Luckily it is by rebooting it is Octiprint that comes to put a temperature of 205 in the offset of the head
Octoprint OctoPrint : 1.3.12
Anycubic Chiron
Slicer Prusa 2.1.0
code de départ sur le terminal
Connecting to: /dev/ttyUSB0
Changing monitoring state from "Offline" to "Opening serial port"
Connected to: Serial<id=0x6f4c5730, open=True>(port='/dev/ttyUSB0', baudrate=250000, bytesize=8, parity='N', stopbits=1, timeout=20.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
Changing monitoring state from "Opening serial port" to "Connecting"
Send: N0 M110 N0*125
Recv: start
Recv: echo:V1.3.0
Recv: 1.1.0-RC8
Recv:
Recv: echo: Last Updated: 2016-12-06 12:00 | Author: (Jolly, xxxxxxxx.CO.)
Recv: Compiled: Oct 25 2018
Recv: echo: Free Memory: 3118 PlannerBufferBytes: 1168
Recv: echo:Hardcoded Default Settings Loaded
Recv: echo:Steps per unit:
Recv: echo: M92 X80.00 Y100.00 Z400.00 E405.00
Recv: echo:Maximum feedrates (mm/s):
Recv: echo: M203 X100.00 Y100.00 Z20.00 E80.00
Recv: echo:Maximum Acceleration (mm/s2):
Recv: echo: M201 X350 Y350 Z50 E30000
Recv: echo:Accelerations: P=printing, R=retract and T=travel
Recv: echo: M204 P350.00 R3000.00 T350.00
Recv: echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum XY jerk (mm/s), Z=maximum Z jerk (mm/s), E=maximum E jerk (mm/s)
Recv: echo: M205 S0.00 T0.00 B20000 X4.00 Y4.00 Z0.40 E20.00
Recv: echo:Home offset (mm)
Recv: echo: M206 X0.00 Y0.00 Z0.00
Recv: echo:Z2 Endstop adjustment (mm):
Recv: echo: M666 Z0.00
Recv: echo:PID settings:
Recv: echo: M301 P20.00 I0.50 D106.55
Recv: echo: M304 P97.10 I1.41 D1675.16
Recv: echo:Filament settings: Disabled
Recv: echo: M200 D1.75
Recv: echo: M200 D0
Recv: echo:Z-Probe Offset (mm):
Recv: echo: M851 Z-17.60
Recv: MEANL_L:85echo:SD card ok
Recv: ok
Changing monitoring state from "Connecting" to "Operational"
Recv: echo:SD card ok
Recv: ok
Send: N1 M115*39
Recv: ok
Send: N2 M20*19
Recv: Begin file list
Recv: ABATJO~1.GCO
Recv: RAD2AV~1.GCO
Recv: End file list
Recv: ok
Send: N3 M105*36
Recv: ok T:59.9 /0.0 B:46.0 /0.0 @:0 B@:0
Send: N4 M105*35
Recv: ok T:56.3 /0.0 B:44.9 /0.0 @:0 B@:0
Send: N5 M105*34
Recv: ok T:53.3 /0.0 B:44.5 /0.0 @:0 B@:0
Send: N6 M105*33
Recv: ok T:50.8 /0.0 B:43.1 /0.0 @:0 B@:0
Send: N7 M105*32
Recv: ok T:48.5 /0.0 B:42.5 /0.0 @:0 B@:0
Send: N8 M105*47
Recv: ok T:46.1 /0.0 B:41.4 /0.0 @:0 B@:0
Send: N9 M105*46
Recv: ok T:44.2 /0.0 B:40.6 /0.0 @:0 B@:0
Send: N10 M105*22
Recv: ok T:42.5 /0.0 B:39.9 /0.0 @:0 B@:0
