2020-02-03 20:00:12,922 - Connecting to: /dev/ttyACM0
2020-02-03 20:00:12,943 - Changing monitoring state from "Offline" to "Opening serial port"
2020-02-03 20:00:12,947 - Connected to: Serial<id=0xb0d72350, open=True>(port='/dev/ttyACM0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
2020-02-03 20:00:12,948 - Changing monitoring state from "Opening serial port" to "Connecting"
2020-02-03 20:00:42,992 - There was a timeout while trying to connect to the printer
2020-02-03 20:00:43,008 - Changing monitoring state from "Connecting" to "Offline"
2020-02-03 20:00:43,018 - Connection closed, closing down monitor
2020-02-03 20:02:24,953 - Connecting to: /dev/ttyACM0
2020-02-03 20:02:24,982 - Changing monitoring state from "Offline" to "Opening serial port"
2020-02-03 20:02:24,991 - Connected to: Serial<id=0xa7ea1e10, open=True>(port='/dev/ttyACM0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
2020-02-03 20:02:24,992 - Changing monitoring state from "Opening serial port" to "Connecting"
2020-02-03 20:02:55,027 - There was a timeout while trying to connect to the printer
2020-02-03 20:02:55,042 - Changing monitoring state from "Connecting" to "Offline"
2020-02-03 20:02:55,049 - Connection closed, closing down monitor
2020-02-03 20:04:29,834 - Connecting to: /dev/ttyACM0
2020-02-03 20:04:29,854 - Changing monitoring state from "Offline" to "Opening serial port"
2020-02-03 20:04:29,855 - Connected to: Serial<id=0xa7dee6b0, open=True>(port='/dev/ttyACM0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
2020-02-03 20:04:29,857 - Changing monitoring state from "Opening serial port" to "Connecting"
2020-02-03 20:04:59,899 - There was a timeout while trying to connect to the printer
2020-02-03 20:04:59,909 - Changing monitoring state from "Connecting" to "Offline"
2020-02-03 20:04:59,920 - Connection closed, closing down monitor
