When i click the start print bouton on octoprint the printer heats up (sometimes the bed heats up but the nosle refuses), the status is changed to printing in octoprint the progress bar moves but nothing happens on the printer. after this if i try to cancel the print octoprint becomes basicly unresponsive
tried in safe mode with gcode stored locally and son the Sd card.
the gcode works perfectly if i do everything manually without octoprint
OctoPi version : Version 0.18.0, running on Raspberry Pi 4 Model B Rev 1.2
Firmware : wanhao d12 230 dual bl touch TMC 2209
*Browser : tried with opera, chrome, edge and safari(ios)
*operating system : windows 10 and ios 15.4`Preformatted text
i use the latest version of cura with wanaho printer and material profiles. my printer is connected to one of the usb 3 ports of the rasberry pi via the original blue cable. the rasberry pi is connected via ethernet to my local network.
**here is my terminal when starting a print in safe mode**
Changing monitoring state from "Offline" to "Opening serial connection"
Connecting to port /dev/ttyUSB0, baudrate 115200
Changing monitoring state from "Opening serial connection" to "Connecting"
Connected to: Serial(port='/dev/ttyUSB0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
Send: N0 M110 N0*125
Recv: ok
Changing monitoring state from "Connecting" to "Operational"
Recv: ok
Recv: ok
Send: N1 M115*39
Recv: FIRMWARE_NAME:Marlin 1.0.0 (Github) SOURCE_CODE_URL:https://github.com/MarlinFirmware/Marlin PROTOCOL_VERSION:1.0 MACHINE_TYPE:3D Printer EXTRUDER_COUNT:2 UUID:cede2a2f-41a2-4748-9b12-c55c62f367ff
Recv: Cap:SERIAL_XON_XOFF:0
Recv: Cap:EEPROM:1
Recv: Cap:VOLUMETRIC:1
Recv: Cap:AUTOREPORT_TEMP:1
Recv: Cap:PROGRESS:0
Recv: Cap:PRINT_JOB:1
Recv: Cap:AUTOLEVEL:1
Recv: Cap:Z_PROBE:1
Recv: Cap:LEVELING_DATA:1
Recv: Cap:BUILD_PERCENT:0
Recv: Cap:SOFTWARE_POWER:0
Recv: Cap:TOGGLE_LIGHTS:0
Recv: Cap:CASE_LIGHT_BRIGHTNESS:0
Recv: Cap:EMERGENCY_PARSER:0
Recv: ok
Send: M21
Recv: T:189.91 /190.00 B:60.11 /60.00 T0:189.91 /190.00 T1:189.94 /0.00 @:57 B@:0 @0:57 @1:0
Recv: ok
Send: M155 S2
Recv: ok
Recv: echo:enqueueing "M105"
Recv: T:189.77 /190.00 B:59.67 /60.00 T0:189.77 /190.00 T1:189.94 /0.00 @:60 B@:127 @0:60 @1:0
Changing monitoring state from "Operational" to "Starting"
Recv: ok
Changing monitoring state from "Starting" to "Printing"
Send: N1 T1*58
Recv: echo:Active Extruder: 1
Recv: ok
Send: N2 M140 S60*81
Recv: ok
Send: N3 M105*36
Recv: T:189.94 /190.00 B:59.75 /60.00 T0:189.94 /190.00 T1:190.00 /0.00 @:56 B@:127 @0:56 @1:0
Recv: T:189.89 /190.00 B:59.94 /60.00 T0:189.89 /190.00 T1:190.14 /0.00 @:58 B@:127 @0:58 @1:0
Recv: T:190.31 /190.00 B:60.43 /60.00 T0:190.31 /190.00 T1:189.74 /0.00 @:47 B@:127 @0:47 @1:0
Recv: T:190.07 /190.00 B:60.46 /60.00 T0:190.07 /190.00 T1:189.89 /0.00 @:55 B@:127 @0:55 @1:0
Recv: T:190.00 /190.00 B:60.68 /60.00 T0:190.00 /190.00 T1:190.14 /0.00 @:55 B@:127 @0:55 @1:0
Recv: T:190.24 /190.00 B:60.52 /60.00 T0:190.24 /190.00 T1:189.72 /0.00 @:49 B@:0 @0:49 @1:0
Recv: T:189.83 /190.00 B:60.83 /60.00 T0:189.83 /190.00 T1:189.94 /0.00 @:59 B@:0 @0:59 @1:0
Recv: T:190.10 /190.00 B:60.31 /60.00 T0:190.10 /190.00 T1:189.83 /0.00 @:52 B@:0 @0:52 @1:0
Recv: T:189.72 /190.00 B:60.37 /60.00 T0:189.72 /190.00 T1:190.00 /0.00 @:62 B@:0 @0:62 @1:0
Recv: T:189.91 /190.00 B:60.80 /60.00 T0:189.91 /190.00 T1:189.80 /0.00 @:55 B@:0 @0:55 @1:0
Recv: T:190.07 /190.00 B:60.60 /60.00 T0:190.07 /190.00 T1:190.03 /0.00 @:51 B@:0 @0:51 @1:0
Recv: T:190.07 /190.00 B:60.25 /60.00 T0:190.07 /190.00 T1:189.77 /0.00 @:51 B@:0 @0:51 @1:0
**here is some more system info :**
browser.user_agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/98.0.4758.109 Safari/537.36 OPR/84.0.4316.52
connectivity.enabled: true
connectivity.online: true
env.hardware.cores: 4
env.hardware.freq: 1500
env.hardware.ram: 3971158016
env.os.bits: 32
env.os.id: linux
env.os.platform: linux
env.plugins.pi_support.model: Raspberry Pi 4 Model B Rev 1.2
env.python.pip: 22.0.4
env.python.version: 3.7.3
env.python.virtualenv: true
octoprint.safe_mode: true
octoprint.version: 1.7.3
printer.firmware: Marlin 1.0.0 (Github)
