Hello,
I have the common "The OctoPrint server is currently not running" problem. I have seemingly tried everything I can think of (that I know how to do). It is worth noting I'm not 100% familiar with how exactly the system functions.
- Verify the Process is running, it is not, no return after running
ps -ef | grep -i octoprint | grep -i python
as the prompt suggests - Resetting the server using
as the prompt suggests - Running in safe mode, it did not do anything new or different
- Yes, the server does not run.
- No.
- There was no way for me to obtain it. After trying to run the
~/oprint/bin/octoprint systeminfo
from the command line, I get the error "AttributeError: module 'click' has no attribute 'make_pass_decorator'"
- OctoPrint version: 1.7.2
- OctoPi version: 0.18.0
- Printer: Ender 3 v2
Here are the logs I was able to pull using WinSCP.
octoprint.log (255.6 KB)
plugin_pluginmanager_console.log (10.8 KB)
plugin_softwareupdate_console.log (73.4 KB)
From what I pulled from the logs, it looks like it's something with either OctoEverywhere or Octolapse. I tried using ~/oprint/bin/pip uninstall <plugin>
according to this forum, but it draws the error "Warning: Skipping "OctoEverywhere"/"OctoLapse" as it is not installed". Maybe I am doing something wrong but I can't get it to work.
Any help would be appreciated. Thanks.
