I am printing on my Ender 3 Max with a Octopi. When I start a print from my card the printer will auto home then print the purge, then auto home again. (I am not really worried about the double home) The printer will either print normally, or the more common; print in the air. I have absolutely no clue what is causing it. As well, the printer prints at the right height after the first homing for 1-2 seconds then it homes again and most of the time prints in the air.
I have tried to run the printer without the pi and it worked perfectly fine.
I have also tried running it in safe mode.
It didn't fix the printing in the air or the double homing.
I have the pi connected to the printer with the (micro?) usb port next the the card slot. I used the included cords to power the pi and prevent power from the printer messing with the pi.
Hello @Pepisman026 !
Please enable the serial.log, try again and then attach (as it was already requested) the systeminfo bundle to your next post.
Blue words like serial.log are links and give you further information.
Can I view the log before i download it? Sorry for asking so many questions.
It would be easier to look at it after you downloaded it.
Just open it in a text editor of your choice
That's not the one we need
The serial log logs the communication between octoprint and the printer so we know what exactly happened.
Best would be to enable it, then start a print until the issue occurs again an then upload the bundle - or if you prefer it just the serial.log.
Then we see what's going on.
I enabled the serial.log setting and started a test cube. The printer skipped the second auto home and is printing normally. I am going to test the printer more and see what happens.
Ok. There are still issues with the printer. However, the printer is quite old and you can't find parts, so I blame that. I have found something in the settings that made the printer home whenever doing stuff. I don't really remember what I did, (it was 4 months ago) but there was something in the settings that said auto-home on start (or something similar, don't remember). It was one of the issues, but the printer is old, and this may not be the solution to other peoples problems, but I want to help however I can
Β―\ (γ) /Β―.
