This afternoon, I updated TouchUI and restarted.  When OctoPrint should have come back up, it didn't.
- Tried full restart of RasPi
- Tried executing "ps -ef | grep -i octoprint | grep -i python" - no echo produced
- Examined octoprint.log. Didn't see anything since reboot so renamed it and restarted RasPi again. It did not create a new log so seemingly OctoPrint isn't even trying to start
- Executed "sudo service octoprint restart" then with no change tried "sudo service octoprint start" - no change to above nor log created
- Executed "sudo apt-get update && sudo apt-get upgrade"
Here's the last part I have which starts at TouchUI update.  Again, nothing new appended after RasPi restart so at a loss...
2020-03-12 16:21:45,749 - octoprint.plugins.softwareupdate - INFO - Starting update of touchui to 0.3.14...
2020-03-12 16:21:51,231 - octoprint.plugins.softwareupdate - INFO - Update of touchui to 0.3.14 successful!
2020-03-12 16:21:51,237 - octoprint.plugins.pushover - INFO - Got an event: plugin_softwareupdate_update_succeeded Payload: {'to_version': u'0.3.14', 'from_version': '0.3.13', 'target': u'touchui'}
2020-03-12 16:21:55,064 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.0.25) 16.79ms
2020-03-12 16:22:05,053 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.0.25) 10.40ms
2020-03-12 16:22:15,053 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.0.25) 11.00ms
2020-03-12 16:22:25,054 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.0.25) 10.42ms
2020-03-12 16:22:35,056 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.0.25) 11.82ms
2020-03-12 16:22:37,113 - octoprint.plugins.thespaghettidetective - ERROR - Server websocket is closing
2020-03-12 16:22:45,055 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.0.25) 11.69ms
2020-03-12 16:22:55,056 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.0.25) 11.78ms
2020-03-12 16:23:05,055 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.0.25) 11.64ms
2020-03-12 16:23:15,056 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.0.25) 12.26ms
2020-03-12 16:23:25,059 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.0.25) 13.65ms
2020-03-12 16:23:35,057 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.0.25) 12.37ms
2020-03-12 16:23:45,056 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.0.25) 11.43ms
2020-03-12 16:23:46,921 - octoprint.plugins.thespaghettidetective - ERROR - Server websocket is closing
2020-03-12 16:23:51,067 - octoprint.plugins.thespaghettidetective - ERROR - Backing off 0.290379 seconds: Failed to connect to websocket server
2020-03-12 16:23:51,578 - octoprint.plugins.thespaghettidetective - ERROR - Backing off 0.613483 seconds: Failed to connect to websocket server
2020-03-12 16:23:52,391 - octoprint.plugins.thespaghettidetective - ERROR - Backing off 1.024404 seconds: Failed to connect to websocket server
2020-03-12 16:23:53,643 - octoprint.plugins.thespaghettidetective - ERROR - Backing off 2.167075 seconds: Failed to connect to websocket server
2020-03-12 16:23:55,060 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.0.25) 13.92ms
2020-03-12 16:23:55,548 - octoprint.plugins.thespaghettidetective - ERROR - Server websocket is closing
2020-03-12 16:23:58,038 - octoprint.plugins.thespaghettidetective - ERROR - Backing off 5.152510 seconds: Failed to connect to websocket server
2020-03-12 16:24:03,442 - octoprint.plugins.thespaghettidetective - ERROR - Backing off 8.987950 seconds: Failed to connect to websocket server
2020-03-12 16:24:05,061 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.0.25) 13.71ms
2020-03-12 16:24:12,684 - octoprint.plugins.thespaghettidetective - ERROR - Backing off 22.865755 seconds: Failed to connect to websocket server
2020-03-12 16:24:15,060 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.0.25) 13.46ms
2020-03-12 16:24:25,078 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.0.25) 11.72ms
2020-03-12 16:24:34,015 - octoprint.plugins.thespaghettidetective - ERROR - Server websocket is closing
2020-03-12 16:24:35,072 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.0.25) 25.74ms
2020-03-12 16:24:35,934 - octoprint.plugins.thespaghettidetective - ERROR - Server websocket is closing
2020-03-12 16:24:37,801 - octoprint.plugins.thespaghettidetective - ERROR - Backing off 35.158121 seconds: Failed to connect to websocket server
2020-03-12 16:24:45,057 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.0.25) 11.47ms
2020-03-12 16:24:55,055 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.0.25) 10.24ms
2020-03-12 16:25:05,060 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.0.25) 12.55ms
2020-03-12 16:25:15,059 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.0.25) 12.57ms
2020-03-12 16:25:15,202 - octoprint.plugins.thespaghettidetective - ERROR - Backing off 44.477482 seconds: Failed to connect to websocket server
2020-03-12 16:25:25,057 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.0.25) 10.67ms
2020-03-12 16:25:25,331 - octoprint.server.util.flask - INFO - Passively logging in user bzowk from ::ffff:192.168.0.25
2020-03-12 16:25:25,332 - octoprint.access.users - INFO - Logged in user: bzowk
2020-03-12 16:25:25,364 - octoprint.plugins.pushover - INFO - Got an event: UserLoggedIn Payload: {'username': 'bzowk'}
2020-03-12 16:25:28,477 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.0.25
2020-03-12 16:25:28,480 - octoprint.plugins.pushover - INFO - Got an event: ClientClosed Payload: {u'remoteAddress': u'::ffff:192.168.0.25'}
2020-03-12 16:25:28,570 - octoprint.server.util.flask - INFO - Passively logging in user bzowk from ::ffff:192.168.0.25
2020-03-12 16:25:28,571 - octoprint.access.users - INFO - Logged in user: bzowk
2020-03-12 16:25:28,581 - octoprint.plugins.pushover - INFO - Got an event: UserLoggedIn Payload: {'username': 'bzowk'}
2020-03-12 16:25:29,247 - octoprint.plugins.PrintJobHistory.DatabaseManager.SQL - DEBUG - ('SELECT "t1"."databaseId", "t1"."created", "t1"."userName", "t1"."fileOrigin", "t1"."fileName", "t1"."filePathName", "t1"."fileSize", "t1"."printStartDateTime", "t1"."printEndDateTime", "t1"."duration", "t1"."printStatusResult", "t1"."noteText", "t1"."noteDeltaFormat", "t1"."noteHtml", "t1"."printedLayers", "t1"."printedHeight" FROM "pjh_printjobmodel" AS "t1" ORDER BY "t1"."printStartDateTime" DESC LIMIT ? OFFSET ?', [10, 0])
2020-03-12 16:25:29,254 - octoprint.plugins.PrintJobHistory.DatabaseManager.SQL - DEBUG - ('SELECT "t1"."databaseId", "t1"."created", "t1"."printJob_id", "t1"."profileVendor", "t1"."diameter", "t1"."density", "t1"."material", "t1"."spoolName", "t1"."spoolCost", "t1"."spoolCostUnit", "t1"."spoolWeight", "t1"."usedLength", "t1"."calculatedLength", "t1"."usedWeight", "t1"."usedCost" FROM "pjh_filamentmodel" AS "t1" WHERE ("t1"."printJob_id" = ?)', [22])
2020-03-12 16:25:29,260 - octoprint.plugins.PrintJobHistory.DatabaseManager.SQL - DEBUG - ('SELECT "t1"."databaseId", "t1"."created", "t1"."printJob_id", "t1"."sensorName", "t1"."sensorValue" FROM "pjh_temperaturemodel" AS "t1" WHERE ("t1"."printJob_id" = ?)', [22])
2020-03-12 16:25:29,267 - octoprint.plugins.PrintJobHistory.DatabaseManager.SQL - DEBUG - ('SELECT "t1"."databaseId", "t1"."created", "t1"."printJob_id", "t1"."profileVendor", "t1"."diameter", "t1"."density", "t1"."material", "t1"."spoolName", "t1"."spoolCost", "t1"."spoolCostUnit", "t1"."spoolWeight", "t1"."usedLength", "t1"."calculatedLength", "t1"."usedWeight", "t1"."usedCost" FROM "pjh_filamentmodel" AS "t1" WHERE ("t1"."printJob_id" = ?)', [21])
2020-03-12 16:25:29,272 - octoprint.plugins.PrintJobHistory.DatabaseManager.SQL - DEBUG - ('SELECT "t1"."databaseId", "t1"."created", "t1"."printJob_id", "t1"."sensorName", "t1"."sensorValue" FROM "pjh_temperaturemodel" AS "t1" WHERE ("t1"."printJob_id" = ?)', [21])
2020-03-12 16:25:29,279 - octoprint.plugins.PrintJobHistory.DatabaseManager.SQL - DEBUG - ('SELECT "t1"."databaseId", "t1"."created", "t1"."printJob_id", "t1"."profileVendor", "t1"."diameter", "t1"."density", "t1"."material", "t1"."spoolName", "t1"."spoolCost", "t1"."spoolCostUnit", "t1"."spoolWeight", "t1"."usedLength", "t1"."calculatedLength", "t1"."usedWeight", "t1"."usedCost" FROM "pjh_filamentmodel" AS "t1" WHERE ("t1"."printJob_id" = ?)', [20])
2020-03-12 16:25:29,284 - octoprint.plugins.PrintJobHistory.DatabaseManager.SQL - DEBUG - ('SELECT "t1"."databaseId", "t1"."created", "t1"."printJob_id", "t1"."sensorName", "t1"."sensorValue" FROM "pjh_temperaturemodel" AS "t1" WHERE ("t1"."printJob_id" = ?)', [20])
2020-03-12 16:25:29,292 - octoprint.plugins.PrintJobHistory.DatabaseManager.SQL - DEBUG - ('SELECT "t1"."databaseId", "t1"."created", "t1"."printJob_id", "t1"."profileVendor", "t1"."diameter", "t1"."density", "t1"."material", "t1"."spoolName", "t1"."spoolCost", "t1"."spoolCostUnit", "t1"."spoolWeight", "t1"."usedLength", "t1"."calculatedLength", "t1"."usedWeight", "t1"."usedCost" FROM "pjh_filamentmodel" AS "t1" WHERE ("t1"."printJob_id" = ?)', [19])
2020-03-12 16:25:29,297 - octoprint.plugins.PrintJobHistory.DatabaseManager.SQL - DEBUG - ('SELECT "t1"."databaseId", "t1"."created", "t1"."printJob_id", "t1"."sensorName", "t1"."sensorValue" FROM "pjh_temperaturemodel" AS "t1" WHERE ("t1"."printJob_id" = ?)', [19])
2020-03-12 16:25:29,304 - octoprint.plugins.PrintJobHistory.DatabaseManager.SQL - DEBUG - ('SELECT "t1"."databaseId", "t1"."created", "t1"."printJob_id", "t1"."profileVendor", "t1"."diameter", "t1"."density", "t1"."material", "t1"."spoolName", "t1"."spoolCost", "t1"."spoolCostUnit", "t1"."spoolWeight", "t1"."usedLength", "t1"."calculatedLength", "t1"."usedWeight", "t1"."usedCost" FROM "pjh_filamentmodel" AS "t1" WHERE ("t1"."printJob_id" = ?)', [18])
2020-03-12 16:25:29,309 - octoprint.plugins.PrintJobHistory.DatabaseManager.SQL - DEBUG - ('SELECT "t1"."databaseId", "t1"."created", "t1"."printJob_id", "t1"."sensorName", "t1"."sensorValue" FROM "pjh_temperaturemodel" AS "t1" WHERE ("t1"."printJob_id" = ?)', [18])
2020-03-12 16:25:29,317 - octoprint.plugins.PrintJobHistory.DatabaseManager.SQL - DEBUG - ('SELECT "t1"."databaseId", "t1"."created", "t1"."printJob_id", "t1"."profileVendor", "t1"."diameter", "t1"."density", "t1"."material", "t1"."spoolName", "t1"."spoolCost", "t1"."spoolCostUnit", "t1"."spoolWeight", "t1"."usedLength", "t1"."calculatedLength", "t1"."usedWeight", "t1"."usedCost" FROM "pjh_filamentmodel" AS "t1" WHERE ("t1"."printJob_id" = ?)', [17])
2020-03-12 16:25:29,322 - octoprint.plugins.PrintJobHistory.DatabaseManager.SQL - DEBUG - ('SELECT "t1"."databaseId", "t1"."created", "t1"."printJob_id", "t1"."sensorName", "t1"."sensorValue" FROM "pjh_temperaturemodel" AS "t1" WHERE ("t1"."printJob_id" = ?)', [17])
2020-03-12 16:25:29,329 - octoprint.plugins.PrintJobHistory.DatabaseManager.SQL - DEBUG - ('SELECT "t1"."databaseId", "t1"."created", "t1"."printJob_id", "t1"."profileVendor", "t1"."diameter", "t1"."density", "t1"."material", "t1"."spoolName", "t1"."spoolCost", "t1"."spoolCostUnit", "t1"."spoolWeight", "t1"."usedLength", "t1"."calculatedLength", "t1"."usedWeight", "t1"."usedCost" FROM "pjh_filamentmodel" AS "t1" WHERE ("t1"."printJob_id" = ?)', [16])
2020-03-12 16:25:29,334 - octoprint.plugins.PrintJobHistory.DatabaseManager.SQL - DEBUG - ('SELECT "t1"."databaseId", "t1"."created", "t1"."printJob_id", "t1"."sensorName", "t1"."sensorValue" FROM "pjh_temperaturemodel" AS "t1" WHERE ("t1"."printJob_id" = ?)', [16])
2020-03-12 16:25:29,340 - octoprint.plugins.PrintJobHistory.DatabaseManager.SQL - DEBUG - ('SELECT "t1"."databaseId", "t1"."created", "t1"."printJob_id", "t1"."profileVendor", "t1"."diameter", "t1"."density", "t1"."material", "t1"."spoolName", "t1"."spoolCost", "t1"."spoolCostUnit", "t1"."spoolWeight", "t1"."usedLength", "t1"."calculatedLength", "t1"."usedWeight", "t1"."usedCost" FROM "pjh_filamentmodel" AS "t1" WHERE ("t1"."printJob_id" = ?)', [15])
2020-03-12 16:25:29,343 - octoprint.plugins.PrintJobHistory.DatabaseManager.SQL - DEBUG - ('SELECT "t1"."databaseId", "t1"."created", "t1"."printJob_id", "t1"."sensorName", "t1"."sensorValue" FROM "pjh_temperaturemodel" AS "t1" WHERE ("t1"."printJob_id" = ?)', [15])
2020-03-12 16:25:29,347 - octoprint.plugins.PrintJobHistory.DatabaseManager.SQL - DEBUG - ('SELECT "t1"."databaseId", "t1"."created", "t1"."printJob_id", "t1"."profileVendor", "t1"."diameter", "t1"."density", "t1"."material", "t1"."spoolName", "t1"."spoolCost", "t1"."spoolCostUnit", "t1"."spoolWeight", "t1"."usedLength", "t1"."calculatedLength", "t1"."usedWeight", "t1"."usedCost" FROM "pjh_filamentmodel" AS "t1" WHERE ("t1"."printJob_id" = ?)', [14])
2020-03-12 16:25:29,350 - octoprint.plugins.PrintJobHistory.DatabaseManager.SQL - DEBUG - ('SELECT "t1"."databaseId", "t1"."created", "t1"."printJob_id", "t1"."sensorName", "t1"."sensorValue" FROM "pjh_temperaturemodel" AS "t1" WHERE ("t1"."printJob_id" = ?)', [14])
2020-03-12 16:25:29,354 - octoprint.plugins.PrintJobHistory.DatabaseManager.SQL - DEBUG - ('SELECT "t1"."databaseId", "t1"."created", "t1"."printJob_id", "t1"."profileVendor", "t1"."diameter", "t1"."density", "t1"."material", "t1"."spoolName", "t1"."spoolCost", "t1"."spoolCostUnit", "t1"."spoolWeight", "t1"."usedLength", "t1"."calculatedLength", "t1"."usedWeight", "t1"."usedCost" FROM "pjh_filamentmodel" AS "t1" WHERE ("t1"."printJob_id" = ?)', [13])
2020-03-12 16:25:29,357 - octoprint.plugins.PrintJobHistory.DatabaseManager.SQL - DEBUG - ('SELECT "t1"."databaseId", "t1"."created", "t1"."printJob_id", "t1"."sensorName", "t1"."sensorValue" FROM "pjh_temperaturemodel" AS "t1" WHERE ("t1"."printJob_id" = ?)', [13])
2020-03-12 16:25:29,360 - octoprint.plugins.PrintJobHistory.DatabaseManager.SQL - DEBUG - ('SELECT COUNT(1) FROM (SELECT 1 FROM "pjh_printjobmodel" AS "t1") AS "_wrapped"', [])
2020-03-12 16:25:29,384 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.0.25
2020-03-12 16:25:29,472 - octoprint.server.util.flask - INFO - Passively logging in user bzowk from ::ffff:192.168.0.25
2020-03-12 16:25:29,473 - octoprint.access.users - INFO - Logged in user: bzowk
2020-03-12 16:25:31,489 - octoprint.plugins.PrintJobHistory - INFO - Plugin-State: PreHeat=enabled DisplayLayerProgress=enabled filamentmanager=enabled ultimakerformat=enabled
2020-03-12 16:25:31,492 - octoprint.plugins.pushover - INFO - Got an event: ClientOpened Payload: {u'remoteAddress': u'::ffff:192.168.0.25'}
2020-03-12 16:25:31,532 - octoprint.plugins.pushover - INFO - Got an event: UserLoggedIn Payload: {'username': 'bzowk'}
2020-03-12 16:25:31,881 - octoprint.server.util.sockjs - INFO - User bzowk logged in on the socket from client ::ffff:192.168.0.25
2020-03-12 16:25:31,888 - octoprint.plugins.pushover - INFO - Got an event: ClientAuthed Payload: {'username': 'bzowk', 'remoteAddress': u'::ffff:192.168.0.25'}
2020-03-12 16:25:31,996 - octoprint.server.api - ERROR - Error while executing SimpleApiPlugin DeleteAfterPrint
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/server/api/init.py", line 109, in pluginCommand
response = api_plugin.on_api_command(command, data)
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint_DeleteAfterPrint/init.py", line 265, in on_api_command
self._settings.set_boolean([SETTINGS_KEY_DELETE_AFTER_PRINT_LASTVALUE],self._deleteAfterPrintEnabled)
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/plugin/init.py", line 524, in _func
return orig_func(*args_mapper(args), **kwargs_mapper(kwargs))
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/settings.py", line 1772, in setBoolean
self.set(path, value, **kwargs)
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/settings.py", line 1671, in set
self.load()
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/settings.py", line 927, in load
column=column)
InvalidSettings
2020-03-12 16:25:32,001 - tornado.access - ERROR - 500 POST /api/plugin/DeleteAfterPrint (::ffff:192.168.0.25) 18.92ms
2020-03-12 16:25:32,010 - octoprint.server.api - ERROR - Error while executing SimpleApiPlugin DeleteAfterPrint
self.load()
column=column)
InvalidSettings
2020-03-12 16:25:32,014 - tornado.access - ERROR - 500 POST /api/plugin/DeleteAfterPrint (::ffff:192.168.0.25) 30.02ms
2020-03-12 16:25:32,026 - octoprint.server.api - ERROR - Error while executing SimpleApiPlugin DeleteAfterPrint
self.load()
column=column)
InvalidSettings
2020-03-12 16:25:32,031 - tornado.access - ERROR - 500 POST /api/plugin/DeleteAfterPrint (::ffff:192.168.0.25) 44.93ms
2020-03-12 16:25:32,040 - octoprint.server.api - ERROR - Error while executing SimpleApiPlugin DeleteAfterPrint
self.load()
column=column)
InvalidSettings
2020-03-12 16:25:32,046 - tornado.access - ERROR - 500 POST /api/plugin/DeleteAfterPrint (::ffff:192.168.0.25) 58.36ms
2020-03-12 16:25:35,060 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.0.25) 13.04ms
2020-03-12 16:25:40,278 - octoprint.plugins.thespaghettidetective - ERROR - Server websocket is closing
2020-03-12 16:25:44,544 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.0.25
2020-03-12 16:25:44,550 - octoprint.plugins.pushover - INFO - Got an event: ClientClosed Payload: {u'remoteAddress': u'::ffff:192.168.0.25'}
2020-03-12 16:25:44,722 - octoprint.server - INFO - Shutting down...
2020-03-12 16:25:45,145 - octoprint.events - INFO - Processing shutdown event, this will be our last event
2020-03-12 16:25:45,152 - octoprint.plugins.pushover - INFO - Got an event: Shutdown Payload: {}
2020-03-12 16:25:45,246 - octoprint.plugins.pushover - INFO - Could not load image from url
2020-03-12 16:25:45,964 - octoprint.events - INFO - Event loop shut down
2020-03-12 16:25:45,970 - octoprint.server - INFO - Goodbye!
- OctoPrint: Latest release (Can't get to UI to verify version)
- Raspberry Pi 4
- Imaged with OctoPrint Image - not built from Raspbian
Any suggestions? Thanks!
