Some prints are just aborted. The PI shut down suddenly, the red power light is off.
Purchased the official Raspberry power supply. Still happening.
Raspberry PI 3B+
OctoPrint 1.3.8
| Bed Visualizer (0.1.1) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_bedlevelvisualizer
| CuraEngine (<= 15.04) (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/cura
| Octolapse (0.3.1) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_octolapse
| OctoPrint Anywhere (0.6.3) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_anywhere
| hardware:
| cores: 4
| freq: 1400.0
| ram: 918192128
| os:
| platform: linux2
| plugins:
| octopi_support:
| model: unknown
| revision: a020d3
| version: 0.15.0
| python:
| pip: 10.0.1
| version: 2.7.13
| virtualenv: /home/pi/oprint
octoprint.log snippet:
2018-06-13 08:34:14,213 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/webassets...
2018-06-13 08:34:14,227 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/.webassets-cache...
2018-06-13 08:34:14,247 - octoprint.plugins.octolapse - INFO - Octolapse is loading assets.
2018-06-13 08:34:14,466 - octoprint.server - INFO - Shutting down intermediary server...
2018-06-13 08:34:14,707 - octoprint.server - INFO - Intermediary server shut down
2018-06-13 08:34:14,708 - octoprint.events - INFO - Processing startup event, this is our first event
2018-06-13 08:34:14,709 - octoprint.events - INFO - Adding 0 events to queue that were held back before startup event
2018-06-13 08:34:14,710 - octoprint.filemanager - INFO - Adding backlog items from all storage types to analysis queue...
2018-06-13 08:34:14,734 - octoprint.filemanager - INFO - Added 0 items from storage type "local" to analysis queue
2018-06-13 08:34:14,747 - octoprint.plugins.discovery - INFO - Registered OctoPrint instance on octopi for _http._tcp
2018-06-13 08:34:14,757 - octoprint.plugins.discovery - INFO - Registered OctoPrint instance on octopi for _octoprint._tcp
2018-06-13 08:34:14,761 - octoprint.plugins.discovery - INFO - Registered OctoPrint instance on octopi for SSDP
2018-06-13 08:34:14,762 - octoprint.server - INFO - Listening on http://127.0.0.1:5000
2018-06-13 08:34:14,850 - octoprint.plugins.anywhere - WARNING - Not connected to server ws or connection lost
2018-06-13 08:34:14,871 - octoprint.plugins.bedlevelvisualizer - INFO - OctoPrint-BedLevelVisualizer loaded!
2018-06-13 08:34:14,880 - octoprint.plugins.anywhere - WARNING - Not connected to server ws or connection lost
2018-06-13 08:34:14,886 - octoprint.plugins.octolapse - INFO - Loading existing settings file from: /home/pi/.octoprint/data/octolapse/settings.json.
2018-06-13 08:34:14,888 - octoprint.server.util.sockjs - INFO - New connection from client: 127.0.0.1
2018-06-13 08:34:15,468 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2018-06-13 08:34:15,669 - octoprint.plugins.anywhere - WARNING - Not connected to server ws or connection lost
2018-06-13 08:34:15,779 - octoprint.server.preemptive_cache - INFO - Preemptively caching / (ui _default) for {'query_string': 'l10n=en', 'path': '/', 'base_url': 'http://192.168.1.14/'}
2018-06-13 08:34:15,789 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2018-06-13 08:34:28,887 - octoprint.server.preemptive_cache - INFO - ... done in 13.11s
2018-06-13 08:34:28,888 - octoprint.server.preemptive_cache - INFO - Preemptively caching / (ui _default) for {'query_string': 'l10n=en', 'path': '/', 'base_url': 'http://219.75.2.85/'}
2018-06-13 08:36:53,097 - octoprint.server.preemptive_cache - INFO - ... done in 144.21s
2018-06-13 08:38:45,707 - tornado.access - WARNING - 404 GET /manager/html (127.0.0.1) 23.73ms
2018-06-13 08:39:36,644 - tornado.access - WARNING - 403 POST /api/plugin/anywhere (127.0.0.1) 26.66ms
2018-06-13 08:39:38,447 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.1.13
2018-06-13 08:39:42,033 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Detecting serial port"
2018-06-13 08:39:42,266 - octoprint.util.comm - INFO - Changing monitoring state from "Detecting serial port" to "Opening serial port"
2018-06-13 08:39:42,277 - octoprint.util.comm - INFO - Changing monitoring state from "Opening serial port" to "Detecting baudrate"
2018-06-13 08:39:42,311 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2018-06-13 08:39:51,519 - octoprint.util.comm - INFO - Changing monitoring state from "Detecting baudrate" to "Operational"
2018-06-13 08:39:51,539 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2018-06-13 08:39:56,631 - octoprint.util.comm - INFO - Printer reports firmware name "Marlin 1.1.8 (Github)"
2018-06-13 08:39:56,655 - octoprint.util.comm - INFO - Firmware states that it supports temperature autoreporting
2018-06-13 08:39:59,220 - octoprint.util.comm - INFO - Changing monitoring state from "Operational" to "Printing"
2018-06-13 08:40:05,412 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2018-06-13 08:46:04,946 - backoff - ERROR - Backing off forward_ws(...) for 0.8s (WebSocketConnectionClosedException: Connection is already closed.)
2018-06-13 08:46:05,746 - octoprint.plugins.anywhere - WARNING - Not connected to server ws or connection lost
2018-06-13 08:46:05,747 - backoff - ERROR - Backing off forward_ws(...) for 0.0s (WebSocketConnectionClosedException: Connection is already closed.)
2018-06-13 08:46:05,782 - octoprint.plugins.anywhere - WARNING - Not connected to server ws or connection lost
2018-06-13 08:46:05,783 - backoff - ERROR - Backing off forward_ws(...) for 0.6s (WebSocketConnectionClosedException: Connection is already closed.)
2018-06-13 08:46:06,406 - octoprint.plugins.anywhere - WARNING - Not connected to server ws or connection lost
2018-06-13 08:46:06,410 - backoff - ERROR - Backing off forward_ws(...) for 0.6s (WebSocketConnectionClosedException: Connection is already closed.)
2018-06-13 08:46:06,986 - octoprint.plugins.anywhere - WARNING - Not connected to server ws or connection lost
2018-06-13 08:46:06,987 - backoff - ERROR - Backing off forward_ws(...) for 2.6s (WebSocketConnectionClosedException: Connection is already closed.)
2018-06-13 08:46:09,576 - octoprint.plugins.anywhere - WARNING - Not connected to server ws or connection lost
2018-06-13 08:46:09,577 - backoff - ERROR - Backing off forward_ws(...) for 2.0s (WebSocketConnectionClosedException: Connection is already closed.)
2018-06-13 08:46:11,537 - octoprint.plugins.anywhere - WARNING - Not connected to server ws or connection lost
2018-06-13 08:46:11,538 - backoff - ERROR - Backing off forward_ws(...) for 6.6s (WebSocketConnectionClosedException: Connection is already closed.)
2018-06-13 08:46:18,187 - octoprint.plugins.anywhere - WARNING - Not connected to server ws or connection lost
2018-06-13 08:46:18,189 - backoff - ERROR - Backing off forward_ws(...) for 10.5s (WebSocketConnectionClosedException: Connection is already closed.)
2018-06-13 08:46:28,726 - octoprint.plugins.anywhere - WARNING - Not connected to server ws or connection lost
2018-06-13 08:46:28,728 - backoff - ERROR - Giving up forward_ws(...) after 8 tries (WebSocketConnectionClosedException: Connection is already closed.)
2018-06-13 08:46:28,729 - octoprint.plugins.anywhere - WARNING - Reached max backoff in waiting for server ws connection
2018-06-13 08:46:29,019 - octoprint.plugins.anywhere - WARNING - Not connected to server ws or connection lost
2018-06-13 08:46:29,883 - octoprint.plugins.anywhere - WARNING - Not connected to server ws or connection lost
2018-06-13 08:49:08,577 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2018-06-13 08:50:22,057 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.1.13
