Octoprint on connecting to printer moves x and y axis and crashes into ends. HELP
hey guys i have a cr10 with a bl touch and a octoprint. for some reason when i connect to the printer, it lowers and retracts bltouch, moves x and y axis to basic middle of table (if it was at front left before connect) if if i disconnect from pinter or turn it off, it will move x and y axis again to the right and back, and crashes into ends. it keeps trying to move to the right and back each time it turns on... no idea why its doing this. please help
Need help? Read this first! Remember to provide version numbers, relevant log files and general information about your setup. Problem solved? Mark the solution! WE NEED LOGS TO HELP YOU!
With the information you have supplied, I'd guess that you have some Settings, GCODE Scripts defined.
If you want a better answer, then please supply logs including a serial.log.
