Can't find any:
"debian@beaglebone:~/OctoPrint/venv/bin$ cd ~/.octoprint/logs
-bash: cd: /home/debian/.octoprint/logs: No such file or directory"
Hi @UFAnders - I'm wondering if you ever got Octoprint to work on the BeagleBone Black? I'm looking into trying it, as the RPi's are hard to come by and I happen to have a couple BBB's available. I also saw a comment by someone saying they'd been able to do it, which gives me hope.
Any info would be greatly appreciated! thanks in advance -
thanks very much! I'll give it a try and report back. I've tried to install it manually (after stock BBB Debian 10.5 install), but running into trouble trying to upgrade python and get it running in the virtual environment described in the how-to I found. I'm a neophyte linux user, I have to google every command - very monkey see/do. I was, however, able to get Octoprint running on my only available RPi3B, so perhaps this method will work for me.
I run Octoprint on a BeagleBone Black with Debian Buster. Works fine for everyday printing but using a webcam with the -y option seemed to overload the processor sometimes.
Post where you got stuck and I´ll see if I can help you out?
My version info:
python3 --version
Python 3.7.3
cat /etc/dogtag
BeagleBoard.org Debian Buster IoT Image 2020-04-06
uname -a
Linux beaglebone 4.19.94-ti-r70 #1buster SMP PREEMPT Fri Dec 24 16:57:36 UTC 2021 armv7l GNU/Linux
