Octoprint cannot auto-connect to the printer port. PSU Control automatically turns PSU off at bootup. (connected to pin 40).
Disconnecting data cord and reconnecting solves connection issues till the next reboot.
2020-07-08 17:59:52,044 - serial.log is currently not enabled, you can enable it via Settings > Serial Connection > Log communication to serial.log
2020-07-08 20:30:48,302 - serial.log is currently not enabled, you can enable it via Settings > Serial Connection > Log communication to serial.log
2020-07-08 20:42:29,488 - Enabling serial logging
2020-07-08 20:42:35,581 - Changing monitoring state from "Offline" to "Detecting serial port"
2020-07-08 20:42:35,793 - Serial port list: []
2020-07-08 20:42:35,801 - Changing monitoring state from "Detecting serial port" to "Error: Failed to autodetect serial port, please set it manually."
2020-07-08 20:42:35,835 - Failed to autodetect serial port, please set it manually.
2020-07-08 20:42:41,147 - Changing monitoring state from "Offline" to "Detecting serial port"
2020-07-08 20:42:41,372 - Serial port list: []
2020-07-08 20:42:41,376 - Changing monitoring state from "Detecting serial port" to "Error: Failed to autodetect serial port, please set it manually."
2020-07-08 20:42:41,415 - Failed to autodetect serial port, please set it manually.
2020-07-08 20:43:05,423 - Changing monitoring state from "Offline" to "Detecting serial port"
2020-07-08 20:43:05,624 - Serial port list: []
2020-07-08 20:43:05,627 - Changing monitoring state from "Detecting serial port" to "Error: Failed to autodetect serial port, please set it manually."
2020-07-08 20:43:05,665 - Failed to autodetect serial port, please set it manually.
Octoprint Version 1.4.0, Marlin 2.0, firefox, and windows 10
