Revert to previous version with image file
I have installed 1.9.2 but now Better Grbl Support is not working anymore. When I revert to 1.8.2 the server works with windows but not anymore iPad. It gives a network problem. Always worked before.
I tried several times to reinstall but always exact the same problem.
Better GRBL does not run in safe mode
Na
OctoPrint version, OctoPi version, printer, firmware, browser, operating system, ... **as much data as possibl
Octoprint on raspberry Pi 4 running on GRBL cnc machine.
You can try it this way
But I would recommend to back everything up before you try it - just in case something brakes.
Great, it worked fabulous. It's all working again with the older version.
Hopefully "better grbl support" will be upgraded soon to be compatible again.
Thanks,
Ton
