Unable to start Octoprint.
Everything started up fine, and an update was started from the server front-end in the webapp. After that, it hasn't worked at all. I can connect in putty but the octoprint service appears stuck in active (exited) and the logfile will no longer update.
I ran ps -ef | grep -i octoprint | grep -i python (which returned nothing) and looked at the logfiles. I also attempted to restart octoprint using sudo service octoprint restart.
pi@192.168.0.23's password:
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Tue Mar 27 20:56:41 2018 from 192.168.0.120
Access OctoPrint from a web browser on your network by navigating to any of:
http://octopi.local
http://192.168.0.23
http://2601:845:100:2660:1a4b:92a9:4ee9:146a
https is also available, with a self-signed certificate.
OctoPrint version : 1.3.6
OctoPi version : 0.14.0
pi@octopi:~ $ sudo nano ~/.octoprint/logs/octoprint.log
GNU nano 2.2.6 File: /home/pi/.octoprint/logs/octoprint.log
2018-03-27 20:23:57,350 - octoprint.server - INFO - --- Log roll over detected ---------------------------------------------------
2018-03-27 20:23:57,350 - octoprint.server - INFO - OctoPrint 1.3.4 (master branch)
2018-03-27 20:23:57,351 - octoprint.plugin.core - INFO - 7 plugin(s) registered with the system:
| Announcement Plugin (bundled) = /home/pi/oprint/lib/python2.7/site-packages/OctoPrint-1.3.4-py2.7.egg/octoprint/plugins/announcements
| Core Wizard (bundled) = /home/pi/oprint/lib/python2.7/site-packages/OctoPrint-1.3.4-py2.7.egg/octoprint/plugins/corewizard
| CuraEngine (<= 15.04) (bundled) = /home/pi/oprint/lib/python2.7/site-packages/OctoPrint-1.3.4-py2.7.egg/octoprint/plugins/cura
| Discovery (bundled) = /home/pi/oprint/lib/python2.7/site-packages/OctoPrint-1.3.4-py2.7.egg/octoprint/plugins/discovery
| Plugin Manager (bundled) = /home/pi/oprint/lib/python2.7/site-packages/OctoPrint-1.3.4-py2.7.egg/octoprint/plugins/pluginmanager
| Software Update (bundled) = /home/pi/oprint/lib/python2.7/site-packages/OctoPrint-1.3.4-py2.7.egg/octoprint/plugins/softwareupdate
| Virtual Printer (bundled) = /home/pi/oprint/lib/python2.7/site-packages/OctoPrint-1.3.4-py2.7.egg/octoprint/plugins/virtual_printer
2018-03-27 20:23:57,351 - octoprint.server - INFO - ------------------------------------------------------------------------------
2018-03-27 20:23:57,348 - octoprint.server.util.flask.PreemptiveCache - INFO - Adding entry for / and {'query_string': 'l10n=en', 'path': u'/', '_count':$
2018-03-27 20:24:06,105 - octoprint.server.util.sockjs - INFO - New connection from client: 192.168.0.120
2018-03-27 20:24:50,016 - octoprint.plugins.announcements - INFO - Loaded channel _important from http://octoprint.org/feeds/important.xml in 1.2s
2018-03-27 20:24:52,010 - octoprint.plugins.announcements - INFO - Loaded channel _releases from http://octoprint.org/feeds/releases.xml in 1.5s
2018-03-27 20:24:53,150 - octoprint.plugins.announcements - INFO - Loaded channel _blog from http://octoprint.org/feeds/octoblog.xml in 1.0s
2018-03-27 20:24:54,328 - octoprint.plugins.announcements - INFO - Loaded channel _plugins from http://plugins.octoprint.org/feed.xml in 1.1s
2018-03-27 20:24:55,484 - octoprint.plugins.announcements - INFO - Loaded channel _octopi from http://octoprint.org/feeds/octopi.xml in 1.0s
2018-03-27 20:24:56,452 - octoprint.plugins.softwareupdate - INFO - Saved version cache to disk
2018-03-27 20:33:08,244 - octoprint.server.util.sockjs - INFO - Client connection closed: 192.168.0.120
2018-03-27 20:33:08,803 - octoprint.server.util.sockjs - INFO - New connection from client: 192.168.0.120
2018-03-27 20:33:14,260 - octoprint.plugins.softwareupdate - INFO - Starting update of octoprint to 1.3.6...
pi@octopi:~ $ sudo service octoprint status
β octoprint.service - LSB: OctoPrint daemon
Loaded: loaded (/etc/init.d/octoprint)
Active: active (exited) since Tue 2018-03-27 21:30:23 EDT; 3min 33s ago
Process: 523 ExecStart=/etc/init.d/octoprint start (code=exited, status=0/SUCCESS)
Mar 27 21:30:23 octopi octoprint[523]: Starting OctoPrint Daemon: OctoPrint.
Mar 27 21:30:23 octopi systemd[1]: Started LSB: OctoPrint daemon.
