Yeah, just tested my dev box and don't see any issues with yawcam and stream. Assuming you have yawcam like this...
The only other thing I could think of is windows firewall settings blocking the connection.
I'm setting up a windows based system. What do you use to monitor remotely. Ideally with an iphone.
I used anaconda (conda) as virtual environment and it works fine too.
You need to
conda create --name octo_py27 python=2.7
activate octo_py27
pip install https://get.octoprint.org/latest
`octoprint serve
call <path_to_conda>\Anaconda3\Scripts\activate.bat <path_to_conda>\Anaconda3\envs\octo_py27
octoprint serve
pause
I use yawcam, and I have mine setup virtually that way except I had something else using port 8081 so I changed it and my stream link looks like this: http://192.168.0.111:2500/video.mjpg
I submitted and got a Raspberry Pi. But I'll try this, too. Thanks!
I have completed the installation procedure but got stuck on the last bit. When I execute octoprint serve my cmd keeps telling my 'We are not online'. I'm running my cmd as an administrator but still I get the same error.
Continuing the discussion from Setting up OctoPrint on Windows:
hi!
i have already tried to install Octoprint on Windows with the newest release of python 3.7.1rc1, but it didnt work.
i wanted to ask, if it in general possible? (maybe i have made some mistakes)
p.s Octoprint with python 2.7 works perfect!
thank u!
Hi Malinka!
So it should be.
first and For most AWESOME WORK! Octoprint is AMAZING!
I have been running it on a old windows laptop for a few months now, i cant believe how blazing fast it is compared on a my pi version.
So i am trying to setup a 2nd octoprint session on the same windows box. so i can run two or more printers at the same time, (theoretically this should be possible) as we can do it on a pi.
I created a new folder c:/octoprint2 and installed a second version of it.
The only issue i am running into is how would i go about changing the port number from 5000 to 5001
the only file that i see is netaddr but i am not seeing anything in it what would indicate a port address to modify.
any ideas would be helpful.
Niels
Danielkrah,
Thank you, for the info, but the key issue is i am running this via Windows running on python v2.
so doing it this way their is no ssh access to the session.
and the python folder dose not contain a config file for the octo print session, i assume its hiding somewhere and is accessible somehow.
the only thing i can find is the config.py
this dose not contain the octoprint config settings.
so
C:\OctoPrint\venv\Scripts\octoprint.exe serve --port=xxxx
doesn't work ?
That works sorta
C:\Octoprint2\venv\Scripts> .\octoprint.exe serve --port=5002
i can now access the session via port 5002, however it is the same session as port 5000 it dose not different session at all.
hmm.
what i did was re-install everything in a folder called octoprint 2.
any ideas?
It's probably worthwhile searching this forum (the magnifying glass in the upper-right corner) for "multiple". This topic has been discussed many times and you're missing the benefit of reading some of that commentary.
I got this message and that is strange:
OctoPrint>pip install //get.octoprint.org/latest
Downloading //get.octoprint.org/latest (5.3MB)
100% |ββββββββββββββββββββββββββββββββ| 5.4MB 788kB/s
OctoPrint requires Python '>=2.7.3,<3' but the running Python is 3.7.1
MUST I install the older version??
-; >= does mean Greater or Equal
Is there a way to add access control on a Windows setup like on this page? I can find a plugin or how to turn on access control like the pi version does.
@ Foosel
i want to do a Big shout out to Chris Riley, who just posted a video walk threw on setting this up with multiple instances.
Could you please make him a Sticky!
I had the same issue but it was just because http;// was missing before the IP address.
Is the 0.16.0 Update available for Windows as well?
Just tried to update with your recommended update instructions:
I get the message "Cache entry deserialization failed, entry ignored" after calling "pip install..."
