Says stream url is empty, but its not + webcam issues
EDIT: fixed
I'm getting this in the Control tab with my Xbox 360 camera:
Webcam stream not loaded
It might not be
correctly configured. You can change the URL of the stream under "Settings" > "Webcam & Timelapse" > "Stream URL". If you don't have a webcam just set the URL to an empty value.
It was working 5 minutes ago, then froze. I'm on the latest Octopi. Here is my /var/log/webcamd.log:
logger: Starting USB webcam
Running ./mjpg_streamer -o output_http.so -w ./www-octopi -n -i input_uvc.so -r 640x480 -f 30
MJPG Streamer Version.: 2.0
 i: Frames Per Second.: 30
 i: Format............: JPEG
Unable to set format: 1196444237 res: 640x480
 i: init_VideoIn failed
My octopi.txt is all commented out (that's what it was by default). The stream url in settings is /webcam/?action=stream, which shows The webcam server is currently not running. In addition, the camera is shown is lsusb.
Fixed it with help from https://github.com/foosel/OctoPrint/wiki/Webcams-known-to-work - please delete this thread.
I could imagine this is something that others might run into, so I'd definitely not delete it. I've seen some posts here that get marked as solved with a link to the post that solved it, but I can't see how that's done.
Had to be fine by either the topic author or a mod. I've done it with some topics over the past couple days which definitely were solved but where the OP didn't seem to be interested into marking the solution.
@hkyq would be great if you could move your own "it's fixed" post as the solution - doesn't hurt, helps others :slight_smile:
Thought that might have been the case, so I looked at my own post in General to see if I could figure it out, but maybe that doesn't apply to topics in that category.
It's a category specific thing. "Mark as solved" is currently only enabled for "Get Help" and I think I also enabled it in "Plugins". Not sure if it would make sense in one of the others :thinking:
Yep, agreed. Thread hijack: complete.
Sorry, was away. How do I mark as solved?
edit: nevermind, I just added solved in the title
Marked it properly as solved. Just for the record:
The wiki has moved and therefore the link from the solution is no longer correct. Could someone put the updated link here again?
