint restart".
