Octopi cannot connect to my Ender 3 through usb.
When trying to connect through octopi.local all settings are on auto for connection but reads out this error: " Error: Failed to autodetect serial port, please set it manually "
I have tried restarting the pi and the printer and unplugging the USB connection to the printer and its still not getting a connection
2019-08-13 01:12:47,422 - serial.log is currently not enabled, you can enable it via Settings > Serial Connection > Log communication to serial.log
2019-08-13 01:14:39,800 - serial.log is currently not enabled, you can enable it via Settings > Serial Connection > Log communication to serial.log
2019-08-13 01:18:39,097 - Enabling serial logging
2019-08-13 01:18:41,876 - Changing monitoring state from "Offline" to "Detecting serial port"
2019-08-13 01:18:41,899 - Serial port list: []
2019-08-13 01:18:41,900 - Changing monitoring state from "Detecting serial port" to "Error: Failed to autodetect serial port, please set it manually."
2019-08-13 01:18:41,903 - Failed to autodetect serial port, please set it manually.
2019-08-13 01:18:46,402 - Changing monitoring state from "Offline" to "Detecting serial port"
2019-08-13 01:18:46,427 - Serial port list: []
2019-08-13 01:18:46,428 - Changing monitoring state from "Detecting serial port" to "Error: Failed to autodetect serial port, please set it manually."
2019-08-13 01:18:46,446 - Failed to autodetect serial port, please set it manually.
OctoPrint: 1.3.11, OctoPi version: 0.16.0, Ender 3, Th3d Unified Firmware, Google Crome
