Hello
I found the problem in czech language pack for Octoprint version 1.4.0. With language pack for version 1.3.12 this problem is fixed.
I´m not sure what is wrong - the *.po file is downloaded from transifex - https://www.transifex.com/octoprint/octoprint/dashboard/
and converted to *.mo file by this page: https://ezgif.com/po-to-mo Maybe some wrong characters in new translated strings ?
Somebody have same experince in the past?
I have attached both version of files for checking.
Thanks for your help.
Jan
Hello @foosel
Do you known if there is some possibility how to return the translation source file in transifex to state of version 1.3.12 only for czech version?
Or how to adjust transifex to show only strings which was added after version 1.3.12?
I tried adjust "Source updated after" but I´m not sure of date of first update after version 1.3.12
I will try translate it again "per partes" to find problematic string.
