I have been unable to install either update from 1.10.0 to 10.1 or 10.2. In every case it gives me a warning popup that states "Update failed!" and tells me what logs to consult:
octoprint.log
plugin_softwareupdate_console.log
I looked at the logs, and the error message in the installation window, but couldn't decipher what the actual error was.
Some things to note:
I no longer use OctoPrint to manage the actual print loading and gcode loading. I use PrusaSlicer 2.7.4 to talk to my Prusa MK4. I still make use of the camera monitoring, though. The only reason I stopped using OctoPrint is that the PrusaSlicer seems to give me better control of the actual print functions. I'm completely fed up with the PrusaConnect application, and just wish that I could use OctoPrint for everything.
Also, you should be aware that I'm using the OctoPrint Raspberry Pi as an MQTT broker as well. I don't know if this is the source of the issue.
I have tried updating with the printer off and on, while printing and between prints. No luck.
Yes.
No. I'm still unable to install the update.
I've included the System Information bundle.
OctoPrint 1.10.0
Python 3.7.3
OctoPi* 0.18.0 (build 2022.05.24.101555)
Windows 11 Pro, Firefox browser
Octoprint v 1.10.2 install error.zip (1.6 KB)
octoprint-logs.zip (987.6 KB)
octoprint-systeminfo-20240625212827.zip (160.8 KB)
