Using the Pip update in Octoprint to get to 22.0
Read error on screen
Ran using safe mode. Not sure what else I should do.
Yes tried with safe mode but with same error.
No it did not.
[octoprint-systeminfo-20220130234013.zip|attachment](upload://oW5iKDBo648k40Bmm9O30T2cMxu.zip) (25.8 KB) Error on screen:Updating, please wait.
/home/pi/oprint/bin/python -m pip --disable-pip-version-check install pip==22.0 --no-cache-dir
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Collecting pip==22.0
Downloading https://www.piwheels.org/simple/pip/pip-22.0-py3-none-any.whl (2.1 MB)
ERROR: Exception:
File "/home/pi/oprint/lib/python3.7/site-packages/pip/_vendor/urllib3/response.py", line 438, in _error_catcher
yield
File "/home/pi/oprint/lib/python3.7/site-packages/pip/_vendor/urllib3/response.py", line 519, in read
data = self._fp.read(amt) if not fp_closed else b""
File "/usr/lib/python3.7/http/client.py", line 461, in read
n = self.readinto(b)
File "/usr/lib/python3.7/http/client.py", line 505, in readinto
n = self.fp.readinto(b)
File "/usr/lib/python3.7/socket.py", line 589, in readinto
return self._sock.recv_into(b)
File "/usr/lib/python3.7/ssl.py", line 1052, in recv_into
return self.read(nbytes, buffer)
File "/usr/lib/python3.7/ssl.py", line 911, in read
return self._sslobj.read(len, buffer)
socket.timeout: The read operation timed out
During handling of the above exception, another exception occurred:
File "/home/pi/oprint/lib/python3.7/site-packages/pip/_internal/cli/base_command.py", line 164, in exc_logging_wrapper
status = run_func(*args)
File "/home/pi/oprint/lib/python3.7/site-packages/pip/_internal/cli/req_command.py", line 205, in wrapper
return func(self, options, args)
File "/home/pi/oprint/lib/python3.7/site-packages/pip/_internal/commands/install.py", line 339, in run
reqs, check_supported_wheels=not options.target_dir
File "/home/pi/oprint/lib/python3.7/site-packages/pip/_internal/resolution/resolvelib/resolver.py", line 93, in resolve
collected.requirements, max_rounds=try_to_avoid_resolution_too_deep
File "/home/pi/oprint/lib/python3.7/site-packages/pip/_vendor/resolvelib/resolvers.py", line 482, in resolve
state = resolution.resolve(requirements, max_rounds=max_rounds)
File "/home/pi/oprint/lib/python3.7/site-packages/pip/_vendor/resolvelib/resolvers.py", line 349, in resolve
self._add_to_criteria(self.state.criteria, r, parent=None)
File "/home/pi/oprint/lib/python3.7/site-packages/pip/_vendor/resolvelib/resolvers.py", line 173, in _add_to_criteria
if not criterion.candidates:
File "/home/pi/oprint/lib/python3.7/site-packages/pip/_vendor/resolvelib/structs.py", line 151, in __bool__
return bool(self._sequence)
File "/home/pi/oprint/lib/python3.7/site-packages/pip/_internal/resolution/resolvelib/found_candidates.py", line 155, in __bool__
return any(self)
File "/home/pi/oprint/lib/python3.7/site-packages/pip/_internal/resolution/resolvelib/found_candidates.py", line 143, in <genexpr>
return (c for c in iterator if id(c) not in self._incompatible_ids)
File "/home/pi/oprint/lib/python3.7/site-packages/pip/_internal/resolution/resolvelib/found_candidates.py", line 47, in _iter_built
candidate = func()
File "/home/pi/oprint/lib/python3.7/site-packages/pip/_internal/resolution/resolvelib/factory.py", line 206, in _make_candidate_from_link
version=version,
File "/home/pi/oprint/lib/python3.7/site-packages/pip/_internal/resolution/resolvelib/candidates.py", line 287, in __init__
version=version,
File "/home/pi/oprint/lib/python3.7/site-packages/pip/_internal/resolution/resolvelib/candidates.py", line 156, in __init__
self.dist = self._prepare()
File "/home/pi/oprint/lib/python3.7/site-packages/pip/_internal/resolution/resolvelib/candidates.py", line 225, in _prepare
dist = self._prepare_distribution()
File "/home/pi/oprint/lib/python3.7/site-packages/pip/_internal/resolution/resolvelib/candidates.py", line 292, in _prepare_distribution
return preparer.prepare_linked_requirement(self._ireq, parallel_builds=True)
File "/home/pi/oprint/lib/python3.7/site-packages/pip/_internal/operations/prepare.py", line 482, in prepare_linked_requirement
return self._prepare_linked_requirement(req, parallel_builds)
File "/home/pi/oprint/lib/python3.7/site-packages/pip/_internal/operations/prepare.py", line 528, in _prepare_linked_requirement
link, req.source_dir, self._download, self.download_dir, hashes
File "/home/pi/oprint/lib/python3.7/site-packages/pip/_internal/operations/prepare.py", line 217, in unpack_url
hashes=hashes,
File "/home/pi/oprint/lib/python3.7/site-packages/pip/_internal/operations/prepare.py", line 94, in get_http_url
from_path, content_type = download(link, temp_dir.path)
File "/home/pi/oprint/lib/python3.7/site-packages/pip/_internal/network/download.py", line 145, in __call__
for chunk in chunks:
File "/home/pi/oprint/lib/python3.7/site-packages/pip/_internal/cli/progress_bars.py", line 144, in iter
for x in it:
File "/home/pi/oprint/lib/python3.7/site-packages/pip/_internal/network/utils.py", line 87, in response_chunks
decode_content=False,
File "/home/pi/oprint/lib/python3.7/site-packages/pip/_vendor/urllib3/response.py", line 576, in stream
data = self.read(amt=amt, decode_content=decode_content)
File "/home/pi/oprint/lib/python3.7/site-packages/pip/_vendor/urllib3/response.py", line 541, in read
raise IncompleteRead(self._fp_bytes_read, self.length_remaining)
File "/usr/lib/python3.7/contextlib.py", line 130, in __exit__
self.gen.throw(type, value, traceback)
File "/home/pi/oprint/lib/python3.7/site-packages/pip/_vendor/urllib3/response.py", line 443, in _error_catcher
raise ReadTimeoutError(self._pool, None, "Read timed out.")
pip._vendor.urllib3.exceptions.ReadTimeoutError: HTTPSConnectionPool(host='www.piwheels.org', port=443): Read timed out.
The update did not finish successfully. Please consult octoprint.log and plugin_softwareupdate_console.log for details.
OctoPrint version: 1.7.3.
, OctoPi version 0.17.0,
printer Lulzbot TaZ6,
firmware: Marlin 2.0.9.3,
browser: Chrome,
operating system: Windows 10
