Octoprint plugin will not allow restore from previous backup. I went to update to the new Octopi version and decides to create a fresh install on another SD card. I made a backup of the instance I am using and downloaded it to my Mac. On the setup of the new instance it asked if I wanted to restore from backup, I said yes and went to the folder. No files in that backup are selectable. Is the backup/Restore plugin supposed to read the backup or is there something else I need to be doing
searched the forums and see many manual SSH solutions. There was a thread that talked about dropping the files into the location on the SD card. Need some help there.
NA
Complete Logs
