Qidi X-plus connect but dont work
I installed the octoprint, and connect my RPI4 in the mother board using a URAT/USB on it, the octorprint connected to my printer, but I try to send any command, like to move x or print and printer don't do nothing.
Reinstalled everything, tried some tutorials
Complete Logs
2020-07-23 00:23:45,010 - octoprint.startup - INFO - Starting OctoPrint 1.4.0
2020-07-23 00:23:45,010 - octoprint.startup - INFO - ******************************************************************************
2020-07-23 00:23:45,472 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2020-07-23 00:23:46,445 - octoprint.plugin.core - INFO - Found 18 plugin(s) providing 16 mixin implementations, 32 hook handlers
2020-07-23 00:23:46,569 - octoprint.server.heartbeat - INFO - Starting server heartbeat, 900.0s interval
2020-07-23 00:23:46,595 - octoprint.server - INFO - Intermediary server started
2020-07-23 00:23:46,596 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2020-07-23 00:23:46,662 - octoprint.plugin.core - INFO - Found 18 plugin(s) providing 16 mixin implementations, 32 hook handlers
2020-07-23 00:23:46,680 - octoprint.filemanager.storage - INFO - Initializing the file metadata for /home/pi/.octoprint/uploads...
2020-07-23 00:23:46,919 - octoprint.filemanager.storage - INFO - ... file metadata for /home/pi/.octoprint/uploads initialized successfully.
2020-07-23 00:23:46,922 - octoprint.server - INFO - Added new permission from plugin action_command_prompt: PLUGIN_ACTION_COMMAND_PROMPT_INTERACT (needs: u"Need(method='role', value=u'plugin_action_command_prompt_interact')")
2020-07-23 00:23:46,922 - octoprint.server - INFO - Added new permission from plugin announcements: PLUGIN_ANNOUNCEMENTS_READ (needs: u"Need(method='role', value=u'plugin_announcements_read')")
2020-07-23 00:23:46,923 - octoprint.server - INFO - Added new permission from plugin announcements: PLUGIN_ANNOUNCEMENTS_MANAGE (needs: u"Need(method='role', value=u'plugin_announcements_manage'), Need(method='role', value=u'plugin_announcements_read')")
2020-07-23 00:23:46,924 - octoprint.server - INFO - Added new permission from plugin appkeys: PLUGIN_APPKEYS_ADMIN (needs: u"Need(method='role', value=u'plugin_appkeys_admin')")
2020-07-23 00:23:46,925 - octoprint.server - INFO - Added new permission from plugin backup: PLUGIN_BACKUP_ACCESS (needs: u"Need(method='role', value=u'plugin_backup_access')")
2020-07-23 00:23:46,926 - octoprint.server - INFO - Added new permission from plugin logging: PLUGIN_LOGGING_MANAGE (needs: u"Need(method='role', value=u'plugin_logging_manage')")
2020-07-23 00:23:46,926 - octoprint.server - INFO - Added new permission from plugin pi_support: PLUGIN_PI_SUPPORT_STATUS (needs: u"Need(method='role', value=u'plugin_pi_support_check')")
2020-07-23 00:23:46,928 - octoprint.server - INFO - Added new permission from plugin pluginmanager: PLUGIN_PLUGINMANAGER_MANAGE (needs: u"Need(method='role', value=u'plugin_pluginmanager_manage')")
2020-07-23 00:23:46,928 - octoprint.server - INFO - Added new permission from plugin pluginmanager: PLUGIN_PLUGINMANAGER_INSTALL (needs: u"Need(method='role', value=u'plugin_pluginmanager_install'), Need(method='role', value=u'plugin_pluginmanager_manage')")
2020-07-23 00:23:46,930 - octoprint.server - INFO - Added new permission from plugin printer_safety_check: PLUGIN_PRINTER_SAFETY_CHECK_DISPLAY (needs: u"Need(method='role', value=u'plugin_printer_safety_check_display')")
2020-07-23 00:23:46,931 - octoprint.server - INFO - Added new permission from plugin softwareupdate: PLUGIN_SOFTWAREUPDATE_CHECK (needs: u"Need(method='role', value=u'plugin_softwareupdate_check')")
2020-07-23 00:23:46,931 - octoprint.server - INFO - Added new permission from plugin softwareupdate: PLUGIN_SOFTWAREUPDATE_UPDATE (needs: u"Need(method='role', value=u'plugin_softwareupdate_update')")
2020-07-23 00:23:46,971 - octoprint.plugins.softwareupdate - INFO - Loaded version cache from disk
2020-07-23 00:23:46,974 - octoprint.plugins.fixcbdfirmware - INFO - Plugin active, working around broken 'CBD make it' firmware
2020-07-23 00:23:47,698 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2020-07-23 00:23:48,280 - octoprint.util.pip - INFO - Version of pip is 19.3.1
2020-07-23 00:23:48,281 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2020-07-23 00:23:48,282 - octoprint.util.pip - INFO - ==> pip ok -> yes
2020-07-23 00:23:48,286 - octoprint.plugin.core - INFO - Initialized 16 plugin implementation(s)
2020-07-23 00:23:48,292 - octoprint.plugin.core - INFO - 18 plugin(s) registered with the system:
| Fix CBD Firmware Plugin (0.3.0) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_fixcbdfirmware
| Login UI (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/loginui
| Rewrite wait to busy = /home/pi/.octoprint/plugins/rewrite_wait_to_busy.py
| Strip M110 Parameters = /home/pi/.octoprint/plugins/strip_m110_parameter.py
2020-07-23 00:23:48,305 - octoprint.environment - INFO - Detected environment is Python 2.7.16 under Linux (linux2). Details:
| hardware:
| cores: 4
| freq: 1500.0
| ram: 3960000512
| os:
| platform: linux2
| plugins:
| pi_support:
| model: Raspberry Pi 4 Model B Rev 1.1
| octopi_version: 0.17.0
| python:
| pip: 19.3.1
| version: 2.7.16
| virtualenv: /home/pi/oprint
2020-07-23 00:23:48,313 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/webassets...
2020-07-23 00:23:48,329 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/.webassets-cache...
2020-07-23 00:23:48,765 - octoprint.server - INFO - Shutting down intermediary server...
2020-07-23 00:23:49,103 - octoprint.server - INFO - Intermediary server shut down
2020-07-23 00:23:49,105 - octoprint.events - INFO - Processing startup event, this is our first event
2020-07-23 00:23:49,106 - octoprint.events - INFO - Adding 0 events to queue that were held back before startup event
2020-07-23 00:23:49,107 - octoprint.filemanager - INFO - Adding backlog items from all storage types to analysis queue...
2020-07-23 00:23:49,108 - octoprint.server - INFO - Autoconnect on startup is configured, trying to connect to the printer...
2020-07-23 00:23:49,109 - octoprint.filemanager - INFO - Added 0 items from storage type "local" to analysis queue
2020-07-23 00:23:49,136 - octoprint.server - INFO - Trying to connect to configured serial port AUTO
2020-07-23 00:23:49,160 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Detecting serial port"
2020-07-23 00:23:49,165 - octoprint.server.util.watchdog - INFO - Running initial scan on watched folder...
2020-07-23 00:23:49,170 - octoprint.server.util.watchdog - INFO - ... initial scan done.
2020-07-23 00:23:49,176 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance on octopi' for _http._tcp
2020-07-23 00:23:49,184 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance on octopi' for _octoprint._tcp
2020-07-23 00:23:49,209 - octoprint.server - INFO - Listening on http://127.0.0.1:5000
2020-07-23 00:23:49,274 - octoprint.util.comm - INFO - Changing monitoring state from "Detecting serial port" to "Opening serial port"
2020-07-23 00:23:49,285 - octoprint.util.comm - INFO - Changing monitoring state from "Opening serial port" to "Detecting baudrate"
2020-07-23 00:23:49,339 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2020-07-23 00:23:50,013 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2020-07-23 00:23:50,156 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2020-07-23 00:23:50,176 - octoprint.util.pip - INFO - ==> pip ok -> yes
2020-07-23 00:23:50,336 - octoprint.plugins.fixcbdfirmware - INFO - Replacing M110 with M110
2020-07-23 00:23:50,357 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2020-07-23 00:23:50,480 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2020-07-23 00:23:51,066 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2020-07-23 00:23:51,085 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2020-07-23 00:23:53,193 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages/ (writable -> yes), --user flag needed -> no, virtual env -> yes
2020-07-23 00:23:53,193 - octoprint.util.pip - INFO - ==> pip ok -> yes
2020-07-23 00:23:53,208 - octoprint.plugins.softwareupdate - INFO - Saved version cache to disk
2020-07-23 00:23:53,279 - octoprint.server.preemptive_cache - INFO - Preemptively caching / (ui _default) for {'query_string': 'l10n=en', 'path': '/', 'base_url': 'https://octopi.local/'}
2020-07-23 00:23:57,524 - octoprint.server.preemptive_cache - INFO - ... done in 4.24s
2020-07-23 00:23:57,524 - octoprint.server.preemptive_cache - INFO - Preemptively caching / (ui _default) for {'query_string': 'l10n=en', 'path': '/', 'base_url': 'http://192.168.22.188/'}
2020-07-23 00:23:58,422 - octoprint.server.preemptive_cache - INFO - ... done in 0.90s
2020-07-23 00:24:00,328 - octoprint.plugins.fixcbdfirmware - INFO - Replacing M110 with M110
2020-07-23 00:24:00,329 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2020-07-23 00:24:01,334 - octoprint.plugins.fixcbdfirmware - INFO - Replacing M110 with M110
2020-07-23 00:24:01,335 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2020-07-23 00:24:02,178 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.5.241
2020-07-23 00:24:02,241 - octoprint.server.util.flask - INFO - Passively logging in user qidi from ::ffff:192.168.5.241
2020-07-23 00:24:02,243 - octoprint.access.users - INFO - Logged in user: qidi
2020-07-23 00:24:02,289 - octoprint.server.util.sockjs - INFO - User qidi logged in on the socket from client ::ffff:192.168.5.241
2020-07-23 00:24:02,338 - octoprint.plugins.fixcbdfirmware - INFO - Replacing M110 with M110
2020-07-23 00:24:02,339 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2020-07-23 00:24:03,341 - octoprint.plugins.fixcbdfirmware - INFO - Replacing M110 with M110
2020-07-23 00:24:03,342 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2020-07-23 00:24:04,353 - octoprint.plugins.fixcbdfirmware - INFO - Replacing M110 with M110
2020-07-23 00:24:04,355 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2020-07-23 00:24:05,358 - octoprint.plugins.fixcbdfirmware - INFO - Replacing M110 with M110
2020-07-23 00:24:05,358 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2020-07-23 00:24:06,366 - octoprint.plugins.fixcbdfirmware - INFO - Replacing M110 with M110
2020-07-23 00:24:06,369 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2020-07-23 00:24:07,365 - octoprint.plugins.fixcbdfirmware - INFO - Replacing M110 with M110
2020-07-23 00:24:07,367 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2020-07-23 00:24:08,374 - octoprint.plugins.fixcbdfirmware - INFO - Replacing M110 with M110
2020-07-23 00:24:08,377 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2020-07-23 00:24:09,379 - octoprint.plugins.fixcbdfirmware - INFO - Replacing M110 with M110
2020-07-23 00:24:09,381 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2020-07-23 00:24:10,382 - octoprint.plugins.fixcbdfirmware - INFO - Replacing M110 with M110
2020-07-23 00:24:10,384 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2020-07-23 00:24:11,392 - octoprint.plugins.fixcbdfirmware - INFO - Replacing M110 with M110
2020-07-23 00:24:11,394 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2020-07-23 00:24:12,395 - octoprint.plugins.fixcbdfirmware - INFO - Replacing M110 with M110
2020-07-23 00:24:12,400 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2020-07-23 00:46:11,242 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-07-23 00:46:11,272 - octoprint.util.connectivity_checker - INFO - Connectivity changed from offline to online
2020-07-23 00:46:11,366 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2020-07-23 00:46:11,924 - octoprint.plugins.fixcbdfirmware - INFO - Replacing M110 with M110
2020-07-23 00:46:11,937 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2020-07-23 00:46:12,556 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 26}
2020-07-23 00:46:12,593 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2020-07-23 00:46:12,894 - octoprint.plugins.fixcbdfirmware - INFO - Replacing M110 with M110
2020-07-23 00:46:12,894 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2020-07-23 00:46:13,144 - octoprint.plugins.softwareupdate - INFO - Saved version cache to disk
2020-07-23 00:46:13,903 - octoprint.plugins.fixcbdfirmware - INFO - Replacing M110 with M110
2020-07-23 00:46:13,904 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2020-07-23 00:46:14,906 - octoprint.plugins.fixcbdfirmware - INFO - Replacing M110 with M110
2020-07-23 00:46:14,907 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2020-07-23 00:46:15,910 - octoprint.plugins.fixcbdfirmware - INFO - Replacing M110 with M110
2020-07-23 00:46:15,911 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2020-07-23 00:46:16,919 - octoprint.plugins.fixcbdfirmware - INFO - Replacing M110 with M110
2020-07-23 00:46:16,921 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2020-07-23 00:46:17,934 - octoprint.plugins.fixcbdfirmware - INFO - Replacing M110 with M110
2020-07-23 00:46:17,935 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2020-07-23 00:46:18,952 - octoprint.plugins.fixcbdfirmware - INFO - Replacing M110 with M110
2020-07-23 00:46:18,955 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2020-07-23 00:46:19,969 - octoprint.plugins.fixcbdfirmware - INFO - Replacing M110 with M110
2020-07-23 00:46:19,970 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2020-07-23 00:46:20,984 - octoprint.plugins.fixcbdfirmware - INFO - Replacing M110 with M110
2020-07-23 00:46:20,986 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2020-07-23 00:46:22,000 - octoprint.plugins.fixcbdfirmware - INFO - Replacing M110 with M110
2020-07-23 00:46:22,002 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2020-07-23 00:46:23,019 - octoprint.plugins.fixcbdfirmware - INFO - Replacing M110 with M110
2020-07-23 00:46:23,022 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2020-07-23 00:46:24,040 - octoprint.plugins.fixcbdfirmware - INFO - Replacing M110 with M110
2020-07-23 00:46:24,043 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
Rpi4b 4gb, last version of octorint/pi
It was a problem with the cable, I changed it and worked. #closed
Great. So could you please:
