I found Physical button plugin - #16 by foosel but trying the issues there doesn't seem to fix my problems.
I am attempting to setup a physical button for homing the printer.
I am running the OctoPrint Version 1.11.5 build via Raspberry PI installer on a PI 3+ Model B.
My octoprint.log is showing:
AttributeError: module 'lgpio' has no attribute 'SET_BIAS_DISABLE'
I have verified that user pi is in the gpio group, etc.
I've tried the steps listed in the linked problem but nothing seems to be helping.
I have verified that the wiring is correct. I can read the button state using the RPi.GPIO library.
Yes
My printer starts up in error mode until it receives a $X and $H.
In safe mode, Octoprint sees the error and disconnects. As it is disconnected from the printer, I cannot attempt to home the device.
octoprint-systeminfo-20251202165207.zip (34.8 KB)
OctoPrint version 1.11.5,
OctoPi version: Build 2025.12.01.130812 with "webcamd", based on OctoPi 1.1.0, running on Raspberry Pi 3 Model B Plus Rev 1.3
Printer is a custom CoreXY system running GRBL
I also have Better GRBL Support plugin installed
