After updating Windows 10 to the latest version my OctPrint-server wont start
Re-booted several times
Yes, but only the black CMD-windows comes up for a short time and then disappears again
It's completely NON SENCE to me how to get this "Systeminfo Bundle" !
I get this when I try to start the OctoPrint server:
2022-07-17 18:06:31,957 - octoprint.startup - INFO - ******************************************************************************
2022-07-17 18:06:31,957 - octoprint.startup - INFO - Starting OctoPrint 1.6.1
2022-07-17 18:06:32,255 - octoprint.util.connectivity.connectivity_checker - INFO - Connectivity changed from offline to online
2022-07-17 18:06:32,316 - octoprint.util.connectivity.connectivity_checker - INFO - Connectivity state is currently: online
2022-07-17 18:06:32,316 - octoprint.util.connectivity.connectivity_checker - INFO - Connecting to 1.1.1.1:53 is working
2022-07-17 18:06:32,316 - octoprint.util.connectivity.connectivity_checker - INFO - Resolving octoprint.org is working
2022-07-17 18:06:32,332 - octoprint.startup - INFO - Blacklist processing done, adding 12 blacklisted plugin versions: roomtemp (any), GcodeEditor (0.1.1), GcodeEditor (0.2.0), GcodeEditor (0.2.1), GcodeEditor (0.2.2), GcodeEditor (0.2.3), GcodeEditor (0.2.4), GcodeEditor (0.2.5), GcodeEditor (0.2.6), GcodeEditor (0.2.8), gcodeleveling (0.1.0), gcodeleveling (0.1.1)
2022-07-17 18:06:32,364 - octoprint.plugin.core - INFO - Loading plugins from c:\octoprint\venv\lib\site-packages\octoprint\plugins, C:\Users\kelds\AppData\Roaming\OctoPrint\plugins and installed plugin packages...
2022-07-17 18:06:33,426 - octoprint.plugin.core - INFO - Plugin Pi Support Plugin (2021.3.26.post2) did not pass check, not loading.
2022-07-17 18:06:33,505 - octoprint.plugin.core - INFO - Found 16 plugin(s) providing 16 mixin implementations, 32 hook handlers
2022-07-17 18:06:33,582 - octoprint.server.heartbeat - INFO - Starting server heartbeat, 900.0s interval
2022-07-17 18:06:33,894 - octoprint.server - INFO - Intermediary server started
2022-07-17 18:06:33,911 - octoprint.filemanager.storage - INFO - Initializing the file metadata for C:\Users\kelds\AppData\Roaming\OctoPrint\uploads...
2022-07-17 18:06:34,114 - octoprint.filemanager.storage - INFO - ... file metadata for C:\Users\kelds\AppData\Roaming\OctoPrint\uploads initialized successfully.
2022-07-17 18:06:34,114 - octoprint.server - INFO - Added new permission from plugin action_command_notification: PLUGIN_ACTION_COMMAND_NOTIFICATION_SHOW (needs: u"Need(method='role', value=u'plugin_action_command_notification_show')")
2022-07-17 18:06:34,114 - octoprint.server - INFO - Added new permission from plugin action_command_notification: PLUGIN_ACTION_COMMAND_NOTIFICATION_CLEAR (needs: u"Need(method='role', value=u'plugin_action_command_notification_clear')")
2022-07-17 18:06:34,130 - octoprint.server - INFO - Added new permission from plugin action_command_prompt: PLUGIN_ACTION_COMMAND_PROMPT_INTERACT (needs: u"Need(method='role', value=u'plugin_action_command_prompt_interact')")
2022-07-17 18:06:34,130 - octoprint.server - INFO - Added new permission from plugin announcements: PLUGIN_ANNOUNCEMENTS_READ (needs: u"Need(method='role', value=u'plugin_announcements_read')")
2022-07-17 18:06:34,130 - octoprint.server - INFO - Added new permission from plugin announcements: PLUGIN_ANNOUNCEMENTS_MANAGE (needs: u"Need(method='role', value=u'plugin_announcements_manage'), Need(method='role', value=u'plugin_announcements_read')")
2022-07-17 18:06:34,130 - octoprint.server - INFO - Added new permission from plugin appkeys: PLUGIN_APPKEYS_ADMIN (needs: u"Need(method='role', value=u'plugin_appkeys_admin')")
2022-07-17 18:06:34,130 - octoprint.server - INFO - Added new permission from plugin backup: PLUGIN_BACKUP_ACCESS (needs: u"Need(method='role', value=u'plugin_backup_access')")
2022-07-17 18:06:34,130 - octoprint.server - INFO - Added new permission from plugin firmware_check: PLUGIN_FIRMWARE_CHECK_DISPLAY (needs: u"Need(method='role', value=u'plugin_firmware_check_display')")
2022-07-17 18:06:34,130 - octoprint.server - INFO - Added new permission from plugin logging: PLUGIN_LOGGING_MANAGE (needs: u"Need(method='role', value=u'plugin_logging_manage')")
2022-07-17 18:06:34,130 - octoprint.server - INFO - Added new permission from plugin pluginmanager: PLUGIN_PLUGINMANAGER_MANAGE (needs: u"Need(method='role', value=u'plugin_pluginmanager_manage')")
2022-07-17 18:06:34,130 - octoprint.server - INFO - Added new permission from plugin pluginmanager: PLUGIN_PLUGINMANAGER_INSTALL (needs: u"Need(method='role', value=u'plugin_pluginmanager_install'), Need(method='role', value=u'plugin_pluginmanager_manage')")
2022-07-17 18:06:34,130 - octoprint.server - INFO - Added new permission from plugin softwareupdate: PLUGIN_SOFTWAREUPDATE_CHECK (needs: u"Need(method='role', value=u'plugin_softwareupdate_check')")
2022-07-17 18:06:34,130 - octoprint.server - INFO - Added new permission from plugin softwareupdate: PLUGIN_SOFTWAREUPDATE_UPDATE (needs: u"Need(method='role', value=u'plugin_softwareupdate_update')")
2022-07-17 18:06:34,130 - octoprint.server - INFO - Added new permission from plugin softwareupdate: PLUGIN_SOFTWAREUPDATE_CONFIGURE (needs: u"Need(method='role', value=u'plugin_softwareupdate_configure')")
2022-07-17 18:06:34,191 - octoprint.plugins.softwareupdate - INFO - Loaded version cache from disk
2022-07-17 18:06:34,707 - octoprint.util.pip - INFO - Using "c:\octoprint\venv\scripts\python.exe -m pip" as command to invoke pip
2022-07-17 18:06:35,191 - octoprint.util.pip - INFO - Version of pip is 20.2.4
2022-07-17 18:06:35,191 - octoprint.util.pip - INFO - pip installs to c:\octoprint\venv\Lib\site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2022-07-17 18:06:35,207 - octoprint.util.pip - INFO - ==> pip ok -> yes
2022-07-17 18:06:35,207 - octoprint.plugin.core - INFO - Initialized 16 plugin implementation(s)
2022-07-17 18:06:35,207 - octoprint.plugin.core - INFO - 16 plugin(s) registered with the system:
| Action Command Notification Support (bundled) = c:\octoprint\venv\lib\site-packages\octoprint\plugins\action_command_notification
| Action Command Prompt Support (bundled) = c:\octoprint\venv\lib\site-packages\octoprint\plugins\action_command_prompt
| Announcement Plugin (bundled) = c:\octoprint\venv\lib\site-packages\octoprint\plugins\announcements
| Anonymous Usage Tracking (bundled) = c:\octoprint\venv\lib\site-packages\octoprint\plugins\tracking
| Application Keys Plugin (bundled) = c:\octoprint\venv\lib\site-packages\octoprint\plugins\appkeys
| Backup & Restore (bundled) = c:\octoprint\venv\lib\site-packages\octoprint\plugins\backup
| Core Wizard (bundled) = c:\octoprint\venv\lib\site-packages\octoprint\plugins\corewizard
| Discovery (bundled) = c:\octoprint\venv\lib\site-packages\octoprint\plugins\discovery
| Error Tracking (bundled) = c:\octoprint\venv\lib\site-packages\octoprint\plugins\errortracking
| File Check (2021.2.23) (bundled) = c:\octoprint\venv\lib\site-packages\octoprint_file_check
| Firmware Check (2021.5.31) (bundled) = c:\octoprint\venv\lib\site-packages\octoprint_firmware_check
| GCode Viewer (bundled) = c:\octoprint\venv\lib\site-packages\octoprint\plugins\gcodeviewer
| Logging (bundled) = c:\octoprint\venv\lib\site-packages\octoprint\plugins\logging
| Plugin Manager (bundled) = c:\octoprint\venv\lib\site-packages\octoprint\plugins\pluginmanager
| Software Update (bundled) = c:\octoprint\venv\lib\site-packages\octoprint\plugins\softwareupdate
| Virtual Printer (bundled) = c:\octoprint\venv\lib\site-packages\octoprint\plugins\virtual_printer
2022-07-17 18:06:35,223 - octoprint.environment - INFO - Detected environment is Python 2.7.14 under Windows (win32). Details:
| hardware:
| cores: 2
| freq: 3000.0
| ram: 6135529472
| os:
| bits: 32
| platform: win32
| python:
| pip: 20.2.4
| version: 2.7.14
| virtualenv: c:\octoprint\venv
2022-07-17 18:06:35,223 - octoprint.server - INFO - Reset webasset folder C:\Users\kelds\AppData\Roaming\OctoPrint\generated\webassets...
2022-07-17 18:06:35,223 - octoprint.server - INFO - Reset webasset folder C:\Users\kelds\AppData\Roaming\OctoPrint\generated\.webassets-cache...
2022-07-17 18:06:35,598 - octoprint.server - INFO - Shutting down intermediary server...
2022-07-17 18:06:35,926 - octoprint.server - INFO - Intermediary server shut down
2022-07-17 18:06:35,926 - octoprint.events - INFO - Processing startup event, this is our first event
2022-07-17 18:06:35,926 - octoprint.events - INFO - Adding 1 events to queue that were held back before startup event
2022-07-17 18:06:35,926 - octoprint.filemanager - INFO - Adding backlog items from all storage types to analysis queue...
2022-07-17 18:06:35,926 - octoprint.server - INFO - Autoconnect on startup is configured, trying to connect to the printer...
2022-07-17 18:06:35,957 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2022-07-17 18:06:35,957 - octoprint.plugins.softwareupdate - INFO - Fetching check overlays from https://plugins.octoprint.org/update_check_overlay.json
2022-07-17 18:06:35,957 - octoprint.filemanager - INFO - Added 0 items from storage type "local" to analysis queue
2022-07-17 18:06:36,036 - octoprint.server - INFO - Trying to connect to configured serial port None
2022-07-17 18:06:36,114 - octoprint.plugins.softwareupdate - INFO - Fetching check overlays from https://plugins.octoprint.org/update_check_overlay_py2.json
2022-07-17 18:06:36,161 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Detecting serial connection"
2022-07-17 18:06:36,176 - octoprint.server.util.watchdog - INFO - Running initial scan on watched folder...
2022-07-17 18:06:36,176 - octoprint.server.util.watchdog - INFO - ... initial scan done.
2022-07-17 18:06:36,176 - octoprint.util.comm - INFO - Serial detection: Performing autodetection with 4 port/baudrate candidates: COM1@115200, COM1@250000, COM3@115200, COM3@250000
2022-07-17 18:06:36,176 - octoprint.util.comm - INFO - Serial detection: Trying port COM1, baudrate 115200
2022-07-17 18:06:36,176 - octoprint.util.comm - INFO - Connecting to port COM1, baudrate 115200
2022-07-17 18:06:36,207 - octoprint.util.comm - INFO - Serial detection: Handshake attempt #1 with timeout 2.0s
2022-07-17 18:06:36,207 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2022-07-17 18:06:36,848 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2022-07-17 18:06:37,005 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance on LenovoE8400._http._tcp.local.' for _http._tcp.local.
2022-07-17 18:06:37,832 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance on LenovoE8400._octoprint._tcp.local.' for _octoprint._tcp.local.
2022-07-17 18:06:37,832 - octoprint.server - INFO - Listening on http://0.0.0.0:5000 and http://[::]:5000
2022-07-17 18:06:37,832 - octoprint.plugins.discovery - INFO - Registered OctoPrint instance on LenovoE8400 for SSDP
2022-07-17 18:06:37,880 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2022-07-17 18:06:38,207 - octoprint.util.comm - INFO - Serial detection: Handshake attempt #2 with timeout 2.0s
2022-07-17 18:06:38,207 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2022-07-17 18:06:38,457 - octoprint.util.pip - INFO - Using "c:\octoprint\venv\scripts\python.exe -m pip" as command to invoke pip
2022-07-17 18:06:38,457 - octoprint.util.pip - INFO - pip installs to c:\octoprint\venv\Lib\site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2022-07-17 18:06:38,457 - octoprint.util.pip - INFO - ==> pip ok -> yes
2022-07-17 18:06:38,457 - octoprint.plugins.softwareupdate - INFO - Minimum free storage across all update relevant locations is 217.2GB. That is considered sufficient for updating.
2022-07-17 18:06:38,661 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'printer_state': 'DETECT_SERIAL', 'octoprint_uptime': 5}
2022-07-17 18:06:38,755 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2022-07-17 18:06:38,769 - octoprint.plugins.tracking - INFO - Sent tracking event startup, payload: {u'python': '2.7.14', u'os': u'windows', u'ram': 6135529472L, u'version': u'1.6.1', u'pip': '20.2.4', u'cores': 2, u'freq': 3000.0, u'bits': 32}
2022-07-17 18:06:38,894 - octoprint.plugins.tracking - INFO - Sent tracking event pong, payload: {u'python': '2.7.14', u'bits': 32, u'ram': 6135529472L, u'version': u'1.6.1', u'plugins': u'', u'pip': '20.2.4', u'cores': 2, u'freq': 3000.0, u'os': u'windows'}
2022-07-17 18:06:40,223 - octoprint.util.comm - INFO - Serial detection: Handshake attempt #3 with timeout 2.0s
2022-07-17 18:06:40,223 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2022-07-17 18:06:42,223 - octoprint.util.comm - INFO - Serial detection: Trying port COM1, baudrate 250000
2022-07-17 18:06:42,223 - octoprint.util.comm - ERROR - Unexpected error while setting baudrate 250000
File "c:\octoprint\venv\lib\site-packages\octoprint\util\comm.py", line 3277, in _perform_detection_step
self._serial.baudrate = b
File "c:\octoprint\venv\lib\site-packages\serial\serialutil.py", line 295, in baudrate
self._reconfigure_port()
File "c:\octoprint\venv\lib\site-packages\serial\serialwin32.py", line 222, in _reconfigure_port
'Original message: {!r}'.format(ctypes.WinError()))
SerialException: Cannot configure port, something went wrong. Original message: WindowsError(87, 'Forkert parameter.')
2022-07-17 18:06:42,223 - octoprint.util.comm - INFO - Serial detection: Trying port COM3, baudrate 115200
2022-07-17 18:06:42,223 - octoprint.util.comm - INFO - Connecting to port COM3, baudrate 115200
2022-07-17 18:06:42,286 - octoprint.util.comm - INFO - Serial detection: Handshake attempt #1 with timeout 2.0s
2022-07-17 18:06:42,301 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2022-07-17 18:06:43,191 - octoprint.util.comm - INFO - Changing monitoring state from "Detecting serial connection" to "Operational"
2022-07-17 18:06:43,207 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2022-07-17 18:06:44,036 - octoprint.util.comm - INFO - Printer reports firmware name "Marlin 1.1.9_B7 TM3D SSMDNB"
2022-07-17 18:06:44,051 - octoprint.util.comm - INFO - Firmware states that it supports temperature autoreporting
2022-07-17 18:06:44,066 - octoprint.util.comm - INFO - Firmware states that it supports emergency GCODEs to be sent without waiting for an acknowledgement first
2022-07-17 18:06:44,066 - octoprint.util.comm - INFO - Firmware states that it supports sd status autoreporting
2022-07-17 18:06:44,161 - octoprint.plugins.tracking - INFO - Sent tracking event printer_connected, payload: {u'printer_baudrate': 0, u'printer_port': None, u'firmware_name': u'Marlin 1.1.9_B7 TM3D SSMDNB'}
The printer is sounding like it's 'rebooted' but nothing happens - normally the OctoPrint-server tels me how many seconds is spend on the startup - but nothing comes up after the last line abowe.
What to do ?
