couldnt fetch plugin on my brand new raspberry pi 4 with lastest stable octopi build
reinstall twice, try to install pip manually,
try to curl https://octoprint.org/feeds/octopi.xml, https://plugins.octoprint.org and both works on my octopi
nslookup
Server: 192.168.42.1
Address: 192.168.42.1#53Non-authoritative answer:
Address: 207.154.233.48pi@octoprint:~/.octoprint/logs $ nslookup
plugins.octoprint.org8.8.8.8
Server: 8.8.8.8
Address: 8.8.8.8#53Non-authoritative answer:
pi@octoprint:~/.octoprint/logs $ wget
https://plugins.octoprint.org/plugins.json
--2019-12-17 00:12:10-- https://plugins.octoprint.org/plugins.json
Resolvingplugins.octoprint.org(plugins.octoprint.org)... 207.154.233.48
Connecting toplugins.octoprint.org
(plugins.octoprint.org)|207.154.233.48|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 123323 (120K) [application/json]
Saving to: ‘plugins.json’plugins.json 100%[==================================================================================================================>] 120.43K --.-KB/s in 0.06s
2019-12-17 00:12:11 (1.90 MB/s) - ‘plugins.json’ saved [123323/123323]
Logs
2019-12-16 23:56:30,254 - octoprint.plugins.pluginmanager - ERROR - Could not fetch plugins from repository at https://plugins.octoprint.org/plugins.json: HTTPSConnectionPool(host='plugins.octoprint.org', p$
File "/home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/pluginmanager/__init__.py", line 823, in _fetch_repository_from_url
r = requests.get(repository_url, timeout=30)
File "/home/pi/oprint/local/lib/python2.7/site-packages/requests/api.py", line 75, in get
return request('get', url, params=params, **kwargs)
File "/home/pi/oprint/local/lib/python2.7/site-packages/requests/api.py", line 60, in request
return session.request(method=method, url=url, **kwargs)
File "/home/pi/oprint/local/lib/python2.7/site-packages/requests/sessions.py", line 533, in request
resp = self.send(prep, **send_kwargs)
File "/home/pi/oprint/local/lib/python2.7/site-packages/requests/sessions.py", line 646, in send
r = adapter.send(request, **kwargs)
File "/home/pi/oprint/local/lib/python2.7/site-packages/requests/adapters.py", line 516, in send
raise ConnectionError(e, request=request)
ConnectionError: HTTPSConnectionPool(host='plugins.octoprint.org', port=443): Max retries exceeded with url: /plugins.json (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object a$
2019-12-16 23:56:30,258 - octoprint.plugins.announcements - ERROR - Could not fetch channel _important from https://octoprint.org/feeds/important.xml: HTTPSConnectionPool(host='octoprint.org', port=443): Ma$
File "/home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/announcements/__init__.py", line 355, in _get_channel_data_from_network
r = requests.get(url, timeout=30)
ConnectionError: HTTPSConnectionPool(host='octoprint.org', port=443): Max retries exceeded with url: /feeds/important.xml (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at$
2019-12-16 23:56:30,264 - octoprint.plugins.pluginmanager - ERROR - Could not fetch notices from `https://plugins.octoprint.org/notices.json`: HTTPSConnectionPool(host='plugins.octoprint.org', port=443): Max $
File "/home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/pluginmanager/__init__.py", line 891, in _fetch_notices_from_url
r = requests.get(notices_url, timeout=30)
ConnectionError: HTTPSConnectionPool(host='plugins.octoprint.org', port=443): Max retries exceeded with url: /notices.json (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object a$
2019-12-16 23:56:30,267 - octoprint.plugins.announcements - ERROR - Could not fetch channel _releases from https://octoprint.org/feeds/releases.xml: HTTPSConnectionPool(host='octoprint.org', port=443): Max $
ConnectionError: HTTPSConnectionPool(host='plugins.octoprint.org', port=443): Max retries exceeded with url: /feed.xml (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x$
2019-12-16 23:56:30,289 - octoprint.plugins.announcements - ERROR - Could not fetch channel _octopi from https://octoprint.org/feeds/octopi.xml: HTTPSConnectionPool(host='octoprint.org', port=443): Max retr$
ConnectionError: HTTPSConnectionPool(host='octoprint.org', port=443): Max retries exceeded with url: /feeds/octopi.xml (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x$
2019-12-16 23:56:30,808 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2019-12-16 23:56:30,809 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2019-12-16 23:56:30,809 - octoprint.util.pip - INFO - ==> pip ok -> yes
2019-12-16 23:56:46,535 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.42.58) 23.42ms
2019-12-16 23:56:46,563 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.42.58) 8.07ms
2019-12-16 23:57:07,015 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.42.58) 8.11ms
2019-12-16 23:57:07,047 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.42.58) 7.99ms
2019-12-16 23:57:07,060 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.42.58) 8.25ms
2019-12-16 23:57:07,073 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.42.58) 8.05ms
2019-12-16 23:57:07,087 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.42.58) 8.44ms
brand new install on the rpi4
i looks through the forum and google and couldnt find a lot of info on raspberry4 error ... i don't understand and sad!
