After installing Octoprint 1.5.0 RC2 (this was the first 1.5.0 RC I tried. I was on 1.4 2 previously) The PSU Control plugin does not save settings. Settings like Switching Method, revert to default after a restart of Octoprint.
Problem exists with 1.5.0 RC3 too
Looked through the code but got lost. Not sure where/when settings are stored/retrieved
Complete Logs
octoprint.log
, serial.log
or output on terminal tab at a minimum, browser error console if UI issue ... no logs, no support! Not log excerpts, complete logs.)
octoprint.log (2.0 MB) serial.log (148 Bytes)
Octoprint 1.5.0 RC3
Octopi Version 0.18.0, running on Raspberry Pi 4 Model B Rev 1.4
SYSTEM INFO
browser.user_agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/86.0.4240.198 Safari/537.36 Edg/86.0.622.69
connectivity.connection_check: 8.8.8.8:53
connectivity.enabled: true
connectivity.online: true
env.hardware.cores: 4
env.hardware.freq: 1500
env.hardware.ram: 8140840960
env.os.bits: 64
env.os.id: linux
env.os.platform: linux
env.plugins.pi_support.model: Raspberry Pi 4 Model B Rev 1.4
env.python.pip: 20.2.4
env.python.version: 3.7.3
env.python.virtualenv: true
octoprint.safe_mode: false
octoprint.version: 1.5.0rc3
