Octoprint via 3G/LTE modem
Hello!
I am new in this one and have the following question
What if I have a printer far away from home without WiFi and I want to connect Raspberry Pi via 3g/LTE modem, what are the configurations then? Is this even possible with Octoprint? What PlugIns do I need to use? I can't find the information about that.
Thanks in advance and have a nice prints:)
In the times when I do a talk and bring my printer then I create a hotspot on my iPhone and connect to that. It helps if the phone has power the entire time, though.
I've had no problem doing that, but I needed to use a 4G modem (not a dongle, because the dongle doesn't have port forwarding capabilities) and then I used Dynamic DNS to access the 4G Modem externally. I even set up the Pi to automatically update the IP address used by the DNS provider.
Over the last twelve months we've spent a lot of effort educating users against simple port forwarding to make their 3D printers available on the Internet.
A Guide to Safe Remote Access of OctoPrint
Accessing your OctoPrint remotely
Restrict Access to OctoPi Utilizing SSL Client Certificates
A Guide To Safe Remote Access of OctoPrint (outside of forum)
Listen to the the voice of experience from OutsurcedGuru and not me (a newbie).
I have now read the advice here and it is very sound. Octoprint do not advise opening up your network to the world by port forwarding, and I agree. I'm going to change my setup and use one of the recommended options instead.
Thanks OutsourcedGuru.
If you do, though, at least add the SSL client certificate and make the server enforce that.
  • port forwarding +
  • forcing any client to be in the client certificate list +
  • dynamic DNS = remote solution
But if you don't do that middle part then it's dangerous and you end up on that compromised list of OctoPrint installs.
