Power cut now asking for password
Power cut while printing now octoprint asks for password I've tried the few passwords I normally use which are apparently wrong. How do I reset this octopi password that I don't even remember ever setting up?
looked at how to reset password using SSH whatever...looks like gobbedygook to me i'm not a computer person. The whole thing will be going in the bin if it requires one to be a computer expert to reset a password
no
no
Hello @196Chlne !
Do you want to reset the OctoPrint password or the OctoPi password?
A quick search gave this ion the FAQ:
This is a very detailed description how to reset the OctoPrint password.
Hi thanks. I need to reset my octoprint login. I don't know what SSHing is or how to do it and it is very difficult to connect a monitor to my rasbery pi since it is inside a printer that must be dismantled to get to it . How do I recent this octoprint password? What is SSH?
this is starting to sound very complicated to the point I'll just throw the thing away and buy a new one
There are some guides how to SSH, like this:
It is not that difficult.
There is no need for throwing away.
If nothing works, you could flash a new OctoPi onto a SD card.
But you may give SSH a try.
I'm trying to reflash the micro SD card. I've absolutely no idea what or how to SSH and I cannot easily connect the pi to a monitor. Maybe if you are a professional computer tech/programmer or software engineer this is simple but for normal non computer person this is absolutely ridiculous. I hope this works otherwise I'm stuck with a useless printer and only option to buy new and start over
That's why I posted that link in my last post.
Anyhow, a fresh flash gives you a clean and up-to-date system.
Thankfully reflashing worked. Thanks for your help
@196Chlne, I strongly recommend that you take the time to learn how to use SSH and maybe a few basic Linux commands. You don't need to be an expert because if you encounter a problem that we can help you fix using SSH, we will lead you through exactly what commands to type, etc.
