Continuing the discussion from Octoprint with sovol sv01? :
mine will not work but it think its because of something with the port. the rasberry pi and the printer are not talking and i tried to switch the cable but that did not work. if anyone else had this prolbem let me know please.
We could check if they pi communicates with the printer at all:
Log into your pi via ssh then disconnect your printer, connect it again, enter dmesg | tail -n 20 and post the output here.
If you need help with ssh connection, follow this guide
Most of the time with my Raspberry PI I remote in using VNC, this is good and I like using a GUI, however sometimes this can be cumbersome and time consuming. Today I will show you how to get a remote terminal (SSH) on your Raspberry PI. Whats even...
Est. reading time: 1 minute
username: pi
password: raspberry
i have an macbook dose that affect anthying?
not that much, you just have to establish the ssh connection in a different way
I have no experience with macos so all I can give you is the first guide I found on google - hope it helps
https://medium.com/@thedyslexiccoder/how-to-remotely-access-a-raspberry-pi-on-a-mac-via-ssh-be285d418f54
Ignore the first steps - ssh is already enabled on your pi.
You just need the part where you ssh into it
nvm i found the problem, i was using a power only micro usb, sorry for wasting your time. thanks for the help
Glad you got it working
Happy printing
system
Closed
April 15, 2024, 10:30pm
7
