Raspberry Pi Partition Issue
Hi! Keep getting this issue when trying to turn on Raspberry Pi with Octopi installed on it. I installed Raspberry Pi OS on the same SD card to check if it was a hardware issue, but the Raspberry Pi OS worked fine. Has anyone had this issue in the past, and if so how did you fix it?
Thank you!
image|690x374
The 8GB Pi isn't officially supported right now.
You may want to try my beta image
Works perfectly, thank you!
I just found out the same issue after buying a pi4 8gb it would not boot octopi. currently testing your beta
