Problem?
First, My prints come out much better from SD card (exactly same gcode file) and idk why?
Second, most important, recently my printer stops printing, freezes on some random point, octopi freezes too, unfreeze when i pull out usb cable from ender...
reflash printer, reinstall octopi
no
Complete Logs
Full log in attachment (change the extension to .txt)
log.gcode (45.6 KB)
Part:
2021-02-03 17:42:40,994 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Detecting serial connection"
2021-02-03 17:42:41,240 - octoprint.util.comm - INFO - Serial detection: Performing autodetection with 7 port/baudrate candidates: /dev/ttyUSB0@115200, /dev/ttyUSB0@250000, /dev/ttyUSB0@230400, /dev/ttyUSB0@57600, /dev/ttyUSB0@38400, /dev/ttyUSB0@19200, /dev/ttyUSB0@9600
2021-02-03 17:42:41,248 - octoprint.util.comm - INFO - Serial detection: Trying port /dev/ttyUSB0, baudrate 115200
2021-02-03 17:42:41,261 - octoprint.util.comm - INFO - Connecting to port /dev/ttyUSB0, baudrate 115200
2021-02-03 17:42:41,286 - octoprint.util.comm - INFO - Serial detection: Handshake attempt #1 with timeout 2.0s
2021-02-03 17:42:41,306 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2021-02-03 17:42:41,357 - octoprint.util.comm - INFO - Changing monitoring state from "Detecting serial connection" to "Operational"
2021-02-03 17:42:41,408 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2021-02-03 17:42:42,188 - octoprint.util.comm - INFO - Printer reports firmware name "Marlin 2.0.7.2 (Jan 25 2021"
2021-02-03 17:42:42,404 - octoprint.util.comm - INFO - Firmware states that it supports temperature autoreporting
2021-02-03 17:42:43,323 - octoprint.plugins.tracking - INFO - Sent tracking event printer_connected, payload: {u'printer_baudrate': 0, u'printer_port': None, u'firmware_name': u'Marlin 2.0.7.2 (Jan 25 2021'}
2021-02-03 17:42:45,478 - octoprint.plugins.DisplayLayerProgress - INFO - Limit of 500 reached and no M117 INDICATOR-Layer found
2021-02-03 17:42:45,486 - octoprint.plugins.DisplayLayerProgress - INFO - FilePreProcessor. Checking LayerExpressions.
2021-02-03 17:42:45,494 - octoprint.plugins.DisplayLayerProgress - INFO - FilePreProcessor. LayerExpression valid. Start processing...
2021-02-03 17:43:05,195 - octoprint.filemanager.analysis - INFO - Starting analysis of local:CE3PRO_test.gcode
2021-02-03 17:43:05,973 - octoprint.plugins.DisplayLayerProgress - INFO - Store layer count in MetaFile
2021-02-03 17:43:06,082 - octoprint.plugins.DisplayLayerProgress - INFO - Read total height from MetaFile
2021-02-03 17:43:06,169 - octoprint.plugins.DisplayLayerProgress - INFO - Total height not found in MetaFile
2021-02-03 17:43:46,310 - octoprint.plugins.DisplayLayerProgress - INFO - Store layer count in MetaFile
2021-02-03 17:43:46,652 - octoprint.plugins.DisplayLayerProgress - INFO - Read total height from MetaFile
2021-02-03 17:43:47,649 - octoprint.filemanager.analysis - INFO - Analysis of entry local:CE3PRO_test.gcode finished, needed 42.45s
2021-02-03 17:43:47,946 - octoprint.plugins.DisplayLayerProgress - INFO - Store layer count in MetaFile
2021-02-03 17:43:48,167 - octoprint.plugins.DisplayLayerProgress - INFO - Read total height from MetaFile
2021-02-03 17:43:49,345 - octoprint.printer.standard.job - INFO - Print job selected - origin: local, path: CE3PRO_test.gcode, owner: _api, user: _api
2021-02-03 17:43:49,391 - octoprint.plugins.DisplayLayerProgress - INFO - File '/home/pi/.octoprint/uploads/CE3PRO_test.gcode' selected. Determining number of layers.
2021-02-03 17:43:49,524 - octoprint.util.comm - INFO - Changing monitoring state from "Operational" to "Starting"
2021-02-03 17:43:49,629 - octoprint.plugins.DisplayLayerProgress - INFO - Read total height from MetaFile
2021-02-03 17:43:49,652 - octoprint.printer.standard.job - INFO - Print job started - origin: local, path: CE3PRO_test.gcode, owner: _api, user: _api
2021-02-03 17:43:50,446 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2021-02-03 17:43:50,541 - octoprint.util.comm - INFO - Changing monitoring state from "Starting" to "Printing"
2021-02-03 17:43:52,900 - octoprint.util.comm - INFO - Printer seems to support the busy protocol, will adjust timeouts and set busy interval accordingly
2021-02-03 17:43:58,516 - octoprint.plugins.DisplayLayerProgress - INFO - Store layer count in MetaFile
2021-02-03 17:43:58,723 - octoprint.plugins.DisplayLayerProgress - INFO - File select-event processing done!'
2021-02-03 17:43:59,098 - octoprint.plugins.DisplayLayerProgress - INFO - Printing started. Detailed progress started.{u'origin': u'local', u'name': u'CE3PRO_test.gcode', u'user': u'_api', u'owner': u'_api', u'path': u'CE3PRO_test.gcode', u'size': 2215826L}
2021-02-03 17:43:59,779 - octoprint.plugins.tracking - INFO - Sent tracking event print_started, payload: {u'origin': u'local', u'file': 'd41210ec150a8ff6fb252898f06be2e31071873a'}
2021-02-03 17:44:53,409 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2021-02-03 17:45:34,732 - octoprint.util.comm - INFO - Telling the printer to set the busy interval to our "communicationBusy" timeout - 1s = 2s
2021-02-03 17:46:03,189 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 9984}
2021-02-03 17:49:14,045 - octoprint.util.comm - INFO - Ignoring resend request for line 265 == current line, we haven't sent that yet so the printer got N-1 twice from us, probably due to a timeout
2021-02-03 17:53:14,788 - octoprint.util.comm - INFO - Ignoring resend request for line 647 == current line, we haven't sent that yet so the printer got N-1 twice from us, probably due to a timeout
2021-02-03 17:56:23,916 - octoprint.util.comm - INFO - Ignoring resend request for line 1308 == current line, we haven't sent that yet so the printer got N-1 twice from us, probably due to a timeout
2021-02-03 17:57:27,745 - octoprint.util.comm - INFO - Ignoring resend request for line 1402 == current line, we haven't sent that yet so the printer got N-1 twice from us, probably due to a timeout
2021-02-03 17:59:53,423 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2021-02-03 18:01:03,266 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 10884}
2021-02-03 18:12:46,018 - octoprint.server.util.flask - INFO - Passively logging in user _api from ::ffff:192.168.0.100
2021-02-03 18:12:46,033 - octoprint.access.users - INFO - Logged in user: _api
2021-02-03 18:13:13,921 - octoprint.util.comm - INFO - Ignoring resend request for line 2874 == current line, we haven't sent that yet so the printer got N-1 twice from us, probably due to a timeout
2021-02-03 18:14:53,438 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2021-02-03 18:16:03,583 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 11784}
2021-02-03 18:18:27,534 - octoprint.server.views - WARNING - Client requested cache refresh via cache-control headers but we are printing. Not invalidating caches due to resource limitation. Append ?_refresh=true to the URL if you absolutely require a refresh now
2021-02-03 18:26:43,484 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.0.100
2021-02-03 18:29:53,448 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2021-02-03 18:31:03,329 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 12684}
2021-02-03 18:31:10,170 - octoprint.util.comm - INFO - Ignoring resend request for line 5960 == current line, we haven't sent that yet so the printer got N-1 twice from us, probably due to a timeout
2021-02-03 18:34:42,951 - octoprint.util.comm - INFO - Ignoring resend request for line 6706 == current line, we haven't sent that yet so the printer got N-1 twice from us, probably due to a timeout
2021-02-03 18:36:36,140 - octoprint.util.comm - INFO - Got a resend request from the printer: requested line = 7122, current line = 7123
| Last lines in terminal:
| Recv: ok
| Send: N7114 G3 X169.286 Y116.028 I-7.663 J6.119 E3618.7914127
| Recv: ok
| Send: N7115 G3 X168.962 Y120.378 I-9.71 J1.465 E3618.99616117
| Recv: ok
| Send: N7116 G3 X166.781 Y124.162 I-9.391 J-2.894 E3619.20123101
| Recv: ok
| Send: N7117 G3 X162.48 Y126.862 I-7.197 J-6.685 E3619.4403492
| Recv: ok
| Send: N7118 G3 X159.588 Y127.296 I-2.898 J-9.46 E3619.5769984
| Recv: ok
| Send: N7119 G1 X153.062 Y127.297 E3619.8809297
| Recv: ok
| Send: N7120 G2 X137.539 Y131.592 I0 J30.196 E3620.6399771
| Recv: ok
| Send: N7121 G1 X84.227 Y163.547 E3623.5342288
| Recv: T:209.37 /210.00 B:60.00 /60.00 @:83 B@:34
| Recv: ok
| Send: N7122 G1 X83.492 Y163.954 E3623.5733494
| Recv: Resend: 7122
2021-02-03 18:36:36,248 - octoprint.util.comm - INFO - Got a resend request from the printer: requested line = 7123, current line = 7125
| Recv: ok
| Recv: ok
| Recv: ok
| Recv: ok
| Recv: ok
| Recv: Resend: 7122
| Recv: ok
| Recv: ok
| Send: N7123 G0 F9750 X83.293 Y163.56268
| Recv: ok
| Send: N7124 G0 X83.029 Y163.6430
| Recv: Error:Line Number is not Last Line Number+1, Last Line: 7122
| Recv: Resend: 7123
2021-02-03 18:44:53,469 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2021-02-03 18:46:03,440 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 13584}
2021-02-03 18:48:44,628 - octoprint.util.comm - INFO - Ignoring resend request for line 11272 == current line, we haven't sent that yet so the printer got N-1 twice from us, probably due to a timeout
2021-02-03 18:50:11,054 - octoprint.util.comm - INFO - Got a resend request from the printer: requested line = 12253, current line = 12255
| Recv: ok
| Send: N12247 G3 X159.574 Y126.897 I-2.77 J-9.085 E850.9040293
| Recv: ok
| Send: N12248 G1 X153.058 Y126.897 E851.20744111
| Recv: ok
| Send: N12249 G2 X137.337 Y131.247 I0.004 J30.595 E851.9761683
| Recv: T:209.37 /210.00 B:60.00 /60.00 @:81 B@:35
| Recv: ok
| Send: N12250 G1 X84.033 Y163.197 E854.8699995
| Recv: ok
| Send: N12251 G1 X83.302 Y163.602 E854.9089108
| Recv: ok
| Send: N12252 G0 F9750 X83.492 Y163.954123
| Recv: ok
| Send: N12253 G3 X77.843 Y165.296 I-5.594 J-10.981 E855.18178 F195012
| Recv: echo:Unknown command: "12253 G3 X77.843 Y165.296 I-5.594 J-10.981 E855.18178 F1950"
| Recv: ok
| Send: N12254 G3 X72.209 Y163.9 I0.055 J-12.28 E855.45453*127
| Recv: Error:Line Number is not Last Line Number+1, Last Line: 12252
| Recv: Resend: 12253
2021-02-03 18:57:31,221 - octoprint.util.comm - INFO - Got a resend request from the printer: requested line = 15091, current line = 15092
Ender 3 Pro V4.2.2 with Marlin 2.0.7.2
Octopi (latest) on Raspberry 1 B+ overlocked to 1ghz,
OS running from USB drive
webcam (old, slow, low quality)
Plugins:
Dashboard (1.17.0)
DisplayLayerProgress Plugin (1.25.3) only for send to printer screen progress %, left time
PrintTimeGenius Plugin (2.2.7)
Themeify (1.2.2)
Slicer: latest Cura with ArcWelds
