Using the @pause and @resume commands usually take around 6 to 8 seconds to execute.
Can it be that the Ramps 1.4 board gets a hiccup whenever Octoprint eats @pause or @resume?
Some additional information from the Serial log:
Did not receive parseable position data from printer within 10.0s, continuing without it
Context:
2022-05-01 16:41:23,432 - Recv: X:25.00 Y:5.00 Z:24.00 Count X:2000 Y:400 Z:1440
2022-05-01 16:41:23,433 - Recv: ok
2022-05-01 16:41:33,430 - Did not receive parseable position data from printer within 10.0s, continuing without it
2022-05-01 16:41:33,537 - Send: N10 G92 X25 Y5*16
2022-05-01 16:41:33,542 - Recv: X:25.00 Y:5.00 Z:24.00 Count X:2400 Y:1600 Z:1440
I do know that the issue isn't appearing on the machines with an SKR 1.4 + Raspberry Pi Zero 2 W
The issue only appears on my Ramps 1.4 + Raspberry Pi Zero 2 W machine
I did try using a different Ramps board and also swapped out for a RPi 4 2Gb. But no combination worked well.
No, as this issue doesn't happen on the SKR 1.4 + Pi combination I think the issue is with the Ramps board. The pause also happens when I hardcore the @pause into my gcode files.
n.a.
octoprint-systeminfo-20220501162400.zip (80.6 KB)
RPi Zero 2 W
Ramps 1.4 (converted to 24v, separate 5v line to power the Mega 2560 <- the issues were also present in the 12v setup)
Enclosure Plugin for physical GPIO controls
Marlin flavored GCODE
Firefox
Windows 10
I'm using a Ramps 1.4 with a Raspberry Pi Zero 2 W to control my machine.
I have been using a "I2C-UART Bi-Directional Logic Level Converter 5V-3.3V 2-channel with supply" to handle the 5v to 3.3v logic level conversion. However, I am having some issues with the communication in a way that I haven't been able to fix in two years.
Further I used this setup to control the Ramps 1.4:
I am using the Enclosure plugin which allows users to add physical buttons to an Octoprint machine. I'm using this on three machines, one uses an SKR 1.3, one uses an SKR 1.4 and the last one uses a Ramps 1.4 board.
The SKR boards perform wonderfully, but the machine with the Ramps board has a latency between pressing a button and actually processing the request. It's roughly 6 to 8 seconds between pressing the button and actually seeing something happen in the machine.
I have further narrowed the latency down to only happening when I am using the @pause and @resume commands that Octoprint offers. Any other button presses are handled fine, like moving axes around while paused etc.
The only two other reasons I can think of are that either the Ramps 1.4 board has problems handling the @pause and @resume commands. Or the Logic Level Converter is somehow influencing something, however I do not suspect the logic level converter because GCODE is streamed perfectly fine.
