The Octopi server no longer runs after trying to add ArcWelder plugin. When trying to login I am greeted with " The OctoPrint server is currently not running"
I tried the advice given on the page with the above greeting and eventually ssh'd into the Pi and looked at the logs, most of which means nothing to me. However an error is reported in connection with the ArcWelder plugin which makes me suspect that it is not compatible.
Yes, by running,
sudo service octoprint stop
sudo ~/oprint/bin/octoprint serve --safe
which showed a lot of text ending with
ValueError: bad marshal data (string ref out of range)
Safe mode did not start.
Complete Logs
octoprint.log
, serial.log
or output on terminal tab at a minimum, browser error console if UI issue ... no logs, no support! Not log excerpts, complete logs.)
######## Octoprint.log ############
2021-03-02 17:19:12,799 - octoprint.plugin.core - ERROR - Error loading plugin logging
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/plugin/core.py", line 1298, in _import_plugin
module = _load_module(module_name, spec)
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/plugin/core.py", line 69, in _load_module
return imp.load_module(name, f, filename, details)
File "/home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/logging/__init__.py", line 19, in <module>
from octoprint.server import NO_CONTENT
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/server/__init__.py", line 48, in <module>
from octoprint.server import util
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/server/util/__init__.py", line 24, in <module>
from . import flask, sockjs, tornado, watchdog # noqa: F401
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/server/util/flask.py", line 23, in <module>
import tornado.web
File "/home/pi/oprint/local/lib/python2.7/site-packages/tornado/web.py", line 95, in <module>
from tornado.routing import (AnyMatches, DefaultHostMatches, HostMatches,
File "/home/pi/oprint/local/lib/python2.7/site-packages/tornado/routing.py", line 184, in <module>
from tornado.httpserver import _CallableAdapter
File "/home/pi/oprint/local/lib/python2.7/site-packages/tornado/httpserver.py", line 33, in <module>
from tornado.http1connection import HTTP1ServerConnection, HTTP1ConnectionParameters
2021-03-02 17:19:13,255 - octoprint.startup - INFO - Added settings overlay from plugin firmware_check
2021-03-02 17:19:13,258 - octoprint.plugin.core - INFO - Found 14 plugin(s) providing 10 mixin implementations, 17 hook handlers
2021-03-02 17:19:13,374 - octoprint.cli.server - ERROR - Uncaught exception
File "/home/pi/oprint/bin/octoprint", line 8, in <module>
sys.exit(main())
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/__init__.py", line 939, in main
octo(args=args, prog_name="octoprint", auto_envvar_prefix="OCTOPRINT")
File "/home/pi/oprint/local/lib/python2.7/site-packages/click/core.py", line 829, in __call__
return self.main(*args, **kwargs)
File "/home/pi/oprint/local/lib/python2.7/site-packages/click/core.py", line 782, in main
rv = self.invoke(ctx)
File "/home/pi/oprint/local/lib/python2.7/site-packages/click/core.py", line 1259, in invoke
return _process_result(sub_ctx.command.invoke(sub_ctx))
File "/home/pi/oprint/local/lib/python2.7/site-packages/click/core.py", line 1066, in invoke
return ctx.invoke(self.callback, **ctx.params)
File "/home/pi/oprint/local/lib/python2.7/site-packages/click/core.py", line 610, in invoke
return callback(*args, **kwargs)
File "/home/pi/oprint/local/lib/python2.7/site-packages/click/decorators.py", line 21, in new_func
return f(get_current_context(), *args, **kwargs)
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/cli/server.py", line 315, in serve_command
ignore_blacklist,
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/cli/server.py", line 144, in run_server
from octoprint.server import Server
import tornado.web
########### serial.log ##########
2021-01-30 17:39:50,155 - serial.log is currently not enabled, you can enable it via Settings > Serial Connection > Log communication to serial.log
octoprint 1.5.3
Don't Know
CTC Prusa I3 pro B (clone)
firmware 1.8.0 (I think)
Firefox 86.0 (64bit)
Ubuntu 20.04
