Stream Stops after some time with multiple webcams
  • Logitech C922
  • Spedal 920
The stream for both cameras work when first starting up OctoPrint, but the stream fails after some time.
Monitoring stream with Chrome inspection tools.
I am using two cameras with the multi-cam plugin. I used these setup instructions to set up two cameras on the new webcam stack.
Initially only one camera worked, but after I changed FORMAT: YUYV to FORMAT: MJPEG both camera streams work. After a period of time, I notice that the stream stops running in the Chrome inspection tools. The example shown does not show that it has stopped, but it will usually stop after a few hours.
N/A
The Syteminfo Bundle was too large, so I have uploaded it to google drive.
  • OctoPrint Version: OctoPrint 1.9.1
  • OctoPi Version: OctoPi 1.0
  • Browser: Google Chrome on Macbook Pro
The camera setups are as follows:
Webcam 1:
Options for USB based cameras
The port on which the webcam server for the camera should listen on.
PORT=8082
The path to the camera device.
DEVICE=/dev/v4l/by-id/usb-046d_C922_Pro_Stream_Webcam_DBDAE4BF-video-index0
The image format of the camera.
FORMAT=MJPEG
The resolution to set on the camera. Defaults to 1280x720.
WIDTH=1280
HEIGHT=720
The framerate to set on the camera. Defaults to 15fps.
FRAMERATE=15
Additional options.
OPTIONS=
Webcam 2:
PORT=8081
DEVICE=/dev/v4l/by-id/usb-Sonix_Technology_Co.__Ltd._USB_Live_camera_SN0001-video-index0
FORMAT=MJPEG
WIDTH=1280
HEIGHT=720
FRAMERATE=15
Additional options.
OPTIONS=
Thanks in advance for the help!
Hello @neil-obico !
The log is flooded by octoeverywhere messages, at about 98%. About 1.000.000 lines.
That is way too much.
And in addition, someone activated the DEBUG mode so the flooding was multiplied.
Most recent version of Octoeverywhere is 2.7.0:
Where have you 2.7.1 got from?
|  OctoEverywhere! (2.7.1) = /home/pi/oprint/lib/python3.9/site-packages/octoprint_octoeverywhere
And why not?
Even if it is older, you may have a look on this thread:
Thank you for the quick response @Ewald_Ikemann
Thanks for pointing out that the file is flooded with Octoeverywhere messages.
I am not sure how I ended up with Octoeverywhere version 2.7.1. I see the current version is 2.7.0, but somehow I installed the plugin via the plugin manager last week and got 2.7.1.
I will do some more testing with Octoeverywhere disabled, and with OctoPrint in safe mode and follow up.
Testing In Safe Mode
I tried running in safe mode, but I am not able to sufficiently test the setup in safe mode. The webcam settings do not allow me to select any webcams when I am in safe mode.
As shown, the webcam is not selectable in safe mode:
Not in safe mode, I can see/select the desired default webcam:
I removed Octoeverywhere, so the only plugins installed are:
  • Multicam
  • Resource Monitor
System Info Bundle
Here is a new Syteminfo Bundle
I still experience the same issue.
To reproduce:
Open OctoPrint interface
Open chrome dev tools (I see stream sending data for a period of time, but eventually data stops sending and the stream starts to overlay a black rectangle that increases in vertical size over time)
According your recent systeminfo bundle, octoeverwhere is still installed:
2023-07-10 18:13:33,193 - octoprint.plugin.core - INFO - 22 plugin(s) registered with the system:
The log contains information from yesterday and the day before, but it is uninstalled (and data cleaned up) as of last night. In the uploaded log, Octoeverywhere is uninstalled at
2023-07-11 19:24:57,133 - octoprint.plugins.pluginmanager - INFO - Plugin octoeverywhere uninstalled
I am still able to reproduce the problem after uninstalling Octoeverywhere and restarting OctoPrint.
Increasing NBUF in the configuration files for each camera fixed this for me.
I ended up setting the buffers to 10 for each USB camera.
I'm running two Logitech 920's, one USB borescope camera and a PiCam on a Pi4.
Now that the streams do not fail I've run into the persistent stream issue.
