Printer stops extruding
Printer stops extruding during print from octoprint.
Replacing cable with a newer one, restarting octoprint, reslicing the gcode
Yes
It still happened.
Where do you get this?
*Found it
octoprint-systeminfo-20230922131936.zip (1.4 MB)
Ender 3 with creality 4.2.7 silent board, custom firmware, running octo4a with many plugins, octoprint version 1.9.2
Hello @Masa_de_Man !
Hint: Blue words like systeminfo bundle / safe mode are links for more info.
OK, got it.
It prints fine when using the sd card, but it stops extruding after some time with octoprint.
I had a look on your octoprint log.
It looks qutie messy. A lot of error message from the system:
2023-09-20 06:17:02,699 - octoprint.util.comm - ERROR - Could not scan /dev for serial ports on the system
  File "/usr/lib/python3.10/site-packages/octoprint/util/comm.py", line 211, in serialList
    with os.scandir("/dev") as it:
PermissionError: [Errno 13] Permission denied: '/dev'
and a ton of other errors
On a tiny side note I saw you run Octo4a.
Did it run before properly?
Yes, this issue only happens every now and then and with certain prints. Usually, reprinting or reslicing helps.
I did try looking for another topic about this, but the topic was closed before a solution was found.
Printer stops extruding after some time - Get Help - OctoPrint Community Forum
