Continuing the discussion from Pi Webcam Lights on then Stops Working:
I am having the exact same issue. Pi 3b+ Camera v1.3. safemode doesn't help. disconnecting usb doesn't help.
when accessing /var/log $ vi webcamd.log I get the following:
"Starting up webcamDaemon...
cfg_file: /boot/octopi.txt
camera: auto
usb options: -r 640x480 -f 10
raspi options: -fps 10
Explicitly USB device:
Found video devices:
/dev/video0
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
raspi
"webcamd.log" [readonly] 74438 lines, 898964 characters"
Can you upload the systeminfo bundle? It will contain all the log files and might give us an indication of what's not working.
Double check all of the connections, including the little one that connects the camera sensor to the board, it's small and often missed.
Thanks for your reply!
Im not sure how to get the logs you want but my camera only has a single ribbon cable. I checked it quite a few times but maybe i need another cable? Not sure where it would even go though
Edit: sorry im new here. I clicked the link above and i will get the logs shortly.
let me know if you can open this. Thanks!
octoprint-systeminfo-20220222035236.zip (38.7 KB)
Hello,
I'm having the same problem. On boot, camera LED comes on for about a second, goes off for about 10 seconds, turns back on for about 5 seconds and then turns off. This problem started when I swapped out the camera ribbon for a longer one. I put the ribbon on backwards, not sure if this could have damanged anything? I switched back to the original ribbon and it's still doing it. Here are my logs:
camera: auto
Explicitly set USB device:
/dev/video0
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
/dev/video18
/dev/video20
/dev/video21
/dev/video22
/dev/video23
/dev/video31
raspi
config file='/boot/octopi.txt':USB device was not set in options, starting MJPG-streamer with the first found video device: /dev/video0
<13>Sep 25 15:34:19 root: Starting USB webcam
Running ./mjpg_streamer -o output_http.so -w ./www-octopi -n --listen 127.0.0.1 -i input_uvc.so -r 640x480 -f 10 -d /dev/video0
MJPG Streamer Version.: 2.0
i: Frames Per Second.: 10
i: Format............: JPEG
o: HTTP Listen Address..: 127.0.0.1
Done bringing up all configured video devices
i: select() timeout
i: cleaning up resources allocated by input thread
Thank you for any help
I still have not solved this issue. But like you it started when swapping to a longer ribbon cable but continues when swapping back to the original cable.
Tried it in another pi and it did the same thing there too. I ended up getting a replacement and it works fine. My best guess is that I screwed up the camera some how by putting the cable in backwards while it was powered up.
A year later and I finally solved it! I bought a new pi camera and it worked like a treat. Not sure what happened to the old one but the new one works. So if anyone else has these symptoms, two cases were solved by purchasing new pi cameras.
