Reverse proxy on a RPi with RPi_Cam_Web_Interface installed
So I've got everything "working". http://prusa.local:5001/ goes to OctoPrint and http://prusa.local/camera/index.php goes to my camera. All very nifty. Even got OctoPrint to take imput from the camera just fine (though it sometimes has issues when I've not logged in to the camera page for a while - anyone know how to tell Ocotprint how to login to the camera page?) But currently just trying to get the reverse proxy running.
RPi_Cam_Web_Interface creates a /etc/nginx/sites-available/rpicam file and a redirect to it at /etc/nginx/sites-enabled/rpicam (would love to know how to create these myself) with the following contents:
server {
	listen   80;
	listen   [::]:80;
	root /var/www;
	index index.php index.html index.htm;
	server_name localhost;
	location / {
		try_files $uri $uri/ /index.html;
    location ~ [^/]\.php(/|$) {
            fastcgi_split_path_info ^(.+?\.php)(/.*)$;
            if (!-f $document_root$fastcgi_script_name) {
                    return 404;
            fastcgi_pass unix:/var/run/php5-fpm.sock;
            fastcgi_index index.php;
            include fastcgi_params;
            fastcgi_param SCRIPT_FILENAME $document_root/$fastcgi_script_name;
			fastcgi_param REMOTE_USER $remote_user;
            auth_basic "Off";
            #auth_basic_user_file /usr/local/.htpasswd;
	location ~ /\.ht {
		deny all;
I've looked at a few reverse proxy examples, such as (from https://esmer-games.github.io/12-12-2018-octoprint-nginx-motion/);
server {
  # webcam port, optional.
  location /webcam {
    proxy_pass http://localhost:8081;
  location /octoprint/ {
    proxy_pass http://localhost:5000/;
    proxy_set_header Host $http_host;
    proxy_set_header Upgrade $http_upgrade;
    proxy_set_header Connection "upgrade";
    proxy_set_header X-Real-IP $remote_addr;
    proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
    proxy_set_header X-Scheme $scheme;
    proxy_set_header X-Script-Name /octoprint;
    proxy_http_version 1.1;
    client_max_body_size 0;
and (from https://community.octoprint.org/t/reverse-proxy-configuration-examples/1107)
    worker_processes  1;
    events {
        worker_connections  1024;
    http {
        include            mime.types;
        default_type       application/octet-stream;
        sendfile           on;
        keepalive_timeout  65;
        map $http_upgrade $connection_upgrade {
            default upgrade;
            '' close;
        upstream "octoprint" {
            server 127.0.0.1:5000;
        upstream "mjpg-streamer" {
            server 127.0.0.1:8080;
        server {
            listen       80;
            location / {
                proxy_pass http://octoprint/;
            location /webcam/ {
                proxy_pass http://mjpg-streamer/;
            # redirect server error pages to the static page /50x.html
            error_page   500 502 503 504  /50x.html;
            location = /50x.html {
                root   html;
but I'm not sure what to do to keep the functionality the original has, but add Octoprint to it.
