Octoprint Update not started! The update could not be started. Is it already active? Please consult octoprint.log for details
octoprint works to control ender 3 and print from pc
but if i try to update or download plugin eg astro clould i get message " Update not started!
The update could not be started. Is it already active? Please consult octoprint.log for details."
i have tried 2 different sd cards and different power leads and 2amp plugs
i get a flashing red light and green flashes to
i have had octopi save time lapse videos and run printer fine though
didnt make difference
no
browser.user_agent : Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/91.0.4472.124 Safari/537.36 Edg/91.0.864.64
connectivity.connection_check : 8.8.8.8:53
connectivity.connection_ok : true
connectivity.enabled : true
connectivity.online : true
connectivity.resolution_check : octoprint.org
connectivity.resolution_ok : true
env.hardware.cores : 4
env.hardware.freq : 1200
env.hardware.ram : 915722240
env.os.bits : 32
env.os.id : linux
env.os.platform : linux
env.plugins.pi_support.model : Raspberry Pi 3 Model B Rev 1.2
env.plugins.pi_support.octopi_version : 0.18.0
env.plugins.pi_support.throttle_state : 0x50005
env.python.pip : 20.3.3
env.python.version : 3.7.3
env.python.virtualenv : true
octoprint.safe_mode : false
octoprint.version : 1.5.2
not sure if red light flashing on pi is good or bad
no power low etc on dashboad/webpage
please im desprate
Hello @jace !
You have an undervoltage and throtteling issue:
As long this persists, you can't update anything.
does this need a bigger power supply and what to do about throtteling ?
Depends on what you are using now. Bigger is not always better.
But always take care not to use a charger.
For a Pi 3B you need a power supply at least with 5.2V and 2.5A
The throtteling in this case is a result of the undervoltage issue
Using a samsung 2 amp plug and a lead but ordered a 3a pi power lead
just an update
new power supply and red light is on constantly and updates great
power supply needs more than a phone charger
thanks for help Ewald_Ikemann
