Hi! Keep getting this issue when trying to turn on Raspberry Pi with Octopi installed on it. I installed Raspberry Pi OS on the same SD card to check if it was a hardware issue, but the Raspberry Pi OS worked fine. Has anyone had this issue in the past, and if so how did you fix it?
Thank you!
image|690x374
