Can't get my printer to register in OctoPrint.
"Error: Failed to autodetect serial port, please set it manually."
The only option is auto.
Have attempted to follow several other 'cant connect printer' conversations/topics, but I either don't know how to adjust the solutions to work for mine or get lost in the back and forth steps in the provided answers.
Printer: PowerSpec Ultra
Firmware: V2.4
RPi: Model 3B
32GB Micro SD
using on-board WIFI
5.25V power supply
Using a Play Station webcam (one of the youtube videos suggested this model and it was only $8 :))
OctoPrint v.0.15.1
Printer and webcam are connected to the RPi via USB and the Pi is plugged into the power supply. I have accessed OctoPrint through my desktop (Windows 10) via IP. If I go to "control", the webcam is on and functioning, but cannot get the printer to register.
serial.log:
2018-07-09 17:25:04,101 - Changing monitoring state from "Offline" to "Detecting serial port"
2018-07-09 17:25:04,163 - Serial port list: []
2018-07-09 17:25:04,163 - Changing monitoring state from "Detecting serial port" to "Error: Failed to autodetect serial port, please set it manually."
2018-07-09 17:25:04,166 - Failed to autodetect serial port, please set it manually.
octoprint.log:
2018-07-08 17:28:14,793 - octoprint.server - INFO - OctoPrint 1.3.8
2018-07-08 17:28:14,794 - octoprint.plugin.core - INFO - 10 plugin(s) registered with the system:
| CuraEngine (<= 15.04) (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/cura
| OctoPi Support Plugin (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/octopi_support
2018-07-08 17:28:14,808 - octoprint.environment - INFO - Detected environment is Python 2.7.13 under Linux (linux2). Details:
| hardware:
| cores: 4
| freq: 1200.0
| ram: 918192128
| os:
| platform: linux2
| plugins:
| octopi_support:
| model: 3B
| revision: a22082
| version: 0.15.1
| python:
| pip: 9.0.3
| version: 2.7.13
| virtualenv: /home/pi/oprint
2018-07-08 17:28:14,809 - octoprint.server - INFO - ------------------------------------------------------------------------------
2018-07-08 17:28:14,791 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2018-07-08 17:43:14,809 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2018-07-08 17:58:14,810 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2018-07-08 18:13:14,812 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2018-07-08 18:28:14,813 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2018-07-08 18:43:14,814 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2018-07-08 18:58:14,815 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2018-07-08 19:13:14,816 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2018-07-08 19:28:14,817 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2018-07-08 19:43:14,818 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2018-07-08 19:58:14,819 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2018-07-08 20:13:14,820 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2018-07-08 20:28:14,821 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2018-07-08 20:43:14,822 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2018-07-08 20:58:14,823 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2018-07-08 21:13:14,824 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2018-07-08 21:28:14,825 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2018-07-08 21:43:14,826 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2018-07-08 21:58:14,827 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2018-07-08 22:13:14,828 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2018-07-08 22:28:14,829 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2018-07-08 22:43:14,831 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2018-07-08 22:58:14,832 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2018-07-08 23:13:14,833 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2018-07-08 23:28:14,835 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2018-07-08 23:43:14,836 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2018-07-08 23:28:24,853 - octoprint.startup - INFO - ******************************************************************************
2018-07-08 23:28:24,855 - octoprint.startup - INFO - Starting OctoPrint 1.3.8
2018-07-08 23:28:24,856 - octoprint.startup - INFO - ******************************************************************************
2018-07-08 23:28:24,966 - octoprint.util.connectivity_checker - INFO - Connectivity changed from offline to online
2018-07-08 23:28:26,607 - octoprint.startup - INFO - Blacklist processing done
2018-07-08 23:28:26,746 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2018-07-08 23:28:29,281 - octoprint.plugin.core - INFO - Found 10 plugin(s) providing 10 mixin implementations, 4 hook handlers
2018-07-08 23:28:29,416 - octoprint.server.heartbeat - INFO - Starting server heartbeat, 900.0s interval
2018-07-08 23:28:29,460 - octoprint.server - INFO - Intermediary server started
2018-07-08 23:28:29,461 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2018-07-08 23:28:30,057 - octoprint.plugin.core - INFO - Found 10 plugin(s) providing 10 mixin implementations, 4 hook handlers
2018-07-08 23:28:30,134 - octoprint.filemanager.storage - INFO - Initializing the file metadata for /home/pi/.octoprint/uploads...
2018-07-08 23:28:30,816 - octoprint.filemanager.storage - INFO - ... file metadata for /home/pi/.octoprint/uploads initialized successfully.
2018-07-08 23:28:30,875 - octoprint.plugins.softwareupdate - INFO - Loaded version cache from disk
2018-07-08 23:28:33,305 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2018-07-08 23:28:35,304 - octoprint.util.pip - INFO - Version of pip is 9.0.3
2018-07-08 23:28:35,305 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2018-07-08 23:28:35,320 - octoprint.util.pip - INFO - ==> pip ok -> yes
2018-07-08 23:28:35,323 - octoprint.plugin.core - INFO - Initialized 10 plugin implementation(s)
2018-07-08 23:28:35,330 - octoprint.plugin.core - INFO - 10 plugin(s) registered with the system:
2018-07-08 23:28:35,352 - octoprint.environment - INFO - Detected environment is Python 2.7.13 under Linux (linux2). Details:
| hardware:
| cores: 4
| freq: 1200.0
| ram: 918192128
| os:
| platform: linux2
| plugins:
| octopi_support:
| model: 3B
| revision: a22082
| version: 0.15.1
| python:
| pip: 9.0.3
| version: 2.7.13
2018-07-08 23:28:35,362 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/webassets...
2018-07-08 23:28:35,378 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/.webassets-cache...
2018-07-08 23:28:35,692 - octoprint.server - INFO - Shutting down intermediary server...
2018-07-08 23:28:35,823 - octoprint.server - INFO - Intermediary server shut down
2018-07-08 23:28:35,825 - octoprint.events - INFO - Processing startup event, this is our first event
2018-07-08 23:28:35,826 - octoprint.events - INFO - Adding 1 events to queue that were held back before startup event
2018-07-08 23:28:35,827 - octoprint.filemanager - INFO - Adding backlog items from all storage types to analysis queue...
2018-07-08 23:28:35,946 - octoprint.filemanager - INFO - Added 0 items from storage type "local" to analysis queue
2018-07-08 23:28:35,979 - octoprint.plugins.discovery - INFO - Registered OctoPrint instance on octopi for _http._tcp
2018-07-08 23:28:35,991 - octoprint.plugins.discovery - INFO - Registered OctoPrint instance on octopi for _octoprint._tcp
2018-07-08 23:28:35,994 - octoprint.plugins.discovery - INFO - Registered OctoPrint instance on octopi for SSDP
2018-07-08 23:28:35,996 - octoprint.server - INFO - Listening on http://127.0.0.1:5000
2018-07-08 23:28:36,071 - octoprint.server.preemptive_cache - INFO - Preemptively caching / (ui _default) for {'query_string': 'l10n=en', 'path': '/', 'base_url': 'http://192.168.1.64/'}
2018-07-08 23:28:36,783 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from https://plugins.octoprint.org/plugins.json
2018-07-08 23:28:37,800 - octoprint.plugins.announcements - INFO - Loaded channel _important from https://octoprint.org/feeds/important.xml in 1.9s
2018-07-08 23:28:38,101 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from https://plugins.octoprint.org/plugins.json
2018-07-08 23:28:38,105 - octoprint.plugins.announcements - INFO - Loaded channel _important from https://octoprint.org/feeds/important.xml in 2.1s
2018-07-08 23:28:38,801 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2018-07-08 23:28:38,878 - octoprint.plugins.pluginmanager - INFO - Loaded plugin notices data from https://plugins.octoprint.org/notices.json
2018-07-08 23:28:39,433 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2018-07-08 23:28:40,117 - octoprint.plugins.announcements - INFO - Loaded channel _releases from https://octoprint.org/feeds/releases.xml in 1.6s
2018-07-08 23:28:41,522 - octoprint.plugins.announcements - INFO - Loaded channel _releases from https://octoprint.org/feeds/releases.xml in 2.7s
2018-07-08 23:28:42,179 - octoprint.plugins.announcements - INFO - Loaded channel _blog from https://octoprint.org/feeds/octoblog.xml in 1.9s
2018-07-08 23:28:42,718 - octoprint.plugins.announcements - INFO - Loaded channel _blog from https://octoprint.org/feeds/octoblog.xml in 0.84s
2018-07-09 17:22:15,196 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2018-07-09 17:22:15,438 - octoprint.plugins.announcements - INFO - Loaded channel _plugins from https://plugins.octoprint.org/feed.xml in 6.4e+04s
2018-07-09 17:22:15,667 - octoprint.plugins.announcements - INFO - Loaded channel _plugins from https://plugins.octoprint.org/feed.xml in 6.4e+04s
2018-07-09 17:22:16,458 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages/ (writable -> yes), --user flag needed -> no, virtual env -> yes
2018-07-09 17:22:16,471 - octoprint.util.pip - INFO - ==> pip ok -> yes
2018-07-09 17:22:17,166 - octoprint.plugins.softwareupdate - INFO - Saved version cache to disk
2018-07-09 17:22:17,437 - octoprint.plugins.announcements - INFO - Loaded channel _octopi from https://octoprint.org/feeds/octopi.xml in 1.4s
2018-07-09 17:22:17,713 - octoprint.plugins.announcements - INFO - Loaded channel _octopi from https://octoprint.org/feeds/octopi.xml in 2.0s
2018-07-09 17:22:35,260 - octoprint.server.preemptive_cache - INFO - ... done in 64439.19s
2018-07-09 17:22:35,268 - octoprint.server.preemptive_cache - INFO - Preemptively caching / (ui _default) for {'query_string': 'l10n=en', 'path': '/', 'base_url': 'http://octopi.local/'}
2018-07-09 17:22:39,210 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.1.73
2018-07-09 17:22:41,211 - octoprint.server.preemptive_cache - INFO - ... done in 5.94s
2018-07-09 17:23:20,255 - octoprint.plugins.announcements - INFO - Loaded channel _important from https://octoprint.org/feeds/important.xml in 1.7s
2018-07-09 17:23:21,387 - octoprint.plugins.announcements - INFO - Loaded channel _releases from https://octoprint.org/feeds/releases.xml in 0.78s
2018-07-09 17:23:23,281 - octoprint.plugins.announcements - INFO - Loaded channel _blog from https://octoprint.org/feeds/octoblog.xml in 1.8s
2018-07-09 17:23:26,757 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.1.73
2018-07-09 17:23:27,118 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.1.73
2018-07-09 17:23:33,094 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Detecting serial port"
2018-07-09 17:23:33,105 - octoprint.util.comm - INFO - Changing monitoring state from "Detecting serial port" to "Error: Failed to autodetect serial port, please set it manually."
2018-07-09 17:23:58,379 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Detecting serial port"
2018-07-09 17:23:58,399 - octoprint.util.comm - INFO - Changing monitoring state from "Detecting serial port" to "Error: Failed to autodetect serial port, please set it manually."
2018-07-09 17:24:09,998 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Detecting serial port"
2018-07-09 17:24:10,068 - octoprint.util.comm - INFO - Changing monitoring state from "Detecting serial port" to "Error: Failed to autodetect serial port, please set it manually."
2018-07-09 17:24:21,934 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Detecting serial port"
2018-07-09 17:24:21,945 - octoprint.util.comm - INFO - Changing monitoring state from "Detecting serial port" to "Error: Failed to autodetect serial port, please set it manually."
2018-07-09 17:24:58,671 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Detecting serial port"
2018-07-09 17:24:58,693 - octoprint.util.comm - INFO - Changing monitoring state from "Detecting serial port" to "Error: Failed to autodetect serial port, please set it manually."
2018-07-09 17:24:59,254 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Detecting serial port"
2018-07-09 17:24:59,264 - octoprint.util.comm - INFO - Changing monitoring state from "Detecting serial port" to "Error: Failed to autodetect serial port, please set it manually."
2018-07-09 17:25:00,765 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Detecting serial port"
2018-07-09 17:25:00,774 - octoprint.util.comm - INFO - Changing monitoring state from "Detecting serial port" to "Error: Failed to autodetect serial port, please set it manually."
2018-07-09 17:25:04,124 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Detecting serial port"
2018-07-09 17:25:04,164 - octoprint.util.comm - INFO - Changing monitoring state from "Detecting serial port" to "Error: Failed to autodetect serial port, please set it manually."
Have attempted to add additional ports (from a different forum) and have rebooted OctoPrint several times. However, I still cant seem to get the printer to connect. I would put the additional port 'like it tells me in the Terminal tab", but this is where my ignorance shines through and I do not know how to obtain this information - I assume this will be in the serial.log??
If there is any additional information needed, feel free to request and I will do my best to provide it.
