When printing with Octoprint I get stuttering an a lot of Surface Blobs
Installed New Octopi 017 on new SD card Sandisk Ultra 16 GB. Connected by ethernet to pi 3B+. Turned off wifi and bluetooth. Printed Identical gcode file direct from Printer main board and good quality clean print
Printer Ender 3 Pro. SKR Mini E3 Board
Log shows loads of time outs
Please can you advise what to try next
Ta
Logs (octoprint.logt serial.log or output on terminal tab at a minimum, browser error console if UI issue ... no logs, no support!)
2020-04-25 17:17:58,619 - octoprint.util.comm - INFO - Changing monitoring state from "Opening serial port" to "Connecting"
2020-04-25 17:17:58,644 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2020-04-25 17:17:58,651 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2020-04-25 17:17:58,657 - octoprint.util.comm - INFO - Changing monitoring state from "Connecting" to "Operational"
2020-04-25 17:17:58,673 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2020-04-25 17:17:58,681 - octoprint.util.comm - INFO - Printer reports firmware name "Marlin bugfix-2.0.x (GitHub)"
2020-04-25 17:17:58,691 - octoprint.util.comm - INFO - Firmware states that it supports temperature autoreporting
2020-04-25 17:18:01,985 - octoprint.filemanager.analysis - INFO - Analysis of entry local:CCR10_RC3_-x2-PETG.gcode finished, needed 48.15s
2020-04-25 17:18:27,549 - octoprint.printer.standard.job - INFO - Print job selected - origin: local, path: CCR10_RC3_-x2-PETG.gcode, owner: cmd, user: cmd
2020-04-25 17:18:27,579 - octoprint.util.comm - INFO - Changing monitoring state from "Operational" to "Starting"
2020-04-25 17:18:27,592 - octoprint.printer.standard.job - INFO - Print job started - origin: local, path: CCR10_RC3_-x2-PETG.gcode, owner: cmd, user: cmd
2020-04-25 17:18:27,602 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2020-04-25 17:18:27,610 - octoprint.util.comm - INFO - Changing monitoring state from "Starting" to "Printing"
2020-04-25 17:18:29,637 - octoprint.util.comm - INFO - Printer seems to support the busy protocol, will adjust timeouts and set busy interval accordingly
2020-04-25 17:24:05,998 - octoprint.util.comm - INFO - Telling the printer to set the busy interval to our "communicationBusy" timeout - 1s = 2s
2020-04-25 17:26:34,790 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
2020-04-25 17:26:38,790 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
2020-04-25 17:26:42,789 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
2020-04-25 17:27:02,798 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
2020-04-25 17:27:06,791 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
2020-04-25 17:27:26,794 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
2020-04-25 17:27:32,794 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
2020-04-25 17:27:36,795 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
2020-04-25 17:27:56,803 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
2020-04-25 17:28:00,811 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
2020-04-25 17:28:18,804 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
2020-04-25 17:28:24,817 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
2020-04-25 17:28:28,817 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
2020-04-25 17:28:38,810 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
2020-04-25 17:28:44,821 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
2020-04-25 17:28:54,811 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
Thank you for pointing this, this should reduce the number of my tests
