Printer disconnect mid print
Printing via octoprint on raspberry pi 4 keeps disconnecting mid print
Prints are perfect from SD card.
Tried multiple cables.
Installed fan on Pi.
nope
To test
octoprint (1).log (17.3 KB)
serial (4).log (3.3 MB)
Here are some replies I have given in the past to that issue
looks like problem solved i ran cable underneath the printer as pi was at the back. Thank you for the help
