I clicked on the update button in the Web UI and the update fails. See below.
Downloading https://www.piwheels.org/simple/psutil/psutil-6.1.1-cp36-abi3-linux_armv7l.whl (281 kB)
ERROR: Exception:
File "/home/pi/oprint/lib/python3.9/site-packages/pip/_vendor/urllib3/response.py", line 437, in _error_catcher
yield
File "/home/pi/oprint/lib/python3.9/site-packages/pip/_vendor/urllib3/response.py", line 560, in read
data = self._fp_read(amt) if not fp_closed else b""
File "/home/pi/oprint/lib/python3.9/site-packages/pip/_vendor/urllib3/response.py", line 526, in _fp_read
return self._fp.read(amt) if amt is not None else self._fp.read()
File "/usr/lib/python3.9/http/client.py", line 458, in read
n = self.readinto(b)
File "/usr/lib/python3.9/http/client.py", line 502, in readinto
n = self.fp.readinto(b)
File "/usr/lib/python3.9/socket.py", line 704, in readinto
return self._sock.recv_into(b)
File "/usr/lib/python3.9/ssl.py", line 1241, in recv_into
return self.read(nbytes, buffer)
File "/usr/lib/python3.9/ssl.py", line 1099, in read
return self._sslobj.read(len, buffer)
socket.timeout: The read operation timed out
During handling of the above exception, another exception occurred:
File "/home/pi/oprint/lib/python3.9/site-packages/pip/_internal/cli/base_command.py", line 160, in exc_logging_wrapper
status = run_func(*args)
File "/home/pi/oprint/lib/python3.9/site-packages/pip/_internal/cli/req_command.py", line 247, in wrapper
return func(self, options, args)
File "/home/pi/oprint/lib/python3.9/site-packages/pip/_internal/commands/install.py", line 400, in run
requirement_set = resolver.resolve(
File "/home/pi/oprint/lib/python3.9/site-packages/pip/_internal/resolution/resolvelib/resolver.py", line 92, in resolve
result = self._result = resolver.resolve(
File "/home/pi/oprint/lib/python3.9/site-packages/pip/_vendor/resolvelib/resolvers.py", line 481, in resolve
state = resolution.resolve(requirements, max_rounds=max_rounds)
File "/home/pi/oprint/lib/python3.9/site-packages/pip/_vendor/resolvelib/resolvers.py", line 373, in resolve
failure_causes = self._attempt_to_pin_criterion(name)
File "/home/pi/oprint/lib/python3.9/site-packages/pip/_vendor/resolvelib/resolvers.py", line 213, in _attempt_to_pin_criterion
criteria = self._get_updated_criteria(candidate)
File "/home/pi/oprint/lib/python3.9/site-packages/pip/_vendor/resolvelib/resolvers.py", line 204, in _get_updated_criteria
self._add_to_criteria(criteria, requirement, parent=candidate)
File "/home/pi/oprint/lib/python3.9/site-packages/pip/_vendor/resolvelib/resolvers.py", line 172, in _add_to_criteria
if not criterion.candidates:
File "/home/pi/oprint/lib/python3.9/site-packages/pip/_vendor/resolvelib/structs.py", line 151, in __bool__
return bool(self._sequence)
File "/home/pi/oprint/lib/python3.9/site-packages/pip/_internal/resolution/resolvelib/found_candidates.py", line 155, in __bool__
return any(self)
File "/home/pi/oprint/lib/python3.9/site-packages/pip/_internal/resolution/resolvelib/found_candidates.py", line 143, in <genexpr>
return (c for c in iterator if id(c) not in self._incompatible_ids)
File "/home/pi/oprint/lib/python3.9/site-packages/pip/_internal/resolution/resolvelib/found_candidates.py", line 47, in _iter_built
candidate = func()
File "/home/pi/oprint/lib/python3.9/site-packages/pip/_internal/resolution/resolvelib/factory.py", line 206, in _make_candidate_from_link
self._link_candidate_cache[link] = LinkCandidate(
File "/home/pi/oprint/lib/python3.9/site-packages/pip/_internal/resolution/resolvelib/candidates.py", line 297, in __init__
super().__init__(
File "/home/pi/oprint/lib/python3.9/site-packages/pip/_internal/resolution/resolvelib/candidates.py", line 162, in __init__
self.dist = self._prepare()
File "/home/pi/oprint/lib/python3.9/site-packages/pip/_internal/resolution/resolvelib/candidates.py", line 231, in _prepare
dist = self._prepare_distribution()
File "/home/pi/oprint/lib/python3.9/site-packages/pip/_internal/resolution/resolvelib/candidates.py", line 308, in _prepare_distribution
return preparer.prepare_linked_requirement(self._ireq, parallel_builds=True)
File "/home/pi/oprint/lib/python3.9/site-packages/pip/_internal/operations/prepare.py", line 491, in prepare_linked_requirement
return self._prepare_linked_requirement(req, parallel_builds)
File "/home/pi/oprint/lib/python3.9/site-packages/pip/_internal/operations/prepare.py", line 536, in _prepare_linked_requirement
local_file = unpack_url(
File "/home/pi/oprint/lib/python3.9/site-packages/pip/_internal/operations/prepare.py", line 166, in unpack_url
file = get_http_url(
File "/home/pi/oprint/lib/python3.9/site-packages/pip/_internal/operations/prepare.py", line 107, in get_http_url
from_path, content_type = download(link, temp_dir.path)
File "/home/pi/oprint/lib/python3.9/site-packages/pip/_internal/network/download.py", line 147, in __call__
for chunk in chunks:
File "/home/pi/oprint/lib/python3.9/site-packages/pip/_internal/cli/progress_bars.py", line 53, in _rich_progress_bar
for chunk in iterable:
File "/home/pi/oprint/lib/python3.9/site-packages/pip/_internal/network/utils.py", line 63, in response_chunks
for chunk in response.raw.stream(
File "/home/pi/oprint/lib/python3.9/site-packages/pip/_vendor/urllib3/response.py", line 621, in stream
data = self.read(amt=amt, decode_content=decode_content)
File "/home/pi/oprint/lib/python3.9/site-packages/pip/_vendor/urllib3/response.py", line 586, in read
raise IncompleteRead(self._fp_bytes_read, self.length_remaining)
File "/usr/lib/python3.9/contextlib.py", line 135, in __exit__
self.gen.throw(type, value, traceback)
File "/home/pi/oprint/lib/python3.9/site-packages/pip/_vendor/urllib3/response.py", line 442, in _error_catcher
raise ReadTimeoutError(self._pool, None, "Read timed out.")
pip._vendor.urllib3.exceptions.ReadTimeoutError: HTTPSConnectionPool(host='www.piwheels.org', port=443): Read timed out.
ββββ 30.7/281.5 kB 2.5 kB/s eta 0:01:42
The update did not finish successfully. Please consult <code>octoprint.log</code> and <code>plugin_softwareupdate_console.log</code> for details.
Trying again, re-enabling the announcement plugin, and trying a 4th time.
You should update these offensive instructions to at least include the steps to procure the System Info bundle that you want. I don't see a System Info section in the settings menu. Regardless, it's the current OctoPi Image that I'm working from. I have not yet connected a printer.
I might be having a similar issue as this forum thread: Pip update to 22 fails with read error
I didn't know what a PIP installation was, but my log stopped when it was futzing with PiWheels, so I looked that up. Their website says it's related to PIPs, and that they are something to do with updates on ARM and Raspberry Pis specifically, so I think my issue is related to the other thread. I don't know what's going on under the hood though, so I'm not sure where to go next, since the previous thread says there was a cloud or server side issue.
I can go to their webpage, so I don't think they are blocking my IP. The Pi has Internet access, and can see that updates are available.
I'm not sure if this is a server-side issue, the OctoPi image is too old, or the latest update is too new.
I have worked with embedded devices professionally for many years, and while I don't have much cred on the forum, have been doing 3d printing for a while too. I do development and sysadmin stuff.
