Octoscreen can not be loaded
I can not load Octoscreen to my Pi 4.
I have followed Chris Basement and it does not load all the prerequsits and therfore does not run
what can I do. I have the newly Today downloaded octoprint with a new PI4 and Pi 7 inch screen. The screen works and shows all progress during loading of octoprint.
You might read through this thread to see if there's anything helpful. And then search the forum like I just did for other threads which discuss octoscreen.
This is what i get when I try to run the download
     Depends: xserver-xorg-input-all but it is not going to be instal                                    led or
                         xorg-driver-input
                Depends: x11-xkb-utils but it is not going to be installed
                Recommends: xserver-xorg-legacy but it is not going to be instal                                    led
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or speci                                    fy a solution).
pi@octopi:~ $ i@octopi:~ $ sudo apt-get install libgtk-3-0 xserver-xorg xinit x11-xserver-uti                                    ls
-bash: i@octopi:~: command not found
pi@octopi:~ $ [sudo] password for pi:
-bash: [sudo]: command not found
pi@octopi:~ $ Reading package lists... Done
-bash: Reading: command not found
pi@octopi:~ $ Building dependency tree
-bash: Building: command not found
pi@octopi:~ $ Reading state information... Done
pi@octopi:~ $ You might want to run 'apt --fix-broken install' to correct these.
-bash: You: command not found
pi@octopi:~ $ The following packages have unmet dependencies:
-bash: The: command not found
pi@octopi:~ $  libgtk-3-0 : Depends: adwaita-icon-theme but it is not going to be installed
-bash: libgtk-3-0: command not found
pi@octopi:~ $               Depends: libatk-bridge2.0-0 (>= 2.5.3) but it is not going to be i                                    nstalled
-bash: syntax error near unexpected token `('
pi@octopi:~ $               Depends: libatk1.0-0 (>= 2.15.1) but it is not going to be install                                    ed
pi@octopi:~ $               Depends: libcairo-gobject2 (>= 1.10.0) but it is not going to be i                                    nstalled
pi@octopi:~ $               Depends: libcolord2 (>= 0.1.10) but it is not going to be installe                                    d
pi@octopi:~ $               Depends: libcups2 (>= 1.6.0) but it is not going to be installed
pi@octopi:~ $               Depends: libepoxy0 (>= 1.4.3) but it is not going to be installed
pi@octopi:~ $               Depends: libjson-glib-1.0-0 (>= 0.12.0) but it is not going to be                                     installed
pi@octopi:~ $               Depends: librest-0.7-0 (>= 0.7) but it is not going to be installe                                    d
pi@octopi:~ $               Depends: libsoup2.4-1 (>= 2.4.0) but it is not going to be install                                    ed
pi@octopi:~ $               Depends: libxcomposite1 (>= 1:0.3-1) but it is not going to be ins                                    talled
pi@octopi:~ $               Depends: libgtk-3-common (>= 3.24.5-1+rpt2) but it is not going to                                     be installed
pi@octopi:~ $               Recommends: libgtk-3-bin but it is not going to be installed
-bash: Recommends:: command not found
pi@octopi:~ $  octoscreen : Depends: libatk1.0-0 (>= 1.12.4) but it is not going to be install                                    ed
pi@octopi:~ $  x11-xserver-utils : Depends: libxaw7 but it is not going to be installed
-bash: x11-xserver-utils: command not found
pi@octopi:~ $                      Depends: libxmu6 but it is not going to be installed
-bash: Depends:: command not found
pi@octopi:~ $                      Depends: libxt6 but it is not going to be installed
pi@octopi:~ $  xserver-xorg : Depends: xserver-xorg-core (>= 2:1.17.2-2) but it is not going t        Depends: libsoup2.4-1 (>= 2.4.0) but it is not going to be install                                    ed
pi@octopi:~ $ -bash: syntax error near unexpected token `('
pi@octopi:~ $ pi@octopi:~ $               Depends: libgtk-3-common (>= 3.24.5-1+rpt2) but it is not going to                                     be installed
pi@octopi:~ $ pi@octopi:~ $               Depends: libcairo-gobject2 (>= 1.10.0) but it is not going to be i                                    nstalled
> ^C
pi@octopi:~ $
Could you please format your logs with the </> in the toolbar? Thank you!
