Octoprint server wont start after updating Windows
After updating Windows 10 to the latest version my OctPrint-server wont start
Re-booted several times
Yes, but only the black CMD-windows comes up for a short time and then disappears again
It's completely NON SENCE to me how to get this "Systeminfo Bundle" !
I get this when I try to start the OctoPrint server:
2022-07-17 18:06:31,957 - octoprint.startup - INFO - ******************************************************************************
2022-07-17 18:06:31,957 - octoprint.startup - INFO - Starting OctoPrint 1.6.1
2022-07-17 18:06:32,255 - octoprint.util.connectivity.connectivity_checker - INFO - Connectivity changed from offline to online
2022-07-17 18:06:32,316 - octoprint.util.connectivity.connectivity_checker - INFO - Connectivity state is currently: online
2022-07-17 18:06:32,316 - octoprint.util.connectivity.connectivity_checker - INFO - Connecting to 1.1.1.1:53 is working
2022-07-17 18:06:32,316 - octoprint.util.connectivity.connectivity_checker - INFO - Resolving octoprint.org is working
2022-07-17 18:06:32,332 - octoprint.startup - INFO - Blacklist processing done, adding 12 blacklisted plugin versions: roomtemp (any), GcodeEditor (0.1.1), GcodeEditor (0.2.0), GcodeEditor (0.2.1), GcodeEditor (0.2.2), GcodeEditor (0.2.3), GcodeEditor (0.2.4), GcodeEditor (0.2.5), GcodeEditor (0.2.6), GcodeEditor (0.2.8), gcodeleveling (0.1.0), gcodeleveling (0.1.1)
2022-07-17 18:06:32,364 - octoprint.plugin.core - INFO - Loading plugins from c:\octoprint\venv\lib\site-packages\octoprint\plugins, C:\Users\kelds\AppData\Roaming\OctoPrint\plugins and installed plugin packages...
2022-07-17 18:06:33,426 - octoprint.plugin.core - INFO - Plugin Pi Support Plugin (2021.3.26.post2) did not pass check, not loading.
2022-07-17 18:06:33,505 - octoprint.plugin.core - INFO - Found 16 plugin(s) providing 16 mixin implementations, 32 hook handlers
2022-07-17 18:06:33,582 - octoprint.server.heartbeat - INFO - Starting server heartbeat, 900.0s interval
2022-07-17 18:06:33,894 - octoprint.server - INFO - Intermediary server started
2022-07-17 18:06:33,911 - octoprint.filemanager.storage - INFO - Initializing the file metadata for C:\Users\kelds\AppData\Roaming\OctoPrint\uploads...
2022-07-17 18:06:34,114 - octoprint.filemanager.storage - INFO - ... file metadata for C:\Users\kelds\AppData\Roaming\OctoPrint\uploads initialized successfully.
2022-07-17 18:06:34,114 - octoprint.server - INFO - Added new permission from plugin action_command_notification: PLUGIN_ACTION_COMMAND_NOTIFICATION_SHOW (needs: u"Need(method='role', value=u'plugin_action_command_notification_show')")
2022-07-17 18:06:34,114 - octoprint.server - INFO - Added new permission from plugin action_command_notification: PLUGIN_ACTION_COMMAND_NOTIFICATION_CLEAR (needs: u"Need(method='role', value=u'plugin_action_command_notification_clear')")
2022-07-17 18:06:34,130 - octoprint.server - INFO - Added new permission from plugin action_command_prompt: PLUGIN_ACTION_COMMAND_PROMPT_INTERACT (needs: u"Need(method='role', value=u'plugin_action_command_prompt_interact')")
2022-07-17 18:06:34,130 - octoprint.server - INFO - Added new permission from plugin announcements: PLUGIN_ANNOUNCEMENTS_READ (needs: u"Need(method='role', value=u'plugin_announcements_read')")
2022-07-17 18:06:34,130 - octoprint.server - INFO - Added new permission from plugin announcements: PLUGIN_ANNOUNCEMENTS_MANAGE (needs: u"Need(method='role', value=u'plugin_announcements_manage'), Need(method='role', value=u'plugin_announcements_read')")
2022-07-17 18:06:34,130 - octoprint.server - INFO - Added new permission from plugin appkeys: PLUGIN_APPKEYS_ADMIN (needs: u"Need(method='role', value=u'plugin_appkeys_admin')")
2022-07-17 18:06:34,130 - octoprint.server - INFO - Added new permission from plugin backup: PLUGIN_BACKUP_ACCESS (needs: u"Need(method='role', value=u'plugin_backup_access')")
2022-07-17 18:06:34,130 - octoprint.server - INFO - Added new permission from plugin firmware_check: PLUGIN_FIRMWARE_CHECK_DISPLAY (needs: u"Need(method='role', value=u'plugin_firmware_check_display')")
2022-07-17 18:06:34,130 - octoprint.server - INFO - Added new permission from plugin logging: PLUGIN_LOGGING_MANAGE (needs: u"Need(method='role', value=u'plugin_logging_manage')")
2022-07-17 18:06:34,130 - octoprint.server - INFO - Added new permission from plugin pluginmanager: PLUGIN_PLUGINMANAGER_MANAGE (needs: u"Need(method='role', value=u'plugin_pluginmanager_manage')")
2022-07-17 18:06:34,130 - octoprint.server - INFO - Added new permission from plugin pluginmanager: PLUGIN_PLUGINMANAGER_INSTALL (needs: u"Need(method='role', value=u'plugin_pluginmanager_install'), Need(method='role', value=u'plugin_pluginmanager_manage')")
2022-07-17 18:06:34,130 - octoprint.server - INFO - Added new permission from plugin softwareupdate: PLUGIN_SOFTWAREUPDATE_CHECK (needs: u"Need(method='role', value=u'plugin_softwareupdate_check')")
2022-07-17 18:06:34,130 - octoprint.server - INFO - Added new permission from plugin softwareupdate: PLUGIN_SOFTWAREUPDATE_UPDATE (needs: u"Need(method='role', value=u'plugin_softwareupdate_update')")
2022-07-17 18:06:34,130 - octoprint.server - INFO - Added new permission from plugin softwareupdate: PLUGIN_SOFTWAREUPDATE_CONFIGURE (needs: u"Need(method='role', value=u'plugin_softwareupdate_configure')")
2022-07-17 18:06:34,191 - octoprint.plugins.softwareupdate - INFO - Loaded version cache from disk
2022-07-17 18:06:34,707 - octoprint.util.pip - INFO - Using "c:\octoprint\venv\scripts\python.exe -m pip" as command to invoke pip
2022-07-17 18:06:35,191 - octoprint.util.pip - INFO - Version of pip is 20.2.4
2022-07-17 18:06:35,191 - octoprint.util.pip - INFO - pip installs to c:\octoprint\venv\Lib\site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2022-07-17 18:06:35,207 - octoprint.util.pip - INFO - ==> pip ok -> yes
2022-07-17 18:06:35,207 - octoprint.plugin.core - INFO - Initialized 16 plugin implementation(s)
2022-07-17 18:06:35,207 - octoprint.plugin.core - INFO - 16 plugin(s) registered with the system:
|  Action Command Notification Support (bundled) = c:\octoprint\venv\lib\site-packages\octoprint\plugins\action_command_notification
|  Action Command Prompt Support (bundled) = c:\octoprint\venv\lib\site-packages\octoprint\plugins\action_command_prompt
|  Announcement Plugin (bundled) = c:\octoprint\venv\lib\site-packages\octoprint\plugins\announcements
|  Anonymous Usage Tracking (bundled) = c:\octoprint\venv\lib\site-packages\octoprint\plugins\tracking
|  Application Keys Plugin (bundled) = c:\octoprint\venv\lib\site-packages\octoprint\plugins\appkeys
|  Backup & Restore (bundled) = c:\octoprint\venv\lib\site-packages\octoprint\plugins\backup
|  Core Wizard (bundled) = c:\octoprint\venv\lib\site-packages\octoprint\plugins\corewizard
|  Discovery (bundled) = c:\octoprint\venv\lib\site-packages\octoprint\plugins\discovery
|  Error Tracking (bundled) = c:\octoprint\venv\lib\site-packages\octoprint\plugins\errortracking
|  File Check (2021.2.23) (bundled) = c:\octoprint\venv\lib\site-packages\octoprint_file_check
|  Firmware Check (2021.5.31) (bundled) = c:\octoprint\venv\lib\site-packages\octoprint_firmware_check
|  GCode Viewer (bundled) = c:\octoprint\venv\lib\site-packages\octoprint\plugins\gcodeviewer
|  Logging (bundled) = c:\octoprint\venv\lib\site-packages\octoprint\plugins\logging
|  Plugin Manager (bundled) = c:\octoprint\venv\lib\site-packages\octoprint\plugins\pluginmanager
|  Software Update (bundled) = c:\octoprint\venv\lib\site-packages\octoprint\plugins\softwareupdate
|  Virtual Printer (bundled) = c:\octoprint\venv\lib\site-packages\octoprint\plugins\virtual_printer
Prefix legend: ! = disabled, # = blacklisted, * = incompatible
2022-07-17 18:06:35,223 - octoprint.environment - INFO - Detected environment is Python 2.7.14 under Windows (win32). Details:
|  hardware:
|    cores: 2
|    freq: 3000.0
|    ram: 6135529472
|  os:
|    bits: 32
|    platform: win32
|  python:
|    pip: 20.2.4
|    version: 2.7.14
|    virtualenv: c:\octoprint\venv
2022-07-17 18:06:35,223 - octoprint.server - INFO - Reset webasset folder C:\Users\kelds\AppData\Roaming\OctoPrint\generated\webassets...
2022-07-17 18:06:35,223 - octoprint.server - INFO - Reset webasset folder C:\Users\kelds\AppData\Roaming\OctoPrint\generated\.webassets-cache...
2022-07-17 18:06:35,598 - octoprint.server - INFO - Shutting down intermediary server...
2022-07-17 18:06:35,926 - octoprint.server - INFO - Intermediary server shut down
2022-07-17 18:06:35,926 - octoprint.events - INFO - Processing startup event, this is our first event
2022-07-17 18:06:35,926 - octoprint.events - INFO - Adding 1 events to queue that were held back before startup event
2022-07-17 18:06:35,926 - octoprint.filemanager - INFO - Adding backlog items from all storage types to analysis queue...
2022-07-17 18:06:35,926 - octoprint.server - INFO - Autoconnect on startup is configured, trying to connect to the printer...
2022-07-17 18:06:35,957 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2022-07-17 18:06:35,957 - octoprint.plugins.softwareupdate - INFO - Fetching check overlays from https://plugins.octoprint.org/update_check_overlay.json
2022-07-17 18:06:35,957 - octoprint.filemanager - INFO - Added 0 items from storage type "local" to analysis queue
2022-07-17 18:06:36,036 - octoprint.server - INFO - Trying to connect to configured serial port None
2022-07-17 18:06:36,114 - octoprint.plugins.softwareupdate - INFO - Fetching check overlays from https://plugins.octoprint.org/update_check_overlay_py2.json
2022-07-17 18:06:36,161 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Detecting serial connection"
2022-07-17 18:06:36,176 - octoprint.server.util.watchdog - INFO - Running initial scan on watched folder...
2022-07-17 18:06:36,176 - octoprint.server.util.watchdog - INFO - ... initial scan done.
2022-07-17 18:06:36,176 - octoprint.util.comm - INFO - Serial detection: Performing autodetection with 4 port/baudrate candidates: COM1@115200, COM1@250000, COM3@115200, COM3@250000
2022-07-17 18:06:36,176 - octoprint.util.comm - INFO - Serial detection: Trying port COM1, baudrate 115200
2022-07-17 18:06:36,176 - octoprint.util.comm - INFO - Connecting to port COM1, baudrate 115200
2022-07-17 18:06:36,207 - octoprint.util.comm - INFO - Serial detection: Handshake attempt #1 with timeout 2.0s
2022-07-17 18:06:36,207 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2022-07-17 18:06:36,848 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2022-07-17 18:06:37,005 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance on LenovoE8400._http._tcp.local.' for _http._tcp.local.
2022-07-17 18:06:37,832 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance on LenovoE8400._octoprint._tcp.local.' for _octoprint._tcp.local.
2022-07-17 18:06:37,832 - octoprint.server - INFO - Listening on http://0.0.0.0:5000 and http://[::]:5000
2022-07-17 18:06:37,832 - octoprint.plugins.discovery - INFO - Registered OctoPrint instance on LenovoE8400 for SSDP
2022-07-17 18:06:37,880 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2022-07-17 18:06:38,207 - octoprint.util.comm - INFO - Serial detection: Handshake attempt #2 with timeout 2.0s
2022-07-17 18:06:38,207 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2022-07-17 18:06:38,457 - octoprint.util.pip - INFO - Using "c:\octoprint\venv\scripts\python.exe -m pip" as command to invoke pip
2022-07-17 18:06:38,457 - octoprint.util.pip - INFO - pip installs to c:\octoprint\venv\Lib\site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2022-07-17 18:06:38,457 - octoprint.util.pip - INFO - ==> pip ok -> yes
2022-07-17 18:06:38,457 - octoprint.plugins.softwareupdate - INFO - Minimum free storage across all update relevant locations is 217.2GB. That is considered sufficient for updating.
2022-07-17 18:06:38,661 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'printer_state': 'DETECT_SERIAL', 'octoprint_uptime': 5}
2022-07-17 18:06:38,755 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2022-07-17 18:06:38,769 - octoprint.plugins.tracking - INFO - Sent tracking event startup, payload: {u'python': '2.7.14', u'os': u'windows', u'ram': 6135529472L, u'version': u'1.6.1', u'pip': '20.2.4', u'cores': 2, u'freq': 3000.0, u'bits': 32}
2022-07-17 18:06:38,894 - octoprint.plugins.tracking - INFO - Sent tracking event pong, payload: {u'python': '2.7.14', u'bits': 32, u'ram': 6135529472L, u'version': u'1.6.1', u'plugins': u'', u'pip': '20.2.4', u'cores': 2, u'freq': 3000.0, u'os': u'windows'}
2022-07-17 18:06:40,223 - octoprint.util.comm - INFO - Serial detection: Handshake attempt #3 with timeout 2.0s
2022-07-17 18:06:40,223 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2022-07-17 18:06:42,223 - octoprint.util.comm - INFO - Serial detection: Trying port COM1, baudrate 250000
2022-07-17 18:06:42,223 - octoprint.util.comm - ERROR - Unexpected error while setting baudrate 250000
  File "c:\octoprint\venv\lib\site-packages\octoprint\util\comm.py", line 3277, in _perform_detection_step
    self._serial.baudrate = b
  File "c:\octoprint\venv\lib\site-packages\serial\serialutil.py", line 295, in baudrate
    self._reconfigure_port()
  File "c:\octoprint\venv\lib\site-packages\serial\serialwin32.py", line 222, in _reconfigure_port
    'Original message: {!r}'.format(ctypes.WinError()))
SerialException: Cannot configure port, something went wrong. Original message: WindowsError(87, 'Forkert parameter.')
2022-07-17 18:06:42,223 - octoprint.util.comm - INFO - Serial detection: Trying port COM3, baudrate 115200
2022-07-17 18:06:42,223 - octoprint.util.comm - INFO - Connecting to port COM3, baudrate 115200
2022-07-17 18:06:42,286 - octoprint.util.comm - INFO - Serial detection: Handshake attempt #1 with timeout 2.0s
2022-07-17 18:06:42,301 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2022-07-17 18:06:43,191 - octoprint.util.comm - INFO - Changing monitoring state from "Detecting serial connection" to "Operational"
2022-07-17 18:06:43,207 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2022-07-17 18:06:44,036 - octoprint.util.comm - INFO - Printer reports firmware name "Marlin 1.1.9_B7 TM3D SSMDNB"
2022-07-17 18:06:44,051 - octoprint.util.comm - INFO - Firmware states that it supports temperature autoreporting
2022-07-17 18:06:44,066 - octoprint.util.comm - INFO - Firmware states that it supports emergency GCODEs to be sent without waiting for an acknowledgement first
2022-07-17 18:06:44,066 - octoprint.util.comm - INFO - Firmware states that it supports sd status autoreporting
2022-07-17 18:06:44,161 - octoprint.plugins.tracking - INFO - Sent tracking event printer_connected, payload: {u'printer_baudrate': 0, u'printer_port': None, u'firmware_name': u'Marlin 1.1.9_B7 TM3D SSMDNB'}
The printer is sounding like it's 'rebooted' but nothing happens - normally the OctoPrint-server tels me how many seconds is spend on the startup - but nothing comes up after the last line abowe.
What to do ?
It looks like it's starting OK to me, there's no errors there.
I assume you tried accessing the UI in the browser and that didn't work? Do you get any errors there?
Yeah, I try to access the server from Firefox but it never starts ... no errors just a white screen !
I'll try to shut ALL my network OFF and then boot again !
I intent to UPDATE the OctoPrint server WHEN I get it to run - should that give me any issues :frowning: ?
The server end looks to be coming up, so that's probably OK.
The issue is possibly with firefox so the first thing to do is to clear FF's caches.
With firefox open press the CTRL SHIFT DEL keys at the same time
A 'Clear data' dialog will open
Make sure that clear cache option is selected, you can leave the rest unticked
Click on OK
Close and reopen firefox and see if it's fixed
A total shut down and restart did the job !
Should I UPDATE to the latest version of OctoPrint - I'm afraid it'll give me problems - no BIG news to get - right ?
There's nothing to be afraid of :slightly_smiling_face:
OctoPrint is well tested on Windows - most active contributors develop on Windows. And if you have problems, we can sort them out.
Although having said that - you will not be able to install the latest version on your system. OctoPrint no longer supports Python 2, you will require 3.7 or higher to run it now.
OK, then I need to update to Python 3.7 too - should that give problems ?
Ooooh, I see I have 4 packs concerning something about Python - should they ALL be updated:
billede
You can use Python 3.9.6, that should work fine. Python versions can only be updated on minor versions, and you can have more than one version installed alongside each other.
When following the install guide, you may have to specify which version of Python to use.
Try running py --version and see what the result is. If it reports the 3.6.9 version, you are good. You can also try py -3 to specifically ask for Python 3. You will then need to recreate the virtual environment as set out in the install guide above to reinstall OctoPrint.
THX to all of you for your advice and time, but I think I'll stick to my setup till I'm forced to update - it's simply TOO 'noisy' ... if you know what I mean !
I like the KISS method - keep it stupidly simple and all about OctoPrint is NOT simple - sorry to say !
