The Print Head does not go to the upper position, after printing
The print head stays at the position where printing stopped. It does NOT go to its upper position. When I press the Home-Button in Octoprint, it goes to its upper position.
I entered the command "G28 X0 Y0" in the gcode scripts at the end of the printing, as it is already in the gcode file, which was created by "Ultimaker Cura"
Complete Logs
octoprint.log
, serial.log
or output on terminal tab at a minimum, browser error console if UI issue ... no logs, no support! Not log excerpts, complete logs.)
