For an unknown reason, Octoprint is trigerring a pause on my prints. The behavior really to be a M600 like command (putting the nozzle on Z+5 and X0) and perfoming a filament retraction for like 30mm (my CR-10 bowden tube). I checked the Gcode: No M600 command in it. I am actually to print the exact same file through USB.
Check the Gcode
Activate Serial logs (to ensure the issue was not ink to other threads)
On-going: Printing the same Gcode from SD
Next: Printing through Octoprint without any plugins activated.
I also tried several pausing conditions:
- Pausing from octoprint: the print is paused and the nozzle secured. The printer displays "Paused" and the filament is not pulled out. When resuming the print from octoprint, everything is starting back
- Pausing triggered by the filament sensor: I have exaclty the same behavior.
What's happening in my case: the job is paused AND the filament is pulled out. I absolutely need to click my CR10, first to reheat the nozzle. Once done, I need to click again to pull the filament in (and purge the nozzle) and finally I can either resume the print or perform another purge. Resuming the print from octoprint has no effect.
not yet tried
Complete Logs
octoprint.log: https://www.dropbox.com/s/il4bkgb94jdz411/octoprint%20(4).log?dl=0
serial.log: https://www.dropbox.com/s/tzk3i9mlxsht9um/serial%20(1).log?dl=0
Octoprint: 1.4.2
OctoPi: 0.17.0
Print: CR-10 v2
Running on: Marlin 2.0.7.2
