I am using my printer and octoprint fore a while now no problems till now.
Had bin printing to day no problems at all.
Dit a manual bed level and then a auto bed leveling becos the Z axe moved becos i prest to hard on the bed to get a print off.
When i did no longer hear my printer i sow that the lever resolts did not end in the popup screan.
And the connection to the printer was closed.
Reconected, bit later on it closed again.
After octopi closes the connection to the printer the printer continues on its last comnand.
I started unplugging all but the usb to the printer from the raspberry pi 3.
Only had a webcam and the printer on it.
Same thing.
Taken a new usb cable new port on the pi and conecter again same problem.
Restarted pi printer and pc same problem
Connecting to: /dev/ttyUSB0
Changing monitoring state from "Offline" to "Opening serial port"
Connected to: Serial<id=0x6a6a2a30, open=True>(port='/dev/ttyUSB0', baudrate=250000, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
Changing monitoring state from "Opening serial port" to "Connecting"
Send: N0 M110 N0*125
Recv: start
Recv: echo:Marlin 1.1.4
Recv:
Recv: echo: Last Updated: 2017-07-04 12:00 | Author: (none, default config)
Recv: Compiled: Jan 8 2020
Recv: echo: Free Memory: 3653 PlannerBufferBytes: 1232
Recv: echo:V39 stored settings retrieved (493 bytes; crc 10628)
Recv: echo: G21 ; Units in mm
Recv: echo: M149 C ; Units in Celsius
Recv:
Recv: echo:Filament settings: Disabled
Recv: echo: M200 D3.00
Recv: echo: M200 T1 D3.00
Recv: echo: M200 D0
Recv: echo:Steps per unit:
Recv: echo: M92 X100.00 Y100.00 Z400.00 E150.00
Recv: echo:Maximum feedrates (units/s):
Recv: echo: M203 X300.00 Y300.00 Z5.00 E25.00
Recv: echo:Maximum Acceleration (units/s2):
Recv: echo: M201 X3000 Y3000 Z100 E10000
Recv: echo:Acceleration (units/s2): P<print_accel> R<retract_accel> T<travel_accel>
Recv: echo: M204 P3000.00 R3000.00 T3000.00
Recv: echo:Advanced: S<min_feedrate> T<min_travel_feedrate> B<min_segment_time_ms> X<max_xy_jerk> Z<max_z_jerk> E<max_e_jerk>
Recv: echo: M205 S0.00 T0.00 B20000 X20.00 Y20.00 Z0.40 E5.00
Recv: echo:Home offset:
Recv: echo: M206 X0.00 Y0.00 Z0.00
Recv: echo:Auto Bed Leveling:
Recv: echo: M420 S0 Z0.00
Recv: echo:Material heatup parameters:
Recv: echo: M145 S0 H240 B60 F0
Recv: M145 S1 H240 B60 F0
Recv: echo:PID settings:
Recv: echo: M301 P22.20 I1.08 D114.00
Recv: echo: M304 P10.00 I0.02 D305.40
Recv: echo:Z-Probe Offset (mm):
Recv: echo: M851 Z-1.42
Recv: echo:SD init fail
Recv: ok
Changing monitoring state from "Connecting" to "Operational"
Recv: ok
Send: N1 M115*39
Recv: FIRMWARE_NAME:Marlin 1.1.4 (Github) SOURCE_CODE_URL:https://github.com/MarlinFirmware/Marlin PROTOCOL_VERSION:1.0 MACHINE_TYPE:3D Printer EXTRUDER_COUNT:2 UUID:cede2a2f-41a2-4748-9b12-c55c62f367ff
Recv: Cap:EEPROM:1
Recv: Cap:AUTOREPORT_TEMP:1
Recv: Cap:PROGRESS:0
Recv: Cap:PRINT_JOB:1
Recv: Cap:AUTOLEVEL:1
Recv: Cap:Z_PROBE:1
Recv: Cap:LEVELING_DATA:1
Recv: Cap:SOFTWARE_POWER:0
Recv: Cap:TOGGLE_LIGHTS:0
Recv: Cap:CASE_LIGHT_BRIGHTNESS:0
Recv: Cap:EMERGENCY_PARSER:0
Recv: ok
Send: M21
Recv: ok
Send: M420V1
Recv: Bilinear Leveling Grid:
Recv: 0 1 2 3
Recv: 0 -0.013 +0.070 -0.015 -0.018
Recv: 1 -0.108 +0.077 -0.088 -0.155
Recv: 2 -0.090 +0.002 -0.018 -0.160
Recv: 3 -0.005 +0.045 -0.058 -0.123
Recv:
Recv: echo:Bed Leveling Off
Recv: echo:Fade Height Off
Recv: ok
Send: M851
Recv: echo:Z Offset : -1.42
Recv: ok
Send: M155 S2
Recv: ok
Send: M104 S220
Recv: ok
Send: M140 S80
Recv: ok
Send: G28
Recv: echo:busy: processing
Printer seems to support the busy protocol, will adjust timeouts and set busy interval accordingly
Recv: X:85.00 Y:104.00 Z:11.42 E:0.00 Count X:8500 Y:10400 Z:4568
Recv: ok
Send: G29
Changing monitoring state from "Operational" to "Offline"
I am using a raspberry pi 3 and the Flsun Cube 3d with the mks gen l v1.0 board running marlin
